Q: Pentax F 28-80/3.5-4.5 & FA 28-70/4 AL, or ??
Started Sep 10, 2008 | Discussions
Ari Aikomus
Veteran MemberPosts: 6,927
Sep 10, 2008
Hi,
I need a little help my friends...I had to sell my trusty Tamron 28-75/2.8 Di, because of my bad finance at this moment. And now I want to buy something cheap in place of it. Right now I have only DA 18-55II kit to cover this "normal" focal length range, but it's a bit too slow and short for my needs ( I also have DA 55-300, but I don't want change lenses between Kit-lens and long tele zoom all the time - range 24-80mm serve my "all-around lens" needs quite nicely).
I know something about Pentax F 28-80/3.5-4.5 & FA 28-70/4 AL lenses (mostly because of Stan Halpin's Lens Comments Site)...
http://www.bdimitrov.de/kmp/lenses/zooms/short/F28-80f3.5-4.5.html
http://www.bdimitrov.de/kmp/lenses/zooms/short/FA28-70f4.html
http://stans-photography.info/
Obviously those are not very bad zooms, but how good those actually are ? My local camera store have F 28-80 for 70€ and new FA 28-70/4 for 100€.
...Or are there possibly some other good and cheap zooms to consider ?
(must be AF and not slower than f/4.5 and at least 70mm at long focal lenght)
Any comments/user experiences much appreciate.
Ari
  • Ari Aikomus -
'Why should I feel lonely ? is not our planet in the Milky way?'
CarlosRG
Regular MemberPosts: 261
Re: Q: Pentax F 28-80/3.5-4.5 & FA 28-70/4 AL, or ??
In reply to Ari Aikomus, Sep 10, 2008
That's a tough question, Ari. I had the Fa 28-70 4.0 and now I have the SMC-F 28-80 3.5-4.5
First thing is that if you are going to buy the F 28-80, make sure it is the SMC-F. The Pentax-F is a completely different animal, it has no SMC coatings and its optical formula is completely different.
Now for your question: both lenses, the SMC-F 28-80 and the Fa 28-70 are good zooms. As you probably know, the FA is smaller and lighter and focuses closer than the SMC-F. The latter's closest focusing distance is 80 cm. although it has a close focusing "macro" mode which only works at the 80 mm. setting and allows it to focus at 40 cm. or so. The SMC-F is better built, but heavier. Both of them focus fast, at least fast enough for my needs, being the SMC-F a bit faster, I think. Both of them flare very little (SMC coatings are excellent).
They are about equally sharp, but the FA is slightly better at 28 mm. and the SMC-F is slightly sharper at the tele settings. The FA is remarkably colour neutral, whilst the SMC-F has a warmer and more saturated native colour rendition.
I think any of them would serve you well. I am not in your case, because like I said I only have the SMC-F and sold the FA some time ago, but i would try them both and would choose one based in how they feel once mounted in the camera and in real use.
One last note: some FA 28-70 4.0 lenses develop a problem after some time, one of their element groups tends to unglue and separate. Have a look through the lens, back to front, with the diafragm fully open, and if you see some white veil when looking towards a source of light, the lens is affected and in that case don't buy it.
I hope this helps a little.
Carlos
Ari Aikomus
Thank you much Carlos ! BTW - photodo's MTF results....
In reply to CarlosRG, Sep 10, 2008
Hi,
ah...OK. that was really good to know!
cm. or so.
How you like their macro features - what comes to image quality? Example 18-55II kit has also macro feature, but it produces quite soft results...
excellent).
That's quite interesting (tele range is important for me), because I just found photodo's MTF results...
http://old.photodo.com/prod/lens/detail/PeSMC-FAZoom28-70_4-614.shtml
http://old.photodo.com/prod/lens/detail/PeSMC-F28-80_35-45-582.shtml
And these gives slightly better values (at tele end) to FA 28-70/4 lens !
Could be some sample variations, though.
The FA is
That's also good to know...
Do you remember what kind of bokeh they produces (if compare together)?
Okey - that was really good info, must check this lens again!
Indeed it does. Thank you very much for your opinion.
Ari
Carlos
  • Ari Aikomus -
kikivrany
Veteran MemberPosts: 3,190
Hello Ari Aikomus
These lens are just at Ebay. I don't now if you like Ebay, but if so, look under the category 'Pentax analog camera'. There you find them (incl. a useless camera), but there are somtimes cheaper as to search a lens only in the category 'Pentax AF lens'. ( I don't no why).
good luck kikivrany
Carpe Noctus
CarlosRG
Re: Thank you much Carlos ! BTW - photodo's MTF results....
The so-called "macro" feature of the SMC-F is a gimmick, mostly. As I wrote, it only works at 80 mm. Results are only passable, in my view.
excellent).
lens !
Perhaps, as you say, there are sample variations. But if you look at the graphs carefully, there arent't any remarkable differences between these two lenses, sharpness wise. They are almost equal. Anyway, I still think that the SMC-F is slightly better at 50 mm. and beyond.
The FA is
I think this is the one of the main differences between this pair of lenses: colour rendition, being the others build quality, size and close focusing abilities. If you want a light walkaround lens, with a neutral colour balance, the FA wins. If you prefer a better built lens; like warm, saturated colours and don't need to focus really close at all focal lengths, the SMC-F may suit you.
They're both OK, but don't expect anything special.
Carlos
Ari Aikomus
Thank you again ;-D n/t
excellent).
lens !
beyond.
The FA is
Carlos
  • Ari Aikomus -
Ari Aikomus
In reply to kikivrany, Sep 10, 2008
Hi & thanx for reply,
kikivrany wrote:
Hello Ari Aikomus
Yes, I know Ebay can be sometimes real treasury to find bargains. I have bought 5 lenses from there and only one purchase was quite much disappointment to me (lens was in much worse condition than seller said).
Maybe I should think also Ebay offerings - thank you for reminding!
Ari
good luck kikivrany
Carpe Noctus
  • Ari Aikomus -
Ari Aikomus
Well...I bought Pentax A 35-105/3.5...
In reply to Ari Aikomus, Sep 11, 2008
Am I crazy ? After all consideration I just finally bought manual focusing old Pentax A series 35-105/3.5 lens !
http://www.bdimitrov.de/kmp/lenses/zooms/medium/A35-105f3.5.html
BTW - It's very solid lens with high quality build construction...But how about IQ ? Well - I will post some sample pics soon...
Ari
  • Ari Aikomus -
brandrx
Forum ProPosts: 27,785
Ari...
Hi Ari,
Tha Pentax-A 35-105/3.5 is a top notch lens IMO although a bit on the heavy side. My experience with this lens is that the IQ is great and FWIW it works very, very good with my Pentax-F 1.7X AF Adapter.
Also, FWIW this lens has almost doubled in price at all of the used lens places since I bought mine back in 2004.
I think you will enjoy using the Pentax-A 35-105/3.5.
Cheers.
Ron - 'We don't have time to go take pics this afternoon Carl.'
Carl - 'What do you mean? It will only take 1/1000s.'
'Keep your eyes looking forward. However, glance back now and then to see where you've come from. It will put a smile on your face.' ~ brandrx
Ron ~ Retired.
VLampa
Senior MemberPosts: 1,030
Re: Well...I bought Pentax A 35-105/3.5...
In reply to Ari Aikomus, Sep 12, 2008
Ari
Good for you! I've seen photos from that lens and I'm impressed. I was looking for one myself but gave up because those that are selling are few and far in between (I'm guessing people chose to keep theirs, with good reason), where'd you get yours?
Ari Aikomus
In reply to VLampa, Sep 12, 2008
Hi,
Ari
Thanx VLampa. I bought mine in local second hand camera store for 150€.
Ari
  • Ari Aikomus -
Steven7
Regular MemberPosts: 119
Well perhaps we're both crazy!
Early last year I also considered the options sugested by the other posters and came to the same conclusion as yourself.
Yes the A35-105 is pretty heavy but it is still very managable and easy enough to focus, is very sharp from 5.6 and I see little or no CA. I prefer the effective longer reach (on digital) and it complements the 16-45 well. And of course I can use it on an MX quite happily when I want to shoot B+W.
Only downside is the rotating front element which makes using a polarising filter a pain, the macro feature is handy but doesn't match the quality or sharpness of a dedicated macro.
Many PDML reviews say this is the sharpest Pentax zoom ever made (these comments were made pre DA*).
I can post some samples next week.
Steve
Roland Mabo
Forum ProPosts: 12,462
I'm very happy with my FA 28-105 f/3.2-4.5 (AL) IF.
It replaced the FA 28-70 f/4 for me and it is as sharp (main advantage with the 28-70 f/4 is the fine sharpness) but has lower vignetting. It is also more contrasty. I prefer it to the 28-70 f/4.
Ari Aikomus
Re: Ari...
In reply to brandrx, Sep 12, 2008
Hi Ron,
Hi Ari,
Okey, that's good to know (because I have 1.7xAFA ;-)) !
Interesting indeed, just wondering what is its common price in second hand market nowadays ?
Thank you for comments,
Ari
Cheers.
brandrx
Ron ~ Retired.
  • Ari Aikomus -
Ari Aikomus
Thank you steve ;-D
In reply to Steven7, Sep 12, 2008
Steve
  • Ari Aikomus -
Ari Aikomus
Thank you for interesting info, Roland ! n/t
In reply to Roland Mabo, Sep 12, 2008
  • Ari Aikomus -
Pumpkin72
Forum MemberPosts: 76
Re: Ari...
I got mine from eBay for 100€ a few months back. I check prices regularly and haven't noticed major differences since then.
Actually, I thought it'd be a good suggestion for you when I saw this thread, but then re-read it, saw the 28mm "requirement", that both the lenses you were considering were AF, and also the 100€ price for the 28-70... so I thought that probably the 35-105 wouldn't suit your needs. I'm glad to see I was wrong
Enjoy it.
Ari Aikomus
Some my first pics with Pentax A 35-105/3.5
Here we go !
105/3.5:
with Macro setting, f/3.5:
35mm, f/3.5
More will come ;-D
Happy weekend,
Ari
  • Ari Aikomus -
KentG
Veteran MemberPosts: 4,199Gear list
I scored an SMC-FA 28-70/4 just last week for $58 US + shipping. Should be here today or so. Even though I have the Tokina ATX 828 28-70/2.8 (non-SV model) I've been looking for something in that range that is small enough I can use the pop-up flash without it getting blocked by the lens barrel or one of my low profile shoe mounted flash units like the AF200fg or the AF240ft.
As for the white veil that sounds more like fungus than anything else. If it looks like it has a faint lacey web look to it that is usually fungus caused by moisture getting into the Canadian balsum used as cement between the glued elements. Somtimes you can lessen it by putting it under a UV lamp for awhile as that will kill the fungus. It may not disappear completely but it will be useable. I have an LN- condition SMC-Takumar 300/4 I had to do that with That was why I got it for only $100US many years ago.
Kent Gittings
 KentG's gear list:KentG's gear list
Pentax K-5 II Pentax K-5 IIs Pentax K-S1 Sigma 50-150mm F2.8 EX DC APO OS HSM Sigma 18-250mm F3.5-6.3 DC Macro OS HSM +1 more
Ari Aikomus
...And now I bought Sigma 28-105/2.8-4 Aspherical...
In reply to Ari Aikomus, Sep 18, 2008
Huh! This LBA...
But hey - this is not so bad lens after all:
Looks fine, feel fine with K20D...and AF operate pretty well...
Pictures are not supersharp, but not bad either:
Some my first shots with Sigma 28-105 zoom:
105mm, f/4, 1/125sec, iso400:
Bokeh is acceptable, or what you think ?
75mm, f/4, 1/20sec, iso800:
105mm, f/5.6, 1/125sec, iso 800:
crop:
...Crazy cat - but not really bad zoom lens - and quite fast too!
Ari
  • Ari Aikomus -
