Deleting unused Canon software programs--please advise
Started Jul 3, 2009 | Discussions
Idoc82 Regular Member • Posts: 280
Hi,
I have a 30D and a 300D (original Rebel). I'm trying to free up some disc space on my computer. I have a bunch of Canon programs, some of which came on the discs with the cameras, and some of which I think were downloaded when ZoomBrowser and DPP were updated online.
I use ZoomBrowser and DPP all the time, but am not sure if I've ever used these other programs. In fact, I don't even know what most of them are. I would appreciate it if anyone could make a brief comment about what any or all of these programs are for, and whether I can safely uninstall them without interfering with the operation of ZoomBroswer and DPP.
Here are the programs in question:
Canon MovieEdit Task for ZoomBrowser EX
--Canon ZoomBrowser EX Memory Card Utility
--Canon Utilities CameraWindow
--Canon Utilities CameraWindow DC
--Canon Utilities CameraWindow DC_DV6 for ZoomBrowser EX
--Canon Utilities MyCamera
--Canon Utilities MyCamera DC
--Canon Camera Access Library
--Canon Camera Support Core Library
Thank you very much, Jim.
RLH1861 Senior Member • Posts: 1,828
similar question
I had the 300D and upgraded to the 20D. the software for those era models was apparently the same except for camera driver itself. But they had the same version of zoombroswer and DPP.
Now I bought the 40D and have to load the software. Does anyone know if I have to uninstall the older stuff first
OR will it automatically overwrite???
RLH
MisterPootieCat
MisterPootieCat Veteran Member • Posts: 3,121
Does this help?
Idoc82 wrote:
Hi,
This allows editing video, if you don't have a video capable camera this could probably be safely removed.
This allows ZB to see and download pictures from your memory cards. ZB will not allow direct viewing of pictures while they are on memory cards attached to your system. If you use a card reader this could be removed but you will need to download the images using desktop applications (File Explorer). DPP can directly access memory cards, ZB forces you to download to a folder on your disk drive first. I always thought this was retarded.
This is used with P&S cameras and serves basically the same function as the EOS Utility. This provides support for remote tethered shooting. If you don't have any Canon P&S cameras this could be removed.
I'm not sure what this is but I'm guessing it's a plug-in for the CameraWindow utility above.
Another plug-in for CameraWindow?
This allows installing custom sounds and backgrounds on P&S cameras. I'm pretty sure EOS cameras have no use for this. I have a couple PowerShots and use this to modify the shutter sound among other things.
This is part of the MyCamera utility and can probably be removed.
Not sure what this does.
Not sure what this does either.
Keep in mind most of the items you list here are part of the ZB installation and might render ZB unstable if removed. In the worst case scenario you would simply remove all the Canon software and re-install from scratch. I've removed the Canon software several times on various systems with no problems.
And your welcome!
 MisterPootieCat's gear list:MisterPootieCat's gear list
Canon EOS 40D Canon EOS 300D Canon EOS 7D Canon EOS 80D Canon EF 50mm f/1.4 USM +22 more
MisterBG Veteran Member • Posts: 5,823
Re: Unused Canon software
Are you desperately short of hard drive space?
I have several Canon cameras, compact and SLR, and I've also managed to accumulate a similar list of Canon utility programs (plus a few more). I've never installed any of those files you mention intentionally, they have all been as a result of installing either Zoombrowser or DPP.
My attitude is, if they are not doing any harm, why remove them? Deleting programs at random without fully knowing what they do seems a little risky, even if they don't directly appear to relate with programs that you are using.
By choice, I always use Zoombrowser to download image files from all of my cameras (via a card reader, not direct), and I like to have DPP available for things like lens correction, although it's not my preferred RAW editor. I always keep up to date on Canon software, and Zoombrowser is currently at 6.3.1. and DPP is at 3.6. You can update any version on Canon software from their support web sites, but you need to have an earlier version already installed in order to perform the update. (There is a "fix" to install an update without having the original program resident, but that's another story). Most of those programs don't take up very much disk space, so you must ask yourself if the benefit is worth the risk of deletion.
Your situation may be different, but disk drives are cheap so I don't worry about a few surplus programs on my hard drive, and who knows, you may need to use them at some time in the future.
To Err is Human, To really foul things up you need a computer.
MisterPootieCat
Not me.
I'm just providing information about the programs in question. I'm assuming you really wanted to reply to the OP and ended up replying to my post by mistake?
As I said, removing various applications tied to ZB could result in instability or complete malfunction. No worries though, reloading the software from scratch is easy.
Re: Not me.
My reply was directed at the OP. Sorry for any confusion.
delete Regular Member • Posts: 283
Re: Deleting unused Canon software programs--please advise
Hello,
I have only DPP and EOS utility installed, nothing else, works perfectly fine. But then, I never used ZB.
Some of my Photographs: http://photo.net/photos/various%20things
draposo Forum Member • Posts: 54
MrPootiecat gave a nice thorough explanation of all the programs. If you want to delete them, go ahead and don't worry about it. You can get most of them back from the canon website. However, I don't think any of them will free up that much space. DPP and ZB are probably the biggest two apps.
If it is space you are trying to get back you should run a disk cleanup utility and defrag your hard drive. (assuming this needs to be done) ... This will help you get rid of a lot of unwanted temporary files.
Here is a link with an explanation on how to run the cleanup utility of you are running XP.
http://www.theeldergeek.com/disk_cleanup_utility.htm
Here is the usa link to current versions of the canon software. You just need to answer the three questions in the drop-down box.
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Good luck
Idoc82 OP Regular Member • Posts: 280
Thank you very much for the helpful replies.
Jim
Wayndom Senior Member • Posts: 1,931
Re: Does this help?
My own experience indicates this is wrong -- CameraWindow is the program that loads your pictures from your camera to your computer. I messed with mine once, and had to re-install the software before I could download pics into my 'puter. A big pain in the rear...
I have to agree with the poster who asked if you're desperately short of disc space, and add that hard-disc memory is incredibly cheap these days. You can pick up a one terabyte HD for around 100 USD -- that's a TRILLION bytes, for considerably less than the cheapest lens on the market.
delete wrote:
Hello,
As long as we're here (and my question doesn't merit a separate thread), does anyone know why ZB displays at "100%" about half the size as DPP or PS?
What up with that?
MisterPootieCat
Does this help?
Here's what the CameraWindow looks like when I connect my PowerShot. Downloading images is one option available, remote shooting is another one.
I think the easiest way to free up space would be to remove ZoomBrowser and all of the plug-ins it uses. Personally, I think DPP is better for editing images anyway.
MisterPootieCat
There are three buttons used for setting image display size. Full Screen, 100%, and Fit to Window. Is it possible you're using Full Screen or Fit to Window instead of 100%?
Wayndom wrote:
delete wrote:
Hello,
What up with that?
Colossus Regular Member • Posts: 327
Idoc82 wrote:
Hi,
How many forums do you need to ask this on?
Just two--the 30D forum and the 300D forum, since I have both and wasn't sure if the software was the same for both. Again, with the exception of the post above, I do appreciate the advice.
Jim.
