Epson R2400 not accepting paper
Started Jan 7, 2010 | Discussions
DavidF
DavidF Regular Member • Posts: 372
My trusty Epson R2400 has stopped accepting sheets of paper. Either the sheets are taken in to the printer and then spit back out without printing, or the printer just doesn't take the sheets--I get print feed error messages in both cases (and I think I'm running through ink with each error message). All the sheets were letter-size.
Does anyone have suggestions for how I can get the printer to accept paper?
Best, David.
dhall
dhall Regular Member • Posts: 150
Re: Epson R2400 not accepting paper
It's usually because the paper feed roller is lightly covered with dust from paper feeding. The rubber coating collects dust over time. The roller tends to work better with glossy and semi-glossy paper but if you feed a lot of photo rag/matte paper you will pick up more residue from the paper.
You can try taking a lightly damp washcloth, hold it against the roller, then hit the top button on the front panel (paper feed) to trigger the roller. With light pressure, hold the damp washcloth against the roller and it should pick up the dust. The roller will revolve twice with every paper feed button push. There is a flat side to the roller that you will notice as it spins around.
luibob
luibob Junior Member • Posts: 32
Wow. You all never seize to amaze me. I had the same problem. I would have spent all night re-installing drivers and cursing. Damp cloth on the roller did the trick!
-Luis
Epson R-2400
 luibob's gear list:luibob's gear list
Nikon D90 Nikon 1 V1 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-105mm f/3.5-5.6G ED VR Nikon AF Nikkor 24mm f/2.8D +1 more
Juliette22
Juliette22 New Member • Posts: 1
Best, David.
My Epson does not pull the paper  A3 +  anymore and I get the dreaded 'media out'... I have reloaded the Drivers/ re-started my Mac nothing works ....
Will the trick with the damp cloth work ? and what do you actually do.  ? Regards
xrdbear
xrdbear MOD Veteran Member • Posts: 3,883
Best, David.
This is a very old thread, you might get more luck by starting a new thread or sending a private message. What printer are you using?
Brian
Fine Art Print sales of the Isle of Skye at:
http://www.eyeofskye.co.uk/
