Softbox(es) vs. umbrella(s) -- advice please!
Started Apr 3, 2008 | Discussions
steverhodes
Regular MemberPosts: 238
Apr 3, 2008
I've got a D300 and an SB800 which I've been using by bouncing off ceilings and walls. Although most of the time I do roaming photography stuff, sometimes I do do portraits at school and church functions. I went to my local big camera store and asked about umbrella(s) today for the portraits. They were happy to sell me what I asked for but suggested that I should think about getting softbox(es) instead.
Is a softbox better, worse or about the same? What should I buy first? I need to do a bunch of portraits in a few weeks.
And should I try to start with just one flash or go ahead and get a second flash and second softbox or umbrella?
Advice please! Thanks!
Beastman
Regular MemberPosts: 150
Re: Softbox(es) vs. umbrella(s) -- advice please!
In reply to steverhodes, Apr 3, 2008
let me guess.. the softboxes were more expensive?! lol, just kidding.
softboxes are good for outside, due to wind reasons. but if thats not an issue, I dont see why umbrellas wouldnt work. I think I heard that theyve worked for a couple photographers in the past!
if your upcoming portraits are in a static location, set yourself up with your softbox or umbrella and use a reflector to fill the far side, no?
gallax
Regular MemberPosts: 125
It's not about which one is better and which one is worse. They are different tools for different tasks.
The umbrella is more flexible, but not as effective as a softbox in terms of light control. Also, it's harder to get a softbox to work with a wireless flash (IR/visible light type).
swu
swu
Regular MemberPosts: 468
it really depends on what you want to achieve.
steverhodes
In reply to gallax, Apr 3, 2008
I'll be using the CLS system of Nikon's, so I'm not sure why this wouldn't work, so long as it was in the arc of the on-camera flash. Right?
Re: " They are different tools for different tasks"
Which task then is each for?
steverhodes
In reply to swu, Apr 3, 2008
I want to achieve a nicely lit photo.
steverhodes
In reply to Beastman, Apr 3, 2008
side, no?
The price is about the same. How do I decide which one to get?
gallax
The umbrella is cheap, is not too heavy, is easy to carry and to store. But the light coming through it is not perfectly even - you get a lot of scattering so the light 'spills' on the walls and on the background. If you use it as a projector (black back) keep in mind that some of the light goes through it (you get light in the back of the black umbrella), the shape is not perfectly spherical so the light bounces in a way which is harder to control. And the spokes can generate unwanted highlights.
The softbox is big, is heavy (needs a stronger light stand), YOU CAN NOT use an infrared-triggered flash head inside as 99% of the flash heads (I don't know about nikons, but the canon ones need to see the master in order to trigger, and being inside a black box doesn't help). But the light created with it is easy to control - you get no spills, you can add modifiers (grids, blinds) and you get an even specular highlight (eye reflection) instead of a spider-web-umbrella-like.
Beastman
thats pretty much it in a nutshell. Im kinda thinking id favor the white umbrella and a silver bounce card on the other side. of course were assuming that you DONT buy that second flash... i bet that didnt help ya!
Jeff Maanum
Senior MemberPosts: 1,185
Go to the strobist website
They have TONS of info about what you are trying to do.
Support our troops. Bring them home to their families.
steverhodes
Yes, but ... Re: Go to the strobist website
In reply to Jeff Maanum, Apr 3, 2008
They do indeed. But I felt like a guy trying to write an essay on a subject by going to the dictionary for advice.
I gave up in frustration, hoping that I could get an answer here to what appeared to me to be a simple question -- umbrella or softbox for someone starting off with a little simple off camera lighting.
My camera shop said that they were about the same and that both could be used with my Nikon CLS to trigger them. They left the decision to me.
jmaditto
Regular MemberPosts: 474
Re: Yes, but ... Re: Go to the strobist website
I feel your pain. Lots of info out there. I couldn't decide so I went with both. And to add another variable into mix, there is a shoot thru and bounce umbrellas. Now even more to learn.
Good luck
ExNihilo
Contributing MemberPosts: 543
softbox all the way
No questions asked.
Softboxes eat up light, but I'd shoot with one (or a shoot through brolly) over a reflector umbrella any day...
http://www.Strobist.com even came to this conclusion just recently!
steverhodes
Re: softbox all the way
In reply to ExNihilo, Apr 3, 2008
ExNihilo wrote:
No questions asked.
Do you know WHERE on their vast site they came to this conclusion? I'd like to read the article now? Thanks!
P.S. I looked now and found them concluding that shoot through umbrellas were better than reflectors but I did not see any reference to softboxes. Also, I've been told (by some, not all) that softboxes will not work if I'm using Nikon's CLS to fire the flashes.
swu
swu
You are asking a subjective question - I can use my cheap equipments to achieve nice lit photos than many, but it doesn't mean other people can do the same with them. It all boils down to how much experience and knowledge you have. Look around for many C&C photos with nice equipments that turn out not so nicely.
If you can't decide, try softbox first. That way you know your fault isn't with cheap umbrella.
LeonelMaluf
Regular MemberPosts: 435
In reply to steverhodes, Apr 5, 2008
Umbrellas and softboxes are very different approaches to the final result.While the umbrellas are more directional and "hard" , softboxes gives you softer and diffuse light for pleasent effect portraits.They are like "window light".
You also can mix them playing with the good old "Key light - fill light" equation.
Personally i prefer continuous light: Fresnell, KinoFlo, softboxes..All mixed up! But that's another talk...
Hope i've been of some help to you!
http://www.dropbox.com/LeoMaluf
steverhodes
In reply to Jeff Maanum, Apr 5, 2008
Based on the strobist website, I decided that firing through an umbrella was the best thing to start with, so I ordered a setup with 2 translucent umbrellas plus two white on black umbrellas for reflector work later and I ordered a 2nd SB-800 flash for getting started.
Erick123
Junior MemberPosts: 39
Try this...
There was a discussion on this topic a couple of weeks ago...
http://forums.dpreview.com/forums/read.asp?forum=1025&message=27124143
plus there are lots of websites out there, one of the better ones is from Photoflex.
http://www.photoflexlightingschool.com/Lighting_Lessons/index.html
There is a wealth of info out there, check it out.
Bottom line, the total area of the light source and its relative distance to your subject will play the largest role in soft/hard your light is. So from that perspective they won't differ much assuming they are the same size. However, the umbrella is going to scatter much more light and depending on what you're trying to do, it might contaminate the background. Softboxes are less likely to do so.
I have both and have had very few problems with Nikon CLS working in either of them. Just be mindful of where your sensor is.
FredJamesPhotography
Veteran MemberPosts: 3,972
The softer the better - My suggestion and some samples
When doing portraits you want a softer light. At least I like it that way. When using an umbrella you can have a harsher shadow in my opinion. I always like something that allows me to bounce the light off the back and then let it come back through the front.
I haven't used flash for many years and enjoy using natural light or even lamps i n the house. I would suggest getting practice with out flash so you can get an understanding of light and if you buy anything make it a softbox for starters.
Then you can buy other devices as you get better with your understanding of light.
Here's a few with out flash but with a lamp or video light or daylight. You already have all you need to practice portrait lighting. The softbox or umbrella is only gonna help you to duplicate what you do with natural light at a time when that light is not available.
good luck , Fred
steverhodes
Summary of my purchase and my worries
started.
Thanks to everyone for their help. I have been frozen in my decison process for a long time (several years) since there are so many option and opinions when it comes to lighting.
Using no lighing or simple bouced lighting is so much easier. But I've always know I wanted to try more.
That said, I worry that I'll soon be getting buyer's remorse wondering if whatever I got, I should have gotten something else. I've never regreted a camera or a lens purchase but this lighting is something else entirely.
