What is the Difference between effective pixels and active pixels of CCD?
Started Aug 20, 2008 | Discussions
ImageChain New Member • Posts: 3
Can someone help to clarify that? Thanks.
Chris R-UK Forum Pro • Posts: 19,591
Re: What is the Difference between effective pixels and active pixels of CCD?
From the Learn/Glossary section of this site:
http://www.dpreview.com/learn/?/key=Effective_Pixels
Chris R
 Chris R-UK's gear list:Chris R-UK's gear list
Olympus E-M1 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +4 more
OP ImageChain New Member • Posts: 3
Hi Chris,
thank you. It explains effective pixels. And how about active pixels? I still can not find a answer.
Rgds
Two Truths Veteran Member • Posts: 5,269
Example
I am not entirely sure that they really mean much at all.
For example;
Sony's 12MP CMOS APS-C sensor...
http://www.dpreview.com/news/0708/07082012sony12mpcmos.asp
Total pixels 4428 x 2948 (13.05 MP)
Effective pixels 4320 x 2888 (12.47 MP)
Active pixels 4312 x 2880 (12.41 MP)
Sony's 12MP CMOS dSLR...
http://www.dpreview.com/reviews/sonydslra700/page3.asp
Largest image size 4272 x 2848 (12.22 MP)
I guess that possibly the final image is produced from the "Active pixels" and for some part of the processing it is either cropped or downsampled slightly (losing 40 pixels x 32 pixels). The "Effective pixels" might include a blacked out area, in order to help eliminate background noise.
Random note; the photosites measure 5.49 µm x 5.49 µm, which means that the final images are formed from an area measuring somewhere between 23.4 x 15.6 mm to 23.7 x 15.8 mm.
Stuart / the Two Truths
http://twotruths.net/
sherwoodpete
sherwoodpete Veteran Member • Posts: 7,767
Re: Example
For example;
Probably cropped. With the old Olympus C5050, the jpeg and image from raw processed using Olympus software had the same size. But processing the raw file in a third-party converter gave an image with a few extra pixels width.
The "Effective
background noise.
From the example figures you quoted, it seems the "effective pixels" are 4 pixels wider on each side than the "active pixels". So it might be reasonable to assume that allows for the demosaicing of the "active pixel" region.
Peter
Re: Example
more or less understood.
Thank you guys.
