Surfing Photogrpahy
Started Oct 3, 2008 | Discussions
ashes_mtb Junior Member • Posts: 27
Surfing Photogrpahy
Hey there, bought an E-510 with the twin lens kit a while ago wanting to get into photography as a hobby. Been playing around a bit and thought I'd start posting some stuff for comment and advice.
Spent an hour at the beach this morning taking some surfing shots. Clear blue skies and sun over the land made for decent conditions I think.
All shots are with the 40-150 kit lens. Based on comments in another thread about sports photography, I was generally shooting in Aperture priority mode and leaving the camera to do its thing with shutter speed. First shots were very over exposed so I played with the exposure compensation until I got some decent results (I think). Haven't applied any PP, just cropped a bit (150mm is probably a bit short).
Would love any advice or suggestions!
http://picasaweb.google.com/Ashes.mtb/TriggBeachFriday3rdOctober08#5252764378028819778
ISO: 400
Exposure: 1/4000 sec
Aperture: f/4.4
Focal Length: 61mm
http://picasaweb.google.com/Ashes.mtb/TriggBeachFriday3rdOctober08#5252766369379012418
ISO: 400
Exposure: 1/3200 sec
Aperture: f/5.6
Focal Length: 150mm
http://picasaweb.google.com/Ashes.mtb/TriggBeachFriday3rdOctober08#5252766403929549298
ISO: 400
Exposure: 1/2500 sec
Aperture: f/5.6
Focal Length: 150mm
Cheers
Brett
Henry Caron Veteran Member • Posts: 5,984
Re: Surfing Photogrpahy
.In those conditions try metering the northern sky for your exposure.
Henry
Thekman03 Regular Member • Posts: 210
A circular polarizer might help cut some of the water reflection a bit.
maybe someone can confirm that.
ViTAR Regular Member • Posts: 185
The problem was - a spot metering, which gives completely unpredictable results in such situation.
I prefer ESP metering with compensation to avoid blown highlights (making test shots and checking histogram) and shooting RAW to have a better room to lighten dark areas. (well, now I always shoot RAW though).
Your images are still editable:
ashes_mtb OP Junior Member • Posts: 27
Cool, thats heaps better.
Can I ask what you use to edit and what you adjusted?
I'll have a play with ESP metering as well next time I'm out shooting.
though).
I've used SilkyPix and played with exposure bias, contrast and gamma. To play further I recommend to ajust WB and saturation and correct horison. Maybe its too dark (its a metter of taste), but much more dramatic
original:
edit:
P.S. I recommend to calibrate monitor using hardware calibration.
bobinsandyeggo
bobinsandyeggo Contributing Member • Posts: 987
consider setting EV to -.3 or -.7, too...
when you're in pretty bright, contrasty light situations. It can help alot with the highlights.
It has really helped me in similar conditions, with my 510. Gets me more of the white water detail. In this shot ( jpg/OOC, cropped only), I had it set at -.3 and probably should have had it at -.7.
Those are nice action shots you have, though. Thanks for posting.
bob naegele
san diego, ca
http://www.rjndesign.com/
 bobinsandyeggo's gear list:bobinsandyeggo's gear list
Olympus E-3 Olympus E-510 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II +1 more
JoeyCinSC
JoeyCinSC Senior Member • Posts: 1,587
I spent about two months in Hawaii back in the Spring and did some surf photography. My best results came while I was in the water (believe it or not). Most of the best ones were with the 50-200 AND EC-14. That gave me an effective reach of 560mm - still not enough IMO. That is why I jumped in. I was using the E-510 at the time, so I needed to be a little careful about the salt water, but I wasn't going to worry about a few splashes. I was about waste deep.
So, the 40-150 is probably on the short side for close action shots, but you could always try different perspectives with multiple surfers. I'd also drop the ISO 200 and get a shutter speed closer to 1/1000. You don't really need 1/4000 (and some of higher speeds you had). Keeping the aperture around F8-F11 will allow a greater depth of field. You'll get better detail with ISO 200 than 400. Occasionally, you will have to bump the ISO to keep the shutter around 1/1000, but that is OK.
With some PP, creative crops, and leveling of the horizon, you can make your current shots pop.
Good luck and here is an example of a collage I made. It looks outstanding printed to 16x20 (could easily go larger).
Joe - Philadelphia, Pa
http://joecorvaia.zenfolio.com/
 JoeyCinSC's gear list:JoeyCinSC's gear list
Olympus E-1 Olympus OM-D E-M10 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS +10 more
