Why do colors look different in Viveza compared to LR/CS3/etc
Started Dec 17, 2009 | Discussions
zieglp1 New Member • Posts: 5
Whenever I take an image into Viveza the colors look over-saturated compared to how the image appears in Lightroom, Photoshop CS3, or any of the other Nik plug-ins (Dfine, Color Efex Pro, Sharpener Pro). I thought that maybe I had a different color space assigned for Viveza but I can't find anywhere to confirm or check the Viveza colorspace. When I bring the image back into Lightroom, it reverts to normal saturation. However, that makes working in Viveza pretty difficult since I don't have real-time feedback of my changes to color. Any ideas on why this only affects the Viveza plug-in and how I might go about fixing the problem? Thanks.
zieglp1 OP New Member • Posts: 5
Further information
I should have mentioned that the problem only exists when I enter Viveza through Lightroom. If I enter via Photoshop, the colors look correct. However, when I enter other Nik plug-ins via Lightroom, the colors look fine. Weird.
sbrom Forum Member • Posts: 50
Re: Further information
I had the same issue. Running under Vista 64, NIK told me this was a known issue in certain PC's with the lightroom version of Viveza. No workaround except to use it in Photoshop instead.
sbrom
Toermalijn
Toermalijn Forum Pro • Posts: 13,603
sbrom
Doesn't it have something to do as how photoshop and lightroom work? You would think that lightroom would use the same colour-aware engine as photoshop is using?! Then all photo's should look the same on the same system.
Toermalijn
Toermalijn wrote:
sbrom
or and that is most likely, the photoshop plug-in has the better engine as photoshop is more sophisticated underneath the skin.
It happens sometimes that plug-ins for photoshop work betetr then the same for lightroom, so one would think that the plug-ins engine of photoshop is better and more sophisticated. What i have read somewhere is that lightroom actually doesn't use a plug-in engine, certainly not photoshop's engine.
Toermalijn
Toermalijn wrote:
Toermalijn wrote:
sbrom
I forgot;
in photoshop there are two versions of plug-ins used. Ones that go outside photoshop and use their own engine and memory, or plug-ins that stay inside photoshop envirement and use photoshop resources.
Thanks for the reply. I appreciate the information. I have a new computer on order, so hopefully it won't be an issue with the new machine (with Windows 7).
Toermalijn
Re: Thanks
I am also running windows 7 64 bit and it runs flawlessly. I am quite sure you'll really like windows 7. The best OS from microsoft in years.
Jesper Lauritsen New Member • Posts: 11
Re: Why do colors look different in Viveza compared to LR/CS3/etc
Hi,
I downloaded the demo version previously today and almost gave up imediatly because of this issue.
However, I discovered that it is somehow connected to me having two screens (the build-in screen on my Dell E4300 and my external LaCie 324) with differenct color profiles.
When I switch to using only the external screen I get the same colors in Lightroom and Viveza! That is the good thing; the bad thing is that they both have the wrong color. I am however fairly confident that a reprofiling with only one screen will fix this.
My guess is that on some hardware configurations with two screens Viveza chooses the profile for the wrong screen.
Jesper
richardplondon
richardplondon Veteran Member • Posts: 9,901
Lightroom plugins are all of the first kind AFAIK. There is not (yet) the ability in Lightroom to do the second thing. Although the LR menus may gain some extra items and what happens may appear quite transparent, as I understand it LR is only made to do things that it could do already . Any extra function needs a completely distinct program and data is usually passed to that via an external file on disk; not integrated within memory as with PS.
For example the LR/Enfuse plugin first causes LR to save temporary images onto disk (using its normal methods), and then runs the Enfuse commandline program as a separate application using these (telling it to save the result on disk), and then gets the OS to delete the temporary images.
RP
 richardplondon's gear list:richardplondon's gear list
Panasonic Lumix DMC-LX100 Pentax K-5 Sigma 10-20mm F4-5.6 EX DC HSM Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 70mm F2.4 AL Limited +7 more
richardplondon
two monitor profiles OT
I'm curious: do you have them independently profiled? What OS version? I have encountered a different issue (not related to Viveza) but with similar symptoms.
RP
Re: two monitor profiles on Windows 7 OT
RP
Im am running Windows 7 64bit profiled with an X-rite ColorMunki. Priviously I have had little luck getting different profiles for two monitors, but it seems like the E4300 protable has an graphics card with two LUT tables (although I have not been able to find any information about this). Largely it works with two profiles, but I have seen both Windows and specific apps with this kinds of problems before. And I have not been able to find much information about this kind of setup, even though it must be a quite common setup.
Jesper
richardplondon
Thanks for that info - I think there must be a lot of variation under different hardware setups; often it's a question of blindly poking at the thing until it cooperates
regards, RP
Toermalijn
regards, RP
ues and no. Windows 7 has a fastly improved interface for profiling 2 or more monitors. I guess it's amixture of software and hardware, certain lcd screens are know to have rgb and sRGB profiles but when tested it turns out to be not the case. It still keeps more or less the rgb mode/gamut. Dispite you turn the sRGB mode on in the menu!
Some people might not know this.
Read some monitor review sites!
In windows 7 you can easally switch from and to any profile for your selected monitor, so you can make 2 specific profiles for rgb and sRGB.
Sorry, I do not understand what your are meaning regarding rgb and sRGB profiles for the monitor?? In my view a monitor profiles describes the monitors colorspace and it is note relevant to call this rgb or sRGB (although I have seen some call a monitor an Adobe RGB monitor, but with that just meaning it kan show most of Adobe RGB and not just sRGB), but for sure there is a lot of this I do not quite understand, so I may well be mistaken. One of the reasons for me to chose a LaCie 324 is that it is fully calibrated by the X-rite software, so I do not think I have many choices in the monitor setup.
I would appreciate if you could explain a bit more and perhaps give a link to some pages at those monitor review sites.
Jesper
Toermalijn
Jesper
yes, it is very relevant as some lcd screens have menu lut's! Internal look up tables that have to be set accordingly before you hardware calibrate your monitor for the specific colourgamut/colourspace!
It turns out to be that some luts in fact don't go to sRGB but still are in rgb mode and fake sRGB mode! So, despite turning the menu sRGB on and profiling and calibrating it for sRGB space, you still might have oversaturated looking pictures on the screen!
Alot fake colourgamut where they should use a smaller gamut, but they don't! So, that is the hardware side of it!
It's not always software or microsofts' fault if something doesn't work propperly.
Comapedrosa Regular Member • Posts: 153
Hi,
I'm reviving this thread, since i'm having this exact same problem:
Win 7-64; 2 monitors (problems appears regardless of whether they are calibrated or not), LR4 and latest version of Nik Collection for Lightroom. Very frustrating, as it makes it pretty useless!
Has anyone found a solution/workaround?
Here's another thread i started about it, alas without resolution:
http://forums.dpreview.com/forums/readflat.asp?forum=1006&message=41162321
Nik has already taken 3 weeks and counting without meaningful solution.
Here's another example with one of Nik's own photos: it shows the same file opened in a bunch of applications, including Lightroom and CS5 (it's actually a photo from Nik's webpage!). All applications display the same colors except for Viveza 2 - where the red is clearly over-saturated!
Thank you so much for your help!!
CP
screen shot
forgot the screenshot...
Just found one workaround: if i disable one monitor, the problem disappears! Seems as if Viveza doesn't read the monitors' color profiles if there's more than one...
http://www.35f2.com
RolloWilliams New Member • Posts: 1
Been having same issue.  Very frustrating.  Been working with Nik for several weeks on this.  I open an image with Photoshop CS6 and looks the same on both monitors.  Open the same image with Viveza 2 and it looks correct on monitor 1 but clearly oversaturates reds on monitor 2. Using Spyder 3 Pro. All color space settings are the same.  Sent the monitor profiles generated by the Spyder to Nik and they say that "my profiles" are creating the same issue on their system but they can't pinpoint which line of code is the culprit.  My question is, and has always been, why can Photoshop recognize seperate monitor profiles and Nik can't?  Using a video card with seperate LUT's and have created my own profile with an exagerated gamma to make it obvious and have successully assigned the profile to the monitor of my choice.  It just looks pretty obvious that Viveza 2 can't destinguish between seperate profiles although Nik insist it can.  They ask me to contact Datacolor for their assistance.  Still no word from them yet.  I have researched this thing to death but so far have failed.  I love Nik software, but this is a real problem.  Could another monitor calabriation software be the answer? I would appreciate any help!
Windows 7, Photoshop CS6, Lightroom 4, Nik Complete Collection, Nvidia GTX 480 video card, Monitor #1 Dell WMP 2007 (tool and pallet monitor) Monitor #2 Dell U2410 (final edit monitor)
Ron
