Chuck Westfall's microadjustment tips.
Started Dec 11, 2008 | Discussions
J A K
Forum ProPosts: 15,833
Dec 11, 2008
Below is CW's answer to the following "how to" question for the 1DmkIII; his comments/suggestions should be applicable to all models that support MA.
What is the best way to use the Micro Focus Adjustment on the Mark III?
The question is simple enough, but the answer really depends on the lenses you're using and the way you use them. To begin with, it should be clarified that there are two types of in-camera AF microadjustment for the EOS-1Ds Mark III and EOS-1D Mark III cameras: the first adjusts the point of focus equally for all Canon EF lenses, whereas the second adjusts the point of focus for up to 20 individual lens types, at one adjustment per lens. In both cases, the point of focus can be adjusted up to + - 20 steps in 1-step increments. Also in both cases, any adjustments you make apply only to the specific camera body in question; lenses themselves are never modified by the camera's AF microadjustment settings. The amount of focus adjustment per step is proportional to the maximum aperture of the lens, with the goal being to increase the precision of the adjustment with large aperture lenses since they have a smaller depth of focus. With all that as a preamble, here is an unofficial procedure for selecting and using an AF microadjustment setting:
Mount the camera to a sturdy tripod.
Position a reference target for the camera to focus on. The reference target should have sufficient contrast for the AF system to read, should be flat and parallel to the camera's focal plane, and should be centered with respect to the picture area.
Lighting should be bright and even.
Camera-to-subject distance should be no less than 50 times the focal length of the lens. For a 50mm lens, that would be at least 2.5 meters, or approximately 8.2 feet.
Set the lens for AF and the camera for One-Shot AF, and manually select the center focusing point.
Shoot at the maximum aperture of the lens via manual mode or aperture-priority AE, and adjust the exposure level if necessary to achieve an accurate exposure of the reference target. Use a low ISO setting to reduce noise.
If the lens has an image stabilizer, shut it off.
Use a remote switch and/or the camera's self-timer to release the shutter. Use mirror lock as well.
Take three sets of images at microadjustment settings of -5, 0 and +5, i.e, three consecutive images at -5, three consecutive images at 0, and three consecutive images at +5.
Examine the resulting images on your computer monitor at 100% pixel magnification.
Take additional sets of test images at different microadjustment settings if necessary until the sharpest image is achieved.
Register the corresponding microadjustment settings in the camera.
Here are a few additional precautions to observe:
• Do not attempt to autofocus on an angled chart, because doing so will degrade the consistency of the camera's focusing measurement. Keep in mind that the camera's AF sensor is comprised of multiple pairs of linear pixel arrays. If you attempt to autofocus on a single line in an angled focusing chart, only a few pixels from each active pixel array will "see" the target. Ideally, the contrast in the reference target should cover the entire area of the camera's center focusing point, and the reference target should be perfectly parallel to the camera's focal plane.
• For best results, manually set the focus on the lens to infinity for every exposure before allowing the camera to autofocus the reference target.
• Expect some minor variations in focusing accuracy within each set of three test images, even though they were all taken at the same microadjustment setting. This is completely normal, and is due to the tolerances of the camera's AF system.
• Expect smaller microadjustment settings to have a greater effect with telephoto lenses, and vice versa for wide-angle lenses.
• If you are attempting to set microadjustments for a zoom lens, it is important to realize that the camera's setting may only be accurate for the focal length setting you test. The instruction book suggests testing at the longest focal length of the lens, but you may find it more efficient to choose the focal length you use most often.
• Some EOS cameras and some EF zoom lenses may require more sophisticated calibration than the in-camera AF microadjustment settings can provide. In such cases, it may be necessary to have calibrations performed at a Canon Factory Service Center.
• Last but not least, there is no "official" Canon method for setting AF microadjustments, so this procedure is unofficial. If you think you can do better, then by all means, go for it. Towards that end, be advised that some independently made tools are designed to help you set AF microadjustments accurately. One of these is the LensAlign kit, due out soon from RawWorkflow.com:
Joe Kurkjian
Galleries: http://www.pbase.com/jkurkjia
SEARCHING FOR A BETTER SELF PORTRAIT
Vladyslav Kosulin
Senior MemberPosts: 1,760
tag (nt)
In reply to J A K, Dec 11, 2008
nt=no text.
Vlad
Benedict Slotte
Senior MemberPosts: 1,165
My method...
I find it better to take more, i.e. -20, -15, -10, -5, 0, 5, 10, ... That gets me to the correct result much faster, at least if the correct adjustment happens to be outside the + - 5 range.
I have also found that focusing on a more "realistic" (but still plane) target is much better. Suggestion: use a flat print of an image that has much detail and contrast in it (and does NOT have repetitive patterns).
reference target.
I go a step further and alternately set it to infinity and to minimum focusing distance. I don't know if that makes any difference, though.
I would suggest to use the geometric mean of the minimum and maximum focal length. So, for the 100-400 mm lens, that is sqrt(100*400) = 200 mm.
Interesting. Maybe I should try my local service center after all. They are just a 15-minute walk from my home
B. Slotte
Turku, Finland
http://bslotte.smugmug.com
JordanS
Contributing MemberPosts: 534
Re: Chuck Westfall's microadjustment tips.
All excellent tips for utilizing MA. My method is to use an old license plate set about 18ft away as the target in the yard. With the target set-up a tape measure is placed at a 45 degree angle to the target extending 2ft to the rear and 2ft to the front of the plate. The resulting image clearly shows exact focus on the tape measure lines. I then set my best focus DOF to show 1/3 in front and 2/3 behind the target.
This method is very quick to detect if MA is even needed and gives latitude to set the midpoint of DOF for the shooter. This was with a 70 200 with a tc attached and different focal length lens will require a change to target distance.
Jordan
stuart melnikoff
Regular MemberPosts: 269
In reply to JordanS, Dec 11, 2008
http://focustestchart.com/chart.html
very interesting methodology - this also seems like a worthy method but it suggests setting the target at an angle. YMMV
WalterSrChat
Senior MemberPosts: 1,075Gear list
Good Reference.
Thanks JAK
that support MA.
III?
magnification.
reference target.
Joe Kurkjian
I am out to take the perfect picture, if it exits!
 WalterSrChat's gear list:WalterSrChat's gear list
Canon EOS 20D Canon EOS-1Ds Mark III Canon EOS-1D X Canon EF 8-15mm f/4L Fisheye USM Canon EF 24-70mm f/2.8L II USM +3 more
Duane DeSieno
Regular MemberPosts: 483
For me I think the important point is the 50X the focal length.
I had been fighting with my 50mm 1.4.
Close up the micro-adjust was coming out -17.
When I move 8ft away, I would get -10.
That's probably the better setting.
Also I found I can get away with not taking pictures till I'm pretty close.
Use QuickMode in LiveView and just AF-ON.
Then look at 10X in LiveView and see if the focus looks good for your favorite f stop
by using the DOF preview.
BTW all my lenses are in the the minus category. Does that mean I need to get the camera adjusted?
Duane
click click
Regular MemberPosts: 461
tag
tag this message for myself
smatty
Senior MemberPosts: 1,798Gear list
tag (nt) Thank you for sharing
 smatty's gear list:smatty's gear list
Canon PowerShot S95 Fujifilm FinePix X100 Fujifilm X10 Fujifilm X100S Canon EOS 5D +16 more
Shamus1
Senior MemberPosts: 1,596Gear list
Re: tag (nt) Thank you for sharing re microfocus adj
In reply to smatty, Dec 11, 2008
Methods are appreciated, will try....
 Shamus1's gear list:Shamus1's gear list
Canon EOS-1D Mark IV Canon EOS 5D Mark III Canon EOS 7D Canon EOS-1D Mark III Adobe Photoshop CS6 +2 more
J A K
I agree regarding using the geometric mean for zooms.
In reply to Benedict Slotte, Dec 11, 2008
Bottom line, I'm not a fan of MA; AFAIC, if you need it either your lens or body should go back to Canon for calibration (i.e. make them do the job they should have done properly in the first place).
Joe Kurkjian
hhski
Senior MemberPosts: 1,295
In reply to J A K, Dec 12, 2008
I use 3 pasta boxes the nutritional labels have heavy dark lines and the af grabs well on thisI go closer than 50x the focal length and I stagger the boxes to give me a feel if I am front or back focusing. I also notice that sometimes it is difficult to differentiate the level of sharpness but the really sharp one has the most contrast and color accuracy and saturation.The saturation is why I went to M mode to keep exposure equal.
OleThorsen
Senior MemberPosts: 2,758Gear list
I prefer to measure the DOF placement
Thanks for sharing Joe.
Even though I use a D300, I believe the considerations should be pretty equal, since the AF adjustment has the same + -20 range. I agree about the AF target should be parallel to the sensor plane, but instead of just focusing on a flat target, I combine a flat target with a ruler placed at a 45 degree angle to the AF target, making it possible to measure the DOF placement. Here is how I adjusted my 80-400 lens, choosing the focal length and focus distance I use most for small birds.
And here is the 100% crops with the DOF placement indicated.
I ended up with a value of -8.
Regards
Ole Thorsen
http://www.pbase.com/ole_thorsen
  • OMNISCIENCE
Knowing what
thou knowest not
is in a sense
omniscience.
(Grook by Piet Hein)
 OleThorsen's gear list:OleThorsen's gear list
Nikon D300 Nikon D200 Nikon D70 Nikon 1 V1 Nikon AF-S Teleconverter TC-14E II +21 more
J A K
Ole, your approach is a good one!
In reply to OleThorsen, Dec 12, 2008
I do almost exactly the same thing as you (i.e. get a measurement of the DOF error). Below is an example (with an enlargement of the measurement area embedded) of my 70-200 f/4 IS and 50D; note, 18 inches is aligned with the target. This is pretty much how my gear performs without any MA (I'm not a fan of MA because it isn't clear to me if the majority of AF errors are a simple offset or an offset with slope dependent on object distance).
More of what my setup looks like can be seen here. Note, I change target designs frequently to probe any weakness (false AF locks) in the camera's AF system.
http://www.pbase.com/jkurkjia/canon_30d
Also, FWIW I agree the near and far DOF limits are very symmetrical about perfect focus. Oh, another FWIW, I usually "test" for AF accuracy at a object to sensor distance of 12.2 times the focal length; this give me a magnification around -1/10 for all of the tested lenses.
Joe Kurkjian
Robert Sheldon
Senior MemberPosts: 2,017
Re: Ole, your approach is a good one!
tested lenses.
Joe Kurkjian
Joe,
Only an engineer would use 12.2. Ordinary slobs would use 12 or more likely 10 or 15.
Bob Sheldon
Photo Gallery at
http://www.bobsheldon.com
Sunghwa Jin
Regular MemberPosts: 103
tag (nt)
nt means no text.
NumberOne
Senior MemberPosts: 1,444Gear list
(NT) Thank you very much for posting - Chuck Westfall's microadjustment tips.
Best regards,
Pedro
Eric Hoffman
Regular MemberPosts: 278
Tag
In reply to NumberOne, Dec 12, 2008
Eric
kipryan
Forum MemberPosts: 70
Re: Tag
In reply to Eric Hoffman, Dec 12, 2008
Bookmarked
jrsforums
Contributing MemberPosts: 656
Another approach
I have not tried it...yet (waiting for 5D2)
http://www.northlight-images.co.uk/article_pages/cameras/1ds3_af_micoadjustment.html
But this seems like a good method...
John
