Will firmware upgrade erase my 5d2 settings such as AF Microadjustment?
Started Jan 19, 2009 | Discussions
Igor Yatsenko New Member • Posts: 5
took a quick look through manual and upgrade procedure, did not find this mentioned. I would expect user settings to be erased, if that is correct, is there a way to back them up and restore after the upgrade using the software that came with the camera? I didn't bother installing any of that yet - just got the camera few days ago.
RicksAstro
RicksAstro Veteran Member • Posts: 3,543
no...
The user settings are retained.
Rick Krejci
http://www.ricksastro.com
Igor Yatsenko OP New Member • Posts: 5
thanks, tried EOS utility - no cfg backup there, will update as-is (nt)
no text
Bartek Senior Member • Posts: 1,408
Re: Will firmware upgrade erase my 5d2 settings such as AF Microadjustment?
not sure about 5DII however with 1D mark III series the AF microadjustment has not been affected by firmware changes as well as "camera reset" settings.
Also removing both batteries didn't clear them and actually the only way I know to reset MA setting is manual change into some other value including "0".
Bartek
 Bartek's gear list:Bartek's gear list
Canon EOS-1Ds Mark III Canon EOS 5D Mark III
