Haze/UV filter for Canon 10-22mm UWA: beware
Started Jun 13, 2008 | Discussions
Flying Fish Veteran Member • Posts: 4,473
As others have pointed out on this forum, some haze/UV filters don't work on the Canon 10-22 because at 10mm, the lens touches the filter. I just bought the Canon 77mm haze filter and indeed the lens does touch it at 10mm. I was going to return the filter, then I remembered I have 77mm haze filters on a couple other Canon lenses, so I tried one of the older ones (B+W, made in Germany) and bingo, it works just fine (and the new Canon filter works fine on the older lens).
So make sure you try the filter on the lens before you buy.
FF
 Flying Fish's gear list:Flying Fish's gear list
Canon EOS 7D Canon EOS 550D Canon EOS 6D Canon EOS 7D Mark II Canon EF 400mm f/5.6L USM +2 more
photonius Veteran Member • Posts: 6,493
Re: Haze/UV filter for Canon 10-22mm UWA: beware
lens).
FF
That seems a bit odd. How does that Canon 77mm filter look? It must sit
rather deep in the thread, or even extend to the back?
I have a Hoya digital Pro1 UV on the 10-22 and seem to have space in between.
(I will try to figure out the distance, if possible).
 photonius's gear list:photonius's gear list
Canon EF 100-400mm F4.5-5.6L IS II
Flying Fish OP Veteran Member • Posts: 4,473
It seems as if the glass in the Canon filter is closer to the back of the rim--am I being clear?--than the older filter's glass is. So the older filter provides a bit more space. It's not something you'd notice unless you were worried about 0.5 mm, as I was with the 10-22mm lens.
FF
Yes,
10-22mm lens.
Funny that Canon would make filters that don't fit on their own lenses....
lightrules Contributing Member • Posts: 771
Same for the Tokina UWAs..
like their 12-24 and new 11-16. The Hoya SHMC (or any standard size filter) "bumps" the front element when at their widest focal length. I use slim MC's on the 11-16 and it's fine now.
lens).
FF
bellevilleguy
bellevilleguy Senior Member • Posts: 1,089
Mine doesn't..
I have a regular Hoya UV on mine and it doesn't hit?? I placed a small piece of newsprint onto of the lens glass and moved it to 10mm and it is not touching, paper did not crush into the filter. It's close but doesn't touch...
wmhocker New Member • Posts: 12
I have discovered the same problem with my 24-105 lens and the Canon uv-haze filter. The two lightly touch creating a very small darkish dot at the center of the lens and an out-of-focus area on the image. A rubber band around the filter thread just before screwing it in tight and holds the two far enough apart to fix the problem. (That millimeter, of course, will then antagonize any vignette problems.)
