Don't Do This To Your Lens Collection . . .
Started Feb 14, 2010 | Discussions
jhinkey
Senior MemberPosts: 2,758Gear list
Feb 14, 2010
Well, actually if you like to be scared for a second go ahead.
I am looking into buying a 135/2 AIS from someone and I asked him to take some images of the lens with a light shined through it. Being that it's an old lens I fully expected it to look quite awful - and it did.
For a reference I took some quick pics of a couple of my lenses (using my excellent LX3 in macro mode hand held) shining an LED flashlight through both ends (the G-lenses were a pain because it's hard to keep the aperture wide open).
Here's what I found:
35-70/3.5 AI (72mm filter ring version)
Two from my newly-acquired 105/2.5 AIS
Now, just looking at these lenses in daylight they don't look nearly this bad and they take just fine images - except for the 35-70 when pointed into direct sunlight it flares quite badly. It seems like it could use a cleaning even though it takes quite nice images when used without the sun in the frame.
So, intrigued, I pulled out some more of my lenses, new and old:
70-300AFS
It's not bad for a 1 year old lens.
Now two from my 200/4 AIS
And one from the rear of my 180/2.8 ED-IF AF
This one looks pretty darn clean for a used lens that's at least 5 years old.
And finally from my 16-85AFS which has not been cleaned in a while
Most of these spots were on the rear element which has not been cleaned in quite a while. It cleaned up nicely using my lens pen.
So I'll probably buy the 135/2 AIS even though it looks similar to the 200/4 and 105/2.5 when a light is shined through it. I may get the 35-70 cleaned if it's not too much to do it.
All of these lenses have taken fine images even with all the dust on the lens elements. It really only shows up with strong contrast or direct light into the lens and even then I never noticed any issues until I pointed the 35-70 directly into the sun.
So don't freak out if you see a lot of individual dust specs in your lens when you shine a flashlight through it - the dust likely will not make a noticeable difference unless the element has a continuous slight haze over it like my 35-70/3.5 has (which again probably should be cleaned).
Can anyone suggest a good place to have AI or AIS lenses CLA'd for a reasonable amount?
John
 jhinkey's gear list:jhinkey's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-LX7 Nikon D800 Panasonic Lumix DMC-G5 Panasonic Lumix DMC-GH3 +20 more
pluton
Senior MemberPosts: 2,691Gear list
Re: Don't Do This To Your Lens Collection . . .
In reply to jhinkey, Feb 14, 2010
Any good Nikon-familiar repair shop should be able to handle the less complicated lenses. The more complex zooms, maybe that's a Nikon job.
BTW, the cleanest lenses you'll find are Leica lenses; next cleanest, traditionally, are Zeiss. Once, back in the early eighties, I had on hand Leica, Nikon, Zeiss, and Canon lenses, so I put them in front of a very bright light(a slide projector with a three-hundred watt lamp). Leica: pretty damn clean; Zeiss, a few dust particles; Nikon: dust, cloudy areas, and smears. Canon: dust, smears, cloudiness, AND human fingerprints . Be glad you're not seeing fingerprints!
-KB-
 pluton's gear list:pluton's gear list
Nikon D800 Nikon D800E Fujifilm X-E1 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R
Snapshott
Senior MemberPosts: 2,114Gear list
I have actually looked at all my new and used purchases with a flashlight. Especially used purchases since this will show fungus growth when just holding it up to light will not.
BTW most of mine are a little better than that but I do have a Nikon 50mm f1.4 D that it pretty dusty (more than most of your shots) and it is sharper than my Nikon 50mm f1.4 non-d that is very clean.
Snapshott
 Snapshott's gear list:Snapshott's gear list
Nikon D80 Nikon D7000 Nikon D750 Nikon AF-S DX Nikkor 18-135mm f/3.5-5.6G ED-IF Nikon AF-S Nikkor 300mm f/4D ED-IF +17 more
tarnish
Senior MemberPosts: 1,470
It's all relative
The last image makes my point more so than the previous - when the very dim reflections from a multicoated lens have gone all the way to a blown-out highlight, you can guess that the percentage of light that is scattered by the dust is usually pretty small. What you have to absolutely stay away from are lenses that look like that when the light isn't so strong!
Are you ready for some of the best photographic advice you will ever hear?
Q. When is the best time to clean a lens?
A. Never.
OK, don't take that completely literally, but honor the spirit of it as much as practically possible. Try to keep the lenses from needing to be cleaned in the first place.
BoyOhBoy
Senior MemberPosts: 1,807
Re: It's all relative
In reply to tarnish, Feb 14, 2010
A. Never.
Even when lenses get pretty filthy there is no particular need to clean them
http://kurtmunger.com/dirty_lens_articleid35.html
Shining a bright light through a lens to highlight all sorts of spot defects is hardly a reasonable thing to do. Doing so under appropriate conditions on the air that surrounds the lens (and that you breathe) will look scary too. All these particles are so severely OOF that they will never image.
jhinkey
jhinkey OP
In reply to tarnish, Feb 15, 2010
A. Never.
Like I said above - only one of the lenses I had any issue at all with it's IQ and that was the dirtiest. So it's relative - at some point a lens will be dirty enough to show issues - that's the time to get it cleaned if it's needed.
Well, for some lenses that's almost impossible if they are a zoom that pumps air in and out every time you zoom it's going to get dusty for sure.
John
jhinkey
jhinkey OP
In reply to BoyOhBoy, Feb 15, 2010
A. Never.
Interesting article, but hardly convincing since he took a picture of the sun with the scratches, but not before he scratched it. If I get dust on my 16/3.5 AI or 16/2.8 fisheyes and point them toward the sun it certainly can show up in the images as flare or ghosts.
Sure it's a reasonable thing to do IF you know how to interpret what you see (i.e., only get concerned if there is something to be concerned about). Fungal infection being one of those things to be concerned about - how else would you find out you had a problem?
My 35-70/3.5 definitely shows flare problems most likely due to the haze on one of the internal elements.
Yes your are correct, the individual dust particles will never image, but they can contribute to flare if large enough or numerous enough and a strong light source is in the image.
John
BruceEvans
Senior MemberPosts: 1,291
Ken Rockwell's take on this
In reply to jhinkey, Feb 15, 2010
Hate to use him as a reference but Ken Rockwell has a really good article on this.
Throw away the flashlight.
Bruce
BRJR
Forum ProPosts: 13,641Gear list
"Flashlight Test"; But, Here's How To Analyze Findings. :-)
Here's a link to the "Flashlight Test":
http://www.kenrockwell.com/tech/flashlight-test.htm
BRJR ....(LOL, some of us are quite satisfied as Hobbyists ..)
 BRJR's gear list:BRJR's gear list
Nikon D700 Leica M9 Nikon AF Nikkor 14mm f/2.8D ED Nikon AF Fisheye-Nikkor 16mm f/2.8D Nikon AF Nikkor 20mm f/2.8D +21 more
jhinkey
jhinkey OP
Re: "Flashlight Test"; But, Here's How To Analyze Findings. :-)
In reply to BRJR, Feb 15, 2010
Actually quite a good article from Ken. He doesn't say to throw away the flashlight at all.
John
tarnish
It's about the loss of contrast from the scattering of the light. That's why I clean my eyeglasses every morning. Sometimes it makes a world of difference.
Dust on lenses certainly does hurt the image but from time to time someone or other will get carried away about it. With experience you know how much contamination is too much to tolerate.
DaveOl
Senior MemberPosts: 2,858Gear list
In reply to jhinkey, Aug 3, 2013
Jhinkey
Sorry to see all your dusty lenses.  If you send them all to me, I'll make a good home for them.
 DaveOl's gear list:DaveOl's gear list
Nikon D300S
jhinkey
jhinkey OP
In reply to DaveOl, May 12, 2014
DaveOl wrote:
Jhinkey
I guess you missed the point of the thread then . . .
unknown member
(unknown member)
In reply to jhinkey, May 12, 2014
