What is the Largest aperture lens in the world?
Started Jan 19, 2009 | Discussions
fastap Regular Member • Posts: 132
What is the Largest aperture lens in the world? would it be possible to convert it to EOS mount?
voodoo1694 Regular Member • Posts: 145
Re: What is the Largest aperture lens in the world?
Correct me if I'm wrong, but I believe it's the Leica Noctilux-M 50mm f/0.95 ASPH lens
CanonKen Senior Member • Posts: 2,878
I win (I think)...
 CanonKen's gear list:CanonKen's gear list
Canon PowerShot S95 Canon EOS 6D Canon EF 35mm F2 IS USM
pikeface Contributing Member • Posts: 532
Physically
it could be these
Have a look and leave a message
http://www.pbase.com/jeremy_broome_smith
tkbslc Forum Pro • Posts: 13,558
Re: Physically
Canon made a 50mm F1.0L
http://www.flickr.com/photos/mrbokeh/3038998368/in/pool-43936001@N00
There was a post recently about an FD mount Canon 50mm 0.95, but you'd have to use a conversion adapter and lose .5 stop of light (or infinity focus). Then the 50mm 1.0 wins.
Photo_AK
Photo_AK Senior Member • Posts: 1,166
Here Bjørn Rørslett writes about 50/0.75, 75/1.1, 85/1 ... fast lenses:
http://www.naturfotograf.com/index2_PC.html
Robert Capa said 'you can never get close enough'. Well, he did.... He also often visited my daily photoblog at http://logatec.blogspot.com/
 Photo_AK's gear list:Photo_AK's gear list
Leica Q Nikon D850 Nikon AF-S Nikkor 14-24mm f/2.8G ED Nikon AF-S Nikkor 58mm f/1.4G Nikon AF-S Nikkor 20mm f/1.8G ED +7 more
Andrew dB Contributing Member • Posts: 970
Stepper lenses
Probably any number of specialist repro lenses built for making microchips and used in so-called 'steppers', which can be as fast as f/0.53 (0.95 NA) and cost millions of dollars each.
They are designed for focusing specific wavelenghts of UV light produced by lasers and they wouldn't be the kind of thing you could fit to an EOS camera even if you wanted to. These days the cutting edge is moving over to mirror rather than lens optics but they wouldn't work on EOS either.
OP fastap Regular Member • Posts: 132
Re: Stepper lenses
What do you mean moving to mirror rather then lens optics?...a cheaper way around making good optics or?
Chris59 Forum Pro • Posts: 15,437
Keck I and Keck II, 10 METRES acoss - each!
Look them up in Google.
 Chris59's gear list:Chris59's gear list
Samsung NX1 Samsung 16-50mm F2.0-2.8
Re: Stepper lenses
From reading the linked article ( http://www.asml.com/immersion/eng/source/lens_images_fall05.pdf ) it looks like the main benefits at the moment are:
smaller optics
less dependant on material quality than transmission optics
less vulnerable to misalignment
mirrors can be cooled on their rear surfaces making it easier to avoid heating effects than with lenses.
Additionally, as you get to shorter wavelengths of light, it becomes harder to use transmission optics to achive focussing. Nearing Extreme UV or X-ray wavelengths, mirrors become the only option.
maiaibing Veteran Member • Posts: 5,008
List of several of the fastest "standard" photo lenses
 maiaibing's gear list:maiaibing's gear list
Canon EOS 5DS R Canon EF 70-200mm F2.8L IS II USM Canon EF 300mm f/2.8L IS II USM Canon Extender EF 1.4x III Canon Extender EF 2x III +5 more
(unknown member) Forum Pro • Posts: 13,144
Cool, it's already an EOS mount lens
