SB-900 Firmware update...
Started Nov 4, 2008 | Discussions
Grig
Senior MemberPosts: 2,088Gear list
Nov 4, 2008
I've got my second SB-900 today and owner of the store said that he talked to Nikon rep and she said that this firmware is released and fixes that stupid temperature cut-off problem (although I turned this feature off).
Did you hear anything about it or tried this update? I can't find it online somehow... ;o(
Real photography - it's just the ability to see what was already created by God!
http://www.pbase.com/grig
 Grig's gear list:Grig's gear list
Panasonic Lumix DMC-ZS3 Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-LX100 Nikon D3S Nikon D800E +13 more
SaltLakeGuy
Forum ProPosts: 10,918Gear list
No such animal
In reply to Grig, Nov 4, 2008
as it can be defeated via it's already existing menu settings.
 SaltLakeGuy's gear list:SaltLakeGuy's gear list
Sony Alpha 7R II Sony FE 35mm F2.8 Sony FE 55mm F1.8 Sony FE 70-200 F4 Sony FE 24-240mm F3.5-6.3 OSS +1 more
Grig
Grig OP
Re: No such animal
In reply to SaltLakeGuy, Nov 4, 2008
That's exactly what I did - just turned it off, but he (owner) said that "Nikon was to conservative on the temperature level and this update should fix this issue for good..."
I guess - let's wait...
RJSPhotography
Senior MemberPosts: 1,680Gear list
Re: No such animal
noted
 RJSPhotography's gear list:RJSPhotography's gear list
Adobe Photoshop CS6
Paul.R.Lindqvist
Veteran MemberPosts: 4,407
Re: No such animal
In reply to SaltLakeGuy, Nov 18, 2008
Do a search and you find more then one person having the sb-900 shutting down with overheating shutdown turned off..
The overheating issue is not mentioned in the changes in the firmware....
Regards
Paul L.
Doug Pitts
Senior MemberPosts: 2,089
Re: SB-900 Firmware update...
In reply to dilgit, Nov 18, 2008
....I had a friend turn off the "cut off" function (after it had locked up at a wedding), and later it still locked up. A firmware upgrade would be welcome concerning this...but show me first.
dilgit
Regular MemberPosts: 176
Re: Its available
In reply to Paul.R.Lindqvist, Nov 18, 2008
Thanks Paul!! I've just downloaded and installed on both my SB900 speedlights. Heres what Nikon says about the upgrade:
The following improvements have been made in version 5.02
  • With uninterrupted shooting with the SB-900 set to i-TTL mode, images captured just before the flash ceased firing were sometimes overexposed. This issue has been resolved. By resolving this issue, metering precision has been further increased and the number of times the flash fires has also been increased. When the SB-900, set to TTL auto flash mode, is used with a camera supporting the Nikon Creative Lighting System (CLS), flash mode automatically changes to A mode according to camera communication status. That flash mode was previously maintained, but it has been modified so that TTL auto flash mode is restored once the SB-900 again recognizes the camera as a CLS-compatible camera.
NikonRumorsAdmin
Regular MemberPosts: 147
In reply to Grig, Nov 18, 2008
The firmware is available on all Nikon Europe sites - try Nikon UK
[NR]
where there's smoke there's fire
Grig
Grig OP
Re: Its available
In reply to dilgit, Nov 19, 2008
Perfect!!! This was bothering me more than overheat shut off (that can be disabled)! Great news!!!
