Promaster 18-200mm and Tamron 18-200mm
Started Jan 4, 2010 | Discussions
johnnyz86
Contributing MemberPosts: 956Gear list
Jan 4, 2010
Please state the relationship between these two lenses for me:
Promaster 18-200mm Digital XR EDO Aspherical Auto Focus Zoom Lens for Pentax
Tamron AF 18-200mm f/3.5-6.3 XR Di II LD Aspherical (IF) Macro Zoom Lens for Pentax Digital SLR Cameras
 johnnyz86's gear list:johnnyz86's gear list
Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO Pentax smc DA 70mm F2.4 AL Limited +3 more
MightyMike
Forum ProPosts: 33,174
Re: Promaster 18-200mm and Tamron 18-200mm
In reply to johnnyz86, Jan 4, 2010
its extremely likely that the Promaster is a clone of the Tamron, but i doubt Promaster would ever admit that. however if you're looking for a super zoom save up for the Pentax/Tamron 18-250 as i do believe its the best of the bunch
Mike from Canada
http://www.airliners.net/search/photo.search?sort_order=views%20DESC&first_this_page=0&page_limit=180&&emailsearch=mighty_mike88%40hotmail.com&thumbnails=
Ed Woodson
Contributing MemberPosts: 797
When I first got back into Photography in 2006, my local dealer sold me a Promaster 70-300 zoom. A couple of weeks later I ran across another Pentax shooter who was using the the Tamron 70-300 zoom. We did a rather close comparison and concluded that the Promaster was/is a re-badged Tamron. All of the specs are exactly the same. I suspect that the same applies to the 18-200 zioom.
'The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?'
johnnyz86
In reply to MightyMike, Jan 4, 2010
Thanks, I am looking for information on these specific lenses and whether or not they are the same.
MightyMike
the Promaster could be a copy of the Sigma 18-200 also, take a good look at the specs
Mike from Canada
johnnyz86
http://www.amazon.com/Tamron-AF-18-200mm-Aspherical-Pentax/dp/B0007WK8NK/ref=sr_1_1?ie=UTF8&qid=1262621831&sr=8-1-fkmr0
Specifications
  • Focal length: 18-200mm
  • Maximum aperture: f/3.5-6.3
  • Lens construction: 15 elements in 13 groups
  • Angle of view: 75 to 7 degrees
  • Type of zooming: Rotation
  • Diaphragm blades: 7
  • Minimum aperture: f/22
  • Minimum focusing distance: 17.7 inches
  • Macro magnification ratio: 1:3.7 (at f=200mm)
  • Filter size: 62mm
  • Corresponding mounts: Pentax
  • Lens hood: Yes, flower shaped
  • Dimensions: 2.9 inches in diameter and 3.3 inches long
  • Weight: 14 ounces
  • Warranty: 6 years
PROMASTER ®
http://www.promaster.com/products/products.asp?product=AF18200
Specifications:
• Enhanced Digital Optic Design
• Lens Construction: 15 Elements in 13 Groups
• Lens Coating: Multicoated
• Angle of View: 75-7°
• Minimum Aperture: f/22
• Minimum Focusing Distance: 17.7 in (0.45m)
• Maximum Magnification: 1:3.7 (at 200mm)
• Zooming System: Rotary
• Weight: 14 oz.
• Diameter x Length: 73.8mm x 83.7mm
• Filter Size: 62mm
• Bayonet lens hood included
• Lifetime Warranty
Sigma 18-200mm F3.5-6.3 DC
Lens Construction
http://www.sigmaphoto.com/lenses/lenses_all_details.asp?id=3302&navigator=6
Angle of View 69.3 - 7.1 degrees (Sigma SD format)
Number of Diaphragm Blades 7 Blades
Minimum Aperture F22
Minimum Focusing Distance 45cm / 17.7 in.
Maximum Magnification 1:4.4
Filter Size Diameter 62mm
Lens Hood Petal Hood
Dimensions Diameter 70mm X Length 78.1mm
2.8 in. x 3.1 in.
Weight 405g / 14.4 oz.
Ed Woodson
Looking at the specs, I'd say that the Promaster and Tamron are the same.
biggest difference you'll find. a year or two down the road, the Tamron will have a much greater re-sale value than will the Promaster.
KentG
Veteran MemberPosts: 4,204Gear list
In reply to johnnyz86, Jan 5, 2010
Yes the Promasters are all rebadged Tamrons while if I remember correctly the Quantaray lenses were all rebadged Sigmas. I have a Tamton 18-200 that I bought before the 18-250 or 18-270 cameout. I am pretty sure the 18-250 is a better but more expensive lens. I use mine for one lens travel only because if I can carry at least 2 then the Pentax 18-55 AL II and the 55-300 ED will give me better results. In fact the Tamron SP 24-135, which is a FF lens, gives much better results than the 18-200 as long as you don't need the extra range.
Kent Gittings
 KentG's gear list:KentG's gear list
Pentax K-5 II Pentax K-5 IIs Pentax K-S1 Sigma 50-150mm F2.8 EX DC APO OS HSM Sigma 18-250mm F3.5-6.3 DC Macro OS HSM +1 more
