Current Best Under US$500 22"-24" IPS or PVA Monitor
Started Jul 11, 2009 | Discussions
SantaFeBill
Senior MemberPosts: 2,293
Jul 11, 2009
Assuming there is such a thing ... . Now that the Dell 2209WA is history, at least for the moment, what's the next best one at a (semi-) reasonable price? ($xxxx.xx monitors are not an option for me.)
I went to the U.S. LG site and looked there, because a post I saw somewhere said some of theirs used IPS panels.
If that is so, I wasn't able to tell from the specs they publish - in fact, nothing about panel type at all.
P.S. - If it were a 4:3 aspect ratio rather than 16:9, I'd certainly consider a 19" or 20", again, if there is such a thing.
Howard Moftich
Veteran MemberPosts: 7,448
Re: Current Best Under US$500 22"-24" IPS or PVA Monitor
In reply to SantaFeBill, Jul 11, 2009
dell 2408wfp
Adam2
Veteran MemberPosts: 5,855
Yes, the Dell 2408wfp (nt)
In reply to Howard Moftich, Jul 11, 2009
$449 at the moment + tax.
SantaFeBill
Thanks to you both for the recommendation. Do you know the panel type? Neither the U.S. nor Canadian Dell sites gives this info in the monitor's specs.
Midnighter
Senior MemberPosts: 1,727
In reply to SantaFeBill, Jul 12, 2009
Not a fanboy of any brand but I am looking at buying similar quality/price to you.. by the looks of it anyway, found this so far in my search:
HP L2445w
(edit: woops... wrong monitor... its the L2475w I was looking at)
I love this Dell laptop I am typing on right now but sadly Dell does a lot of very heavy regionalisation... in fact some Dell monitors with identical model numbers have different feature sets here in Australia compared to overseas.
bubblzzz
Regular MemberPosts: 459
According to flatpanelshd.com it's an S-PVA panel.
DazeMae
Regular MemberPosts: 240
Any idea what's happened to the Dell 2209WA? As I recall, they weren't going to be delivered until some time in early August.
Howard Moftich
In reply to DazeMae, Jul 12, 2009
thats what Dell is saying, that they are suspending sales/pre-sales until inventory of the 2209WA can be replenished in mid-late August.
I think that's weird. They should simply say '4+ week leadtime' and let people pre-order it.
Mark Devine
Senior MemberPosts: 1,757
Another vote for Dell 2408FWP
In reply to Howard Moftich, Jul 12, 2009
I profile the monitor and printers with colormunki, and am very pleased with the result.
Best Regards,
Mark Devine
NewsyL
Veteran MemberPosts: 5,635
HP LP2275w
In reply to SantaFeBill, Jul 13, 2009
22" S-PVA wide gamut
Much discussed in the PC Talk forum.
Also, you may find the following for under $500USD; Dell was selling them.
NEC P221 S-PVA 10Bit Internal LUT, 96% AdobeRGB gamut
Prad.de did not like the P221 as much as the 2209WA or the 2275w.
http://www.prad.de/en/monitore/reviews.html
Adam2
Re: HP LP2275w
In reply to NewsyL, Jul 13, 2009
If I'm not mistaken the LP2275 is roughly 92% of CIE, compared to the larger gamut of the Dell, no?
NewsyL
Re: HP LP2275w
In reply to Adam2, Jul 13, 2009
Without looking it up, I'd say you are about right. The 2275w is a wider gamut than the Dell 2209WA but not as wide as the Dell 2408.
Now, wide gamut is appealing to some and not at all to others. Thought it was worth mentioning just because of that.
Oh heck... I had to peek at the PRAD.de reviews.
HP LP2275w
95% of sRGB
91% of AdobeRGB
83% of ECI-RGB 2.0
Dell 2209WA
99.5% of sRGB
"We only use a comparison with AdobeRGB and ECI-RGB 2.0 for models which have an extended colour space. This is not the case for the Dell 2209WA."
Dell 2408WFP
99% of sRGB
98% of AdobeRGB
93% of ECI-RGB 2.0
Joseph S Wisniewski
Forum ProPosts: 34,106Gear list
92% of CIE, beyond state-of-art...
In reply to Adam2, Jul 15, 2009
No.
You are indeed mistaken. Sharp has a monitor in the prototype stage based on a 5 color filter system that can exceed 90% of CIE. The most you can manage with a three filter system, even if the light source is three near monochromatic LED colors, is about 70% of CIE (I don't have the exact number on hand).
Many monitors manage a decent percentage of sRGB or ARGB, but those are only about 60-70% of CIE. (the "easy" 60-70%).
Rahon Klavanian 1912-2008.
Armenian genocide survivor, amazing cook, scrabble master, and loving grandmother. You will be missed.
Ciao! Joseph
http://www.swissarmyfork.com
 Joseph S Wisniewski's gear list:Joseph S Wisniewski's gear list
Nikon D3 Nikon D2X Nikon D90 Nikon D100 Canon EOS 5D Mark II +43 more
Scott Weierich
Senior MemberPosts: 2,100
Re: HP LP2275w
In reply to NewsyL, Jul 15, 2009
And the Dell 2408WFP is not as wide as the HP LP2475w. Among this and several other reasons I chose this HP display. According to this same site here are the color gamut ratings:
HP LP2475w
100% of sRGB
100% of AdobeRGB
95% of ECI-RGB 2.0
HP LP2275w
95% of sRGB
91% of AdobeRGB
83% of ECI-RGB 2.0
Dell 2209WA
99.5% of sRGB
Dell 2408WFP
99% of sRGB
98% of AdobeRGB
93% of ECI-RGB 2.0
Scott
Adam2
Re: 92% of CIE, beyond state-of-art...
In reply to Joseph S Wisniewski, Jul 15, 2009
Joseph S Wisniewski wrote:
No.
Please do educate because Dell claims that the 2408wfp is 110% of CIE 1976 whereas the HP is around 92%.
JortS29
Veteran MemberPosts: 3,781
The Samsung XL30 (or XL24) comes to mind, with 123% NTSC.
Joseph S Wisniewski
Color spaces 101...
No.
OK.
First, I believe you've misunderstood the numbers on the Dell site. No monitor maker quotes a percentage of CIE. The numbers would be too low. You're probably looking at an ICE number, an entirely different organization. Same three letters, different order. That's "television" space, even smaller than computer monitor space.
The CIE's numbers all go back to experiments to determine the entire range of colors that a human can see. This color space is plotted on something called the CIE chromaticity diagram, with which you're probably familiar.
http://en.wikipedia.org/wiki/Chromaticity
This picture may not link, you may have to click on it...
There are a number of different ways to mathematically translate that human visual space, CIE L*A*B, CIExyz, etc. but they all can be converted from one to another with no loss of information. The diagram forms a tongue shape. Any color that the eye can see can be plotted on that diagram (ignoring its lightness).
Do you see those numbers along the border of the tongue, ranging from 380 to 700? Those are pure spectral colors, monochromatic, like a laser. An LED is almost monochromatic, its colors end up very close to the edge of the diagram.
A single light source has a color represented by a point on that diagram. If you add a second light source, you've now got two points. Add those two colors in different ratios, and you move on a line between the two points.
Add a third colored light, and you've now got three points, in a triangle. These are referred to as "additive primaries". By mixing those lights in different ratios, you can make any color inside, or on the border of, a triangle that is inside the tongue.
Here's the sRGB color space.
http://en.wikipedia.org/wiki/SRGB_color_space
http://en.wikipedia.org/wiki/File:CIExy1931_sRGB.svg
It's a three primary color space, where the three primaries were chosen to be representative of an average computer monitor from the 1980s. It can represent any color those monitors can produce, and nothing more.
Note that I had the numbers wrong, earlier. That tiny sRGB triangle only encompasses about 30% of CIE, all the colors that the eye can see. It's primaries, to use the technical term, "suck". They come nowhere near the edges of the tongue.
Adobe RGB covers 50.6% of CIE. It uses three primaries, but they're "better" than the sRGB primaries. Blue is very important in the printing industry, so Adobe RGB uses a "perfect" blue, on the tongue itself. The red and green primaries are "closer to the tongue" (that was not a song by "Rush").
http://en.wikipedia.org/wiki/Adobe_RGB_color_space
And here's a confusing article, with a diagram I really like.
http://en.wikipedia.org/wiki/Color_space
It shows the triangles of three color spaces, sRGB, Adobe RGB, and ProPhoto. It also shows a real printer space, an Epson 2200 on matte paper. You will notice that the real printer gamut is a strange, melted, blobby triangle that actually exceeds both the sRGB and Adobe RGB triangles.
The biggest triangle is ProPhoto, an interesting color space, literally obsolete the day it was created, and quite problematic. In an attempt to push the three primary model to its limit, ProPhoto "cheats": it uses two "imaginary" primaries. The ProPhoto red can actually be made with an LED or a laser, but the green and blue involve negative quantities of light. This means that simple color transforms in ProPhoto space, like a hue adjustment, can lead to colors that are not valid CIE colors and cannot be viewed or printed by any known device. The worse problem is that once translated to an illegal color, any tool that uses CIE colors internally for its math can't deal with the illegal ProPhoto colors and falls apart.
The very best you can do, positioning three real, pure (laser or LED) primaries on the tongue is a triangle within the tongue, and therefore, some real colors are outside the triangle. That's why we're just beginning to see a movement towards displays with four or more primaries. Place four, five, or six points on (or even very near) the tongue, and you get a larger gamut than ProPhoto, but it stays "real", so you don't have to worry about having colors go "unreal" or "impossible" on you.
wizfaq
Ciao! Joseph
SantaFeBill
Re: Color spaces 101...
From the 2408WFP specs on the Dell U.S. site:
"2408WFP Color Gamut (Typical) is based on CIE1976 (110%) and CIE1931 (102%)."
Mark McCormick
Contributing MemberPosts: 921
In reply to SantaFeBill, Jul 15, 2009
Yikes, it's marketing misspeak or some clever new way of comparing transmissive color potential to CIELAB reflective color. The CIELAB color model refers to human colors that can be observed in reflected light situations. Since monitors are transmissive devices, some license is taken to correlate monitor "whitepoint" to 100% reflection off a neutral white reflective object (i.e. a perfectly reflecting white surface) and set this value to RGB = 255,255,255. Now, if the display panel were so bright that one could drive the liquid crystal filters to say 50% transmission yet still have a monitor that looks "white" at say, RGB 128,128,128 then you'd have headroom for self-luminous colors that go beyond LAB reflected colorspace. But you'd need a whole new RGB display standard to encompass self-luminous objects in a scene, and a score over 100% on such a scale would still not guarantee that you aren't missing color gamut for some reflected light colors. All in all, it really doesn't make much sense to promote such a standard at this time in digital imaging, so my guess is that the marketing guys misquoted the engineers. The engineers were probably referring to comparison of monitor color gamut to NTSC colorspace, or sRGB, aRGB, etc. but not CIEXYZ or CIELAB models.
Mark McCormick
http://www.aardenburg-imaging.com
NewsyL
Thanks Joseph!
I had assumed the CIE and ICE had been a dyslexic error as I often see with S-IPS and S-ISP monitor panel inquiries.
You've provided a very lucent explanation. That is indeed a great diagram. Bookmarked.
