Lens collar for tripod mounting heavy lenses
Started Nov 20, 2009 | Discussions
Kameraphil Regular Member • Posts: 445
As we know, these tiny micro cameras can be adapted to use many big legacy long lenses. Problems arise when on tripod, the front end with such a lens is to heavy, too unstable for the setup. I therefore wonder if some kind adjustable tripod mount rings are available for use with heavy lenses of variable diameters. Or anyone has other useful suggestions to get round this problem?
RoyGBiv Senior Member • Posts: 1,956
Re: Lens collar for tripod mounting heavy lenses
This is a common misconception. You do realize, the change in moment on a tripod due to the body size is actually near zero, right? Draw the force diagram on the system, and you'll see...having a thinner camera body actually improves your moment by drawing the lens a hair closer to the axis.
'I have no responsibilities here whatsoever'
Nikonparrothead Veteran Member • Posts: 4,648
Chances are a lens big enough to warrant a tripod collar should have one (I'm thinking of my experience with the Nikon line). That being said, it'd be a comical sight to see, say a GF-1 on the back of a 500 F4.
'Nice pen, bet you write good stories with it.'
 Nikonparrothead's gear list:Nikonparrothead's gear list
Panasonic Lumix DMC-TZ1 Canon PowerShot S95 Fujifilm FinePix X100 Nikon Coolpix A Panasonic Lumix DMC-LX100 +13 more
BigBarney Senior Member • Posts: 2,722
Tripod mounts
Yes indeed. The only really long lens I have come close to mounting on my G1 as a legacy lens is a Soligor 500mm mirror lens. This is considerably shorter and lighter than a solid glass long telephoto, but even this was supplied with its own tripod mounting collar. If you buy a long telephoto lens without the tripod collar the chances are you have not bought the complete package. I don't know of any vendor for an independent tripod collar. I believe the heaviest lens you can hang off the G1 without risk of distorting the lens mount is 1kg (approx 2.2 .lbs), but I cannot remember where I read that.
Kameraphil OP Regular Member • Posts: 445
I think the tripod bush on micro cameras (GF1, E-P1) seems weaker than those on traditional DSLRs (At least visually!). Adding to this, legacy lenses need a lens adapter to attach to these micro cameras, which makes them longer and heavier still (not to mention the possibility that you may want to add a teleconverter on top of all this to take photos of some flags on the moon!), which in turn makes the set up jitter or vibrate more easily (by wind or when you press the button). Don't you think this is the case? Don't you think that even a lens originally requires no tripod mount collar, in this new stuation it may now need one?
imagesmatter Regular Member • Posts: 266
BJN
BJN Veteran Member • Posts: 5,057
Here's a better link...Manfrotto 293
http://www.bhphotovideo.com/c/search?Ntt=manfrotto+lens+support&N=0&InitialSearch=yes
The other link shows collars and feet that fit specific lenses they're designed for.
I'm guessing the generic Manfrotto by Bogen Imaging 293 Telephoto Lens Support is more what the OP has in mind.
There's no generic collar that mounts directly to a lens that I'm aware of.
BJ Nicholls
SLC, UT
 BJN's gear list:BJN's gear list
Panasonic Lumix DMC-GM5
BJN
Ahem. You add an adapter that puts the lens just as far away from the sensor plane as it is in an Olympus DSLR. The real concern is that the plastic internal body of the MFT camera is less substantial than a cast metal body for both the lens mount and the tripod socket.
And it's not even about breaking the camera. Having a long lens cantilevered is a poor way to shoot on a tripod and much more prone to vibration and instability.
BJ Nicholls
SLC, UT
Godfrey Forum Pro • Posts: 29,011
Stick to buying long, heavy lenses that have their own tripod mounts or use a bean-bag system on the tripod head. I sold my Nikkor 180/2.8 because it was simply too awkward to use without a tripod mount, and none that I could find would fit it sensibly.
I can get the same focal length and quality by using the Pentax 135/3.5 on the Olympus EC14 teleconverter ... it's not as fast, but it's light and does not stress the camera's tripod mount.
Or I can simply use the Olympus ZD 50-200 which has a nice, rigid tripod mount.
Godfrey
http://godfreydigiorgi.posterous.com
sacundim Senior Member • Posts: 1,111
Not my experience with Minolta manual focus gear. There is a dire lack of tripod collars on some of those lenses. The ones I have that really need one:
  1. Panagor 90mm f/2.8 1:1 Macro — fairly heavy all-metal macro lens that extends a lot. 1:1 with this guy on a G1 is not fun.
  2. Minolta MD 70-210 f/4 — this lens is very long.
  3. Vivitar 200mm f/3.5 — borderline case
BJN wrote:
Ahem. You add an adapter that puts the lens just as far away from the sensor Ahh...you're right. I forgot about the adapters. It is just as far. But that was really the gist of my point...it's just as far, and the flanges on my l1 & my e-p1 are built to the same thicknesses.
Well, the lens mounts seem to be the same, as I said above. The tripod socket on the other hand...I wasn't thinking about them, and you're right on that count; they're not built nearly as as solidly. So, I stand corrected in that respect. I can definitely see a lens collar helping in relieving stresses on that component in a useful way.
Re: Here's a better link...Manfrotto 293
BJ Nicholls
SLC, UT
Thanks BJN, yes the Manfrotto 293 is the kind of device I need, and I've found a review of it which some of us may find useful: http://www.rahsoft.net/m293_bracket/index.htm
