5D Won't format Cards
Started Sep 14, 2008 | Discussions
Jonathan Lipkin
New MemberPosts: 21
Sep 14, 2008
I just downloaded some images from two 4G CF cards from my 5D. When I put one of the cards in the camera, I got the message 'CF card not formatted'. Odd, I thought, maybe a problem with that card. When I looked at the card in the card reader on my Mac, I could see the images on the card, so the card is OK. I put the other card in. Same error. When I try to format the cards in the camera, I get the message "Cannot format". I then tried a couple of other cards. Same error message. Any ideas on how to fix this? Can the camera be reset somehow?
Rob Cohen
Regular MemberPosts: 198
Re: 5D Won't format Cards
In reply to Jonathan Lipkin, Sep 14, 2008
You might want to power off the camera, remove the battery, insert the battery, then try again.
I hate to even suggest this, but there might be a bent pin in the CF card slot in the camera.
Best of luck,
Rob
Jonathan Lipkin
New MemberPosts: 21
In reply to Rob Cohen, Sep 14, 2008
Yes, tried removing battery, even the lithium battery. It doesn't look like any of the pins are bent...
Volker Hett
Senior MemberPosts: 1,214
happens to me, too
but not all of the time and mostly it's enough to switch the camera off, reinsert the card, and switch the camera on.
This happens with cards I used in a USB cardreader with my macbook but not with a pcmcia Cardreader in an HP NC6000 with Linux.
So I suppose my cardreader is faulty.
I wanted a better viewfinder and now I need more money
Jonathan Lipkin
New MemberPosts: 21
Re: happens to me, too
In reply to Volker Hett, Sep 14, 2008
Curious, Volker. Sort of the same thing happened to me -- the camera worked for a few minutes, then I got exactly the same error message. I'm going to call Canon service first thing tomorrow.
PawelWoj
Senior MemberPosts: 1,040
In reply to Jonathan Lipkin, Sep 15, 2008
its a self destruct timer. It senses 5d mark II is near , forcing you to upgrade. Genius!!
jk;)
