Best portrait lens on Sony a900
Started Feb 20, 2010 | Discussions
WMcCann Regular Member • Posts: 237
Hi All,
I am sure this has been asked before but I have read through loads of posts but every time the answer seems to allude me (also the search function on DPReview sucks, seems to throw up the main post and all subsequent posts so a simple search returns thousands of results - useless....) so please don't flame me.
I have an A900 and the following lenses:
Sigma 12-24mm
Sony Zeiss 24-70mm
Sony 70-200mm G
Sony 70-400mm G
Minolta 100mm Macro (2.8)
Minolta 50mm f2.8 macro
I am looking to add a fast prime to the above for taking portraits of my kids, I have been using the 100mm but while the results are good they are not exactly what I am looking for (being a specialised macro lens etc).
I have narrowed my choice down to the CZ 85mm or the CZ 135mm.
The 85mm seems to have problems when used at f1.4 with purple fringing etc.
What I am really wondering is which is the sharpest lens?
Which has the best Bokeh?
Which woud you use for head/shoulder portraits (note not necessarily posed) on the A900?
Any help would be appreciated,
Thanks,
Walter.
dennismullen
dennismullen Veteran Member • Posts: 8,994
Re: Best portrait lens on Sony a900
On the A900 I like the CZ135/1.8
Both are good, I'd go with the field of view that suits you.
1/250s f2.8 at 135mm iso200
“Those who would sacrifice liberty for safety deserve neither liberty nor safety.” - Ben Franklin.
You can see larger versions of my pictures at http://www.dennismullen.com .
lloyd007 Senior Member • Posts: 1,354
Re: Look at the 135stf
can't buy a lens with better bokeh if that is what you are looking for in portraiture
m_appeal Veteran Member • Posts: 3,434
I find 135 to be too long on A900
Why not try 100 f2 Minolta?
William P Regular Member • Posts: 415
Hi Walter,
cz135 is in a class of its own - can't be beat for head & shoulders portraits. In fact, can't be beat period! Unless you need more room Colour fringing does show up occasionally with the cz85 - but not to the extent that I wouldn't have the lens in my bag. I have both, prefer the 135 - but the 85 is my most used lens. Funny how that happens.
William
Mark K
Mark K Veteran Member • Posts: 5,238
Walker
If it is the optical quality you are after , then the 135 stf must be the answer. This is the only one I do not have in hand
Mark K
 Mark K's gear list:Mark K's gear list
Sony Cyber-shot DSC-RX100 III Sony SLT-A77 Nikon D800 Canon EOS 5D Mark III NEX5R +63 more
DUSTY LENS
DUSTY LENS Veteran Member • Posts: 4,308
Any help , that is my invitation to go where I might not go .
I have the CZ 135 and the a-900 and I love the ability to isolate the background to a small area this lens allows , because it is a long lens .
You could easily find a small shaded area to place behind your subject , with this lens and you will also get very good background blur which really helps this kind of use .
My only argument against using this lens is the possibility of tiring of the weight , if you need to hold it for extended times . in that case you could switch to a 100 f2.8 if it is a light weight lens .
If you are planning to keep up with small kids you might do better with the 85mm because it is lighter and because it will have a focusing speed advantage over the 135 f1.8 .
Either lens will probably give you very great results at f5.6 or around f5.6 .
Try to shoot some test shots at a Sony Style Store with these first . Just call in advance to check the availability of demos and the best time .
I brought my own Flash Card and was allowed to use it in their a-900 .
Dusty
 DUSTY LENS's gear list:DUSTY LENS's gear list
Sigma 35mm F1.4 DG HSM Art
Jim Cockfield Forum Pro • Posts: 16,333
ditto - Minolta 100mm f/2
Ditto. I'd try to find a Minolta 100mm f/2. It's a really good lens. Here are a couple of snapshots using one wide open at f/2 on a KM Maxxum 5D.
lunartown Senior Member • Posts: 1,352
Try the Minolta AF 135 F2.8, weight: only 365 g
Harry Lew Senior Member • Posts: 1,629
Don't forget the Minolta 85 1.4G . . .
I own both the Zeiss and Minolta 85s. The Minolta may be a tad less sharp, but it has better bokeh. Plus the colors seem to be warmer. It's also cheaper than the Zeiss, understandably, since it's an older, out of production lens.
Harry Lew
'Buying gear is easy. What's hard is paying for it.'
http://harryjohn.smugmug.com/
Lyle From Canada Senior Member • Posts: 1,509
The CZ135/1.8 is sony's crown jewel, best lens period.
Sony A300 - Minolta 24-50/4 - Minolta 35-105(old) - Minolta 70-210/4 - Minolta 50/1.7 - Minolta 100-200/4.5 - Minolta 75-300 (new) - Kenko telepro 300 1.4 TC - extension tubes
 Lyle From Canada's gear list:Lyle From Canada's gear list
Ricoh GR Olympus OM-D E-M10 II Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm 1:1.8 Olympus 14-150 F4-5.6 II
Docno Veteran Member • Posts: 4,579
I asked this before and I'm still confused
http://forums.dpreview.com/forums/read.asp?forum=1037&message=32447528
My lens lineup is very similar to yours (see my sig). I asked the question and received the same reasonable answers and, 9 months later, I'm yet to buy a new lens. I'm recently leaning toward the CZ135 because it could do double duty at night events (concerts etc) I sometimes go to. It also seems more distinct (but not greatly so) from other lenses I have: the 50mm and 100mm. I experimented with using my 70-300mm G at the two focal lengths to see which I'd prefer, but their was no clear winner. I'm usually not an indecisive person, so this is really bugging me... at these prices, I don't want to have any regrets.
So good luck... let us know what you decide.
Glenn
Galleries: http://picasaweb.google.com.au/glennjude
Sony a900, a700; CZ24-70mm, SAL70-300mmG, 50mm F1.4, 100mm F2.8 macro, CZ16-80mm, KM11-18mm, SAL18-250mm
 Docno's gear list:Docno's gear list
Sony RX1 Sony Cyber-shot DSC-RX100 IV Sony Alpha 7R Sony Alpha 7R II Sony FE 35mm F2.8 +2 more
joe_rogg Regular Member • Posts: 114
Re: I asked this before and I'm still confused
I suggest the CZ 24-70. Works great for me.
headofdestiny Veteran Member • Posts: 9,226
It's really not about which lens is better, but, rather, which focal length you like better. Even though there probably isn't a better lens, optically, than the ZA 135, I shoot the ZA 85, because I like the working distance better, and it's a more portable lens. Great bokeh, too.
-Douglas
AlphaDSLR Senior Member • Posts: 1,177
Are you going to be using f/1.4? None of the other lenses even have that aperture as an option.
'Nothing is more fairly distributed than common sense: no one thinks he needs more of it than he already has.'
Rene Descartes
WMcCann OP Regular Member • Posts: 237
Hi All,
Thanks for the help. Ended up getting a second hand Minolta 85mm on Ebay (arrived from Germany yesterday) and a new CZ 135mm from Hong Kong (arrived today).
What can I say - the CZ is amazing (it is now my main lens after only a few shots).
I take mostly people especially my kids, the control the 135mm gives is great. The 85mm is a lovely lens with great colours but not as sharp as the 135mm.
To anyone who has this conundrum all I can say is if you have the A900 then get the CZ if you have the A700 or other get the 85mm. The Minolta was £500 and in perfect nick which I think is quite a good price.
Now do I sell the 85mm or keep it.... Decisions Decisions.
Again thanks to everyone,
Walter.
asiafish Regular Member • Posts: 394
Agree.  The Minolta 135/2.8 is a real gem, small, light and quite a bargain.  While I own the 85/1.4 and 35/1.4, I usually travel with just the 28/2.8 (another much-maligned, but excellent lens), 50/1.4 and 135/2.8.  Those are my three cheapest lenses, my three smallest, lightest and by far my three most used.
'China, which we call Red China, just exploded a nuclear bomb, which we called a device'
- Tom Lehrer
 asiafish's gear list:asiafish's gear list
Leica Summarit-M 35mm f/2.5 Leica Summicron-M 50mm f/2
MediaArchivist
MediaArchivist Senior Member • Posts: 2,710
For portraits on my a99, I use primarily the 135 STF, ∑70mm macro, and ∑50/1.4. 135mm is just a little long, but workable. The 70mm macro is just about right, and if I have less light the 50mm does a fine job (although perhaps better on my a77).
I have been looking at the CZ85 and the CZ135 as you have, but since I already have a 135mm lens (that I also think might be just a little too long) I am leaning pretty hard towards the CZ85. A small amount of fringing does not scare me, from what I have read and seen it cleans up nice in Lightroom.
 MediaArchivist's gear list:MediaArchivist's gear list
Sony SLT-A99 Sigma 50mm F1.4 EX DG HSM Sony 135mm F2.8 (T4.5) STF Sony 24mm F2 SSM Carl Zeiss Distagon T* Sigma 35mm F1.4 DG HSM Art +16 more
yakkosmurf Senior Member • Posts: 2,095
I have the 135 and I'm happy with it. I'll probably get the 85 at dime point, as I find the 135 to be a bit ling for shooting in some of the smaller rooms in my house. Play around with your 70-200 to see if focal length matters to you.
yakkosmurf
http://www.flickr.com/photos/yakkosmurf/
a850, a700, R1
24-70CZ, 16-35 CZ, 135CZ, 70-400G, 70-300G, 16-80CZ, Sig 24 1.8 & 10-20 4.5
F58AM flash
 yakkosmurf's gear list:yakkosmurf's gear list
Sony Alpha DSLR-A850 Sony 16-35mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 24-70mm F2.8 ZA SSM Carl Zeiss Vario-Sonnar T* Sony 70-400mm F4-5.6 G SSM Sony 135mm F1.8 ZA Carl Zeiss Sonnar T* +7 more
Brian_Smith
Brian_Smith Senior Member • Posts: 2,530
You've already got my favorite lens for portraits the Sony CZ 24-70mm.
Given what you've got I'd suggest the Sony CZ 135mm/1.8 - AMAZING GLASS!
