Epson R2880- Ink Charging Cycle- Daily??
Started Mar 28, 2010 | Discussions
Clark95
Clark95 Regular Member • Posts: 462
I recently purchased the Epson R2880. In four days of use- it has performed an ink charging cycle each day. I used to have the R1800- it would charge the ink approx once every two weeks- or after a large print job. Is this normal for the 2880??? It happened three times and not turning the printer off. Turned printer off for a day and then printer- same thing. IS there a seting I may have checked off? I looked but did not see one- and don't know why it is going through these five minute cycles every day. Thanks for any advice.
xilvar
xilvar Senior Member • Posts: 1,403
Re: Epson R2880- Ink Charging Cycle- Daily??
There are many different cleaning/maintenance cycles. Some of them use very little ink, and some use a lot. Are you sure its really taking 5 minutes of wall-time?
In any case its probably not doing a charging cycle. that's a lot of ink... It's probably doing a light cleaning (relatively little ink)
xilvar
Clark95
Clark95 OP Regular Member • Posts: 462
It does a cleaning cycle at least a full three minutes- I have not timed it exactly. But it is the same process it goes through when I had the R1800 and would clean the print head if there were clogs. Also, each time my R2880 is doing this- I see the ink levels all drop a little. I just don't understand why it would do it four times in week. I plan on printing something this evening- and will see if it does it again. If it does I may give Epson a call- but don't know how much help I will get.
Psiman
Psiman Regular Member • Posts: 130
I've had my R2880 since last June and haven't seen this but I only switch it off using the top power switch NOT the mains switch.
Simon
http://www.crewephotosoc.com
Clark95
I take it you mean the power button? That is also how I turn it off- but I only turned it off once- the other times I just left it on.
