PENTAX M 1:2.8 28MM vs. PENTAX M 1:3.5 28mm
Started Dec 14, 2008 | Discussions
dyusem
dyusem Regular Member • Posts: 310
I want to purchase one of these two lens and was wondering if anyone has any personal experience and can make a recommendation?
Thanks,
David
 dyusem's gear list:dyusem's gear list
Fujifilm FinePix F31fd Panasonic Lumix DMC-LX5 Olympus Tough TG-2 Pentax K10D Pentax K-5 +24 more
Lars Holte
Lars Holte Senior Member • Posts: 1,176
Re: PENTAX M 1:2.8 28MM vs. PENTAX M 1:3.5 28mm
Thanks,
David
The F3.5 is considered to be the bett of the two. I have both, and I thinks so too - very sharp!
Lars
 Lars Holte's gear list:Lars Holte's gear list
Pentax K-5 Pentax smc FA 50mm F1.4 Sigma 10-20mm F4-5.6 EX DC HSM Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA* 50-135mm F2.8 ED (IF) SDM +4 more
DougOB
DougOB Regular Member • Posts: 245
My experience
About 4 years ago I was debating between these two lenses. My research of common opinion indicated that the f3.5 was sharper than than the f2.8 and had better contrast. So I bought it. I was happy with the lens and had no complaints, but when I later bought a FA 31 Ltd it became redundant so I sold it.
As I recall there are two versions of the M 28/f2.8 with different reputations.
Doug
Thanks,
David
 DougOB's gear list:DougOB's gear list
Pentax K-01 Pentax K-3 Pentax Q-S1 Pentax smc DA 15mm F4 ED AL Limited Pentax smc FA 50mm F1.4 +15 more
stratokaster Forum Member • Posts: 56
I didn't have a chance to play with 28/2.8, but 28/3.5 is an incredible lens with outstanding sharpness and contrast.
All the best, Pavel
Hipity Regular Member • Posts: 337
K28/3.5 better yet
brandrx Forum Pro • Posts: 28,337
I agree with Hipity...
Hipity wrote:
K28/3.5 better yet
IMO the K28/3.5 is one of the very best ever made.
Cheers.
'Keep your eyes looking forward. However, glance back now and then to see where you've come from. It will put a smile on your face.' ~ brandrx
http://en.wikipedia.org/wiki/Carbon_County,_Utah
Ron ~ Retired.
Ivan Glisin
Ivan Glisin Contributing Member • Posts: 724
I owned M28/2.8, then A28/2.8 and sold both. Not bad lenses at all but with strong back light both are prone to flare and producing low contrast. Also, at f/2.8 corners are a bit soft and vignetting is noticeable (but not bad).
I have M28/3.5 now and it's here to stay: better than M28/2.8 in terms of flare resistance, contrast, color rendering, and corner to corner sharpness, but at the expense of loosing 1/2 steps which is acceptable to me.
So get one, you won't regret.
Roland Mabo Forum Pro • Posts: 12,462
It exist two versions of the M 28 f/2.8, the Mk II was sharper than Mk I.
What I like about them is that they have a warmish tone to the images. I have also owned the FA 28 f/2.8, which in many ways was a better lens - technically speaking - but I liked the images from M 28 f/2.8 more... It simply had flair. (no, not flare Flare was never a problem).
viking79
viking79 Forum Pro • Posts: 14,137
The K version is better corrected than the other 28mm lenses for chromatic aberrations and the like. I don't think it is any sharper in every day situations, but it certainly is an outstanding lens.
See my Flickr Photostream: http://www.flickr.com/photos/28177041@N03/
See my PPG Shots: http://www.pentaxphotogallery.com/erictastad
See my Blog/Page: http://web.me.com/atastad/viking79/Welcome.html
Sony Alpha 7R Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
Lens resolution tests....
Lens resolution tests (28mm) made by Yoshihiko Takinami.
http://www.takinami.com/yoshihiko/photo/lens_test/pentax_28-30.html
Cheers.
Ron ~ Retired.
jthommo Veteran Member • Posts: 3,735
I have the super-tak 28/3.5
and it is simply superb. No other word for it.
Thommo
http://www.flickr.com/photos/jthommo101/
Just1moreDave Regular Member • Posts: 421
Re: My experience
reputations.
The first version is much more common. The second version is optically identical to the Pentax-A and Pentax-F, and has some physical features of the A lenses. (It won't work like an A lens, though.) The easy way to spot a Pentax-M version II is the serial number is not on the front of the lens; it's stamped near the aperture ring. It will say only this around the front element:
smc PENTAX-M 1:2.8 28mm ASAHI OPT. CO., JAPAN
moving_comfort
moving_comfort Veteran Member • Posts: 8,203
Here are some examples from my M 28 f/2.8:
 moving_comfort's gear list:moving_comfort's gear list
Pentax K20D Nikon D800 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF Nikkor 20mm f/2.8D +10 more
Is this the sort of bokeh you usually get from this lens in the dreaded branches in background situation?
Thommo
dyusem
dyusem OP Regular Member • Posts: 310
Thanks to everyone...
...for the feedback. I have been looking for a K 28mm/3.5 with no success so it looks like I will jump on the M 28mm/3.5.
Cheers
moving_comfort
Thommo
Yes - the bokeh isn't what you'd call 'dreamy' in that situation.
But I like it - I love seeing different types of bokeh. Each lens has it's flavor.
I loved my M 28 f/2.8 - sold it because I have the Vivitar (Komine) 28 2.8 Close Focus, and a mes of 35's.
Ivan Glisin
Mk I.
According to Bojidar's site M 28/2.8 Mk II is the same optically as A and F 28/2.8 so technically I owned both (since I had M Mk I and A which is the same as M Mk II) and Mk II optics was indeed sharper to my eyes. Here is the story:
http://kmp.bdimitrov.de/lenses/primes/wide-angle/M28f2.8-ii.html
Marc Sabatella Veteran Member • Posts: 6,679
jthommo wrote:
[ regarding the M28/2.8 ]
I think so; not that different from the f/3.5 version, based on shots I've seen.
