Exposure proof - please (img)
Started Oct 15, 2008 | Discussions
Timskis6 Veteran Member • Posts: 9,562
How does the exposure look on your monitor? I thought my monitor was properly calibrated, however after sending it in to Costco the resultant print seems about 1/2EV darker than on my monitor. If you've got a calibrated monitor, I'd like to hear your input.
Forgot to mention I didn't use the ICC profiles for the specific printers (I never figured out how).
Tim
'Be the change you wish to see in the world.' -Mahatma Gandhi
E3/E410/7-14/12-60/50-200/50/EC-14/C8080
http://www.flickr.com/photos/timskis6/
Joesiv Veteran Member • Posts: 5,497
Re: Exposure proof - please (img)
It's probably preference, but I'd push up the exposure to get the whites to near clipping, and pull down the shadows as well so that the surfers "black" suit is darker. You don't need to bury the shadows, but it looks a bit flat (And I'm one that likes lower contrast shots).
Cloverdale, B.C., Canada
Olympus e-510 L1
http://joesiv.smugmug.com
 Joesiv's gear list:Joesiv's gear list
Nikon D700 Olympus E-510 Nikon D750 Nikon D600 Nikon AF Nikkor 105mm f/2D DC +7 more
Timskis6 OP Veteran Member • Posts: 9,562
Thanks Joe,
I made a few proofs of this image with different exposure settings and color balances. In fact, my preference was exactly what you described - clipping the whites and a bit more contrast in the wetsuit. However, this was the proof that the client chose so that's what I printed. Unfortunately the print didn't look so great, hence the need for help here.
Tim
daleeight Senior Member • Posts: 1,212
My past experience is that a lot of the "drug or superstore" (Walgreens, Costco, Walmart, etc) printers lean about 1/2 stop to the dark, so you're probably pretty accurate on that. If I need to print there (have no ICC profile for them), I just adjust for it and send.
Dale
ViTAR Regular Member • Posts: 185
Re: Thanks Joe,
And how did you calibrated your monitor?
It will be better if you correct the image to how it looks on the print for us to compare and post both, original and corrected.
photo_owl Veteran Member • Posts: 5,455
this is my experience as well with Photoshop here in the UK
I have had some batches refunded in full (200+ prints) because of it.
  • enjoy your camera equipment -
 photo_owl's gear list:photo_owl's gear list
Olympus E-3 Olympus E-400 Olympus E-30 Olympus PEN E-P1 Olympus E-M1 +8 more
RoelHendrickx
RoelHendrickx Forum Pro • Posts: 24,468
Can't help - not calibrated
But my prints turn out reasonably like I see them on screen, and I must say your image looks just a tad dark. A minimal boost in brightness or contrast wouldn't hurt. It is a very nice capture in any event.
Roel Hendrickx
member of UK (and abroad) Photo Safari Group
( http://www.ukphotosafari.org/ )
UKPSG presents a Tunisia E-3 user field report: http://www.biofos.com/ukpsg/roel.html
Stainedsilver Contributing Member • Posts: 773
Looks good to me on my calibrated monitor. But it could probably go either way just a little if needed to suit you.
I'm gonna have to sell some of this stuff so I can buy more stuff! Mummm, more stuff!
jfinite Veteran Member • Posts: 8,099
+1 to the above post. [nt]
 jfinite's gear list:jfinite's gear list
Olympus OM-D E-M5 Olympus E-30 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Leica D Summilux Asph 25mm F1.4 +3 more
Jonas B Forum Pro • Posts: 14,596
I'm sitting at a profiled monitor looking at your image. To me it looks, very much, as expected with regards to the supplied histogram.
Now, what can one do with that information?
Thinking about it, anyone having a color managed working environment will see the image as one can expect it to look. If you find that the print looks darker than seen on your monitor, well, then it is printed darker.
If you ask if the image is dark we are talking about personal preferences and mine is that I would try to brighten up the highlights and darken the black suit. Contrast has a huge impact on how we perceive an image.
Maybe I don't understand your question fully, or what you want to achieve here.
Jonas
Re: Can't help - not calibrated
In the past I haven't had many problems with Costco, it's weird this happened now. I wonder if the print medium - gloss or lustre - has anything to do with brightness of the image. This one was printed gloss which I don't normally do.
Tim
printed darker.
I was in fact referring to the printed image looking darker than the digital image on my monitor - it's hard to take a picture of the printed image and display the comparison online. It's one of those things that just needs to be seen in person, I guess.
I understand that in order to fix the problem I can simply boost the exposure by 0.5EV before sending it in for a print - but then color channels start to clip, the highlights clip, etc., and it wasn't as I intended to display the image. There's got to be a way within Lightroom to use ICC profiles (which I have), but I just don't know how to do it. More research...
achieve here.
Jonas
Tim
Marc Rogoff Regular Member • Posts: 487
On a calibrated mac 20" it looks like it could use 1/2 EV boost....
M
http://www.marcrogoff.com
'Sell your cleverness and buy bewilderment.'
—Jalal ud-Din Rumi
 Marc Rogoff's gear list:Marc Rogoff's gear list
Nikon D800 Nikon D750 Nikon D810 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 50mm f/1.4G +3 more
Re: Thanks
You don't have to scan or shoot printed image, you just have to change original one's exposure or levels to make it comparable to printed one on your monitor. Take an attention what light is in the room.
You didn't answered, how did you calibrated your monitor?
When I print images on my printer or in lab, prints looks the same, just sometimes slightly darker, but not by 1/2EV (except for colors on my printer, since I didn't created paper profiles for my printer). Monitor has just higher brightness than paper and light around and to check a print I have to look at it with 150-200W lamp.
Gary Hebert Senior Member • Posts: 2,611
I have had the same problem in
the past and you have to use the Costco Lab Profile and there is more info at
http://www.drycreekphoto.com
Costco also has a good brochure explaining the process. You have to use the profile of the printer you are going to print on. Phone the store you are sending your files to and they should be able to explain it.
Good luck.
Gary Hebert
E-520, 12-60mm, 70-300mm, G9,
http://www.pbase.com/turnstyle
