How do I get that solid black background...
Started Mar 7, 2008 | Discussions
brian schindler
Junior MemberPosts: 36
Mar 7, 2008
I am far from being a professional photographer but I am involved in a hobby magazine that includes highly detailed diecast cars (expensive little boogars at that! Very high end). Most of the shots I take are good, at least from what I am told. I have shot in my head I would like to take with a black background and only want the subject to be lit...kinda like it is floating in air.
I use continuous lighting with an Oly e-500 on a tripod w/remote. I have the standard "kit" lens and a Macro lens. I also have both styles of ring flashes if that falls into a suggestion (ring flash and the twin head macro flash). I don't want to give up DOF as the detail is outstanding and more interesting in keeping the image properly lit.
I am using a black sweep background on a photo table but it comes out more like dark charcoal. So I want the background to appear a solid BLACK. Any ideas?
Excuse the newbie question, I have learned a lot about lighting techniques from all of the posts out here and I thank you all.
Thanks,
Brian
phila_guy
Senior MemberPosts: 2,360
Re: How do I get that solid black background...
In reply to brian schindler, Mar 7, 2008
properly lit.
BLACK. Any ideas?
1. black velour as background/sweep
2. move your model farther in front of the background
3. block the light from spilling into your background (barndoor, gobo, flag, snoot, grid, snoot+grid)
4. use a flash, continous lighting equals longer exposure time
We have art that we do not die of the truth.
--Friedrich Nietzsche
WFulton
Senior MemberPosts: 2,589
BLACK. Any ideas?
For small objects, black velvet from the fabric store is perfect, and as good as it gets.
Needs zero distance separation to be BLACK. The less expensive velveteen is OK, but one yard of the real stuff is awesome. Maybe $18.
Here is a sample, purse is laying directly on the velvet - no separation at all.
balloonchasers
Veteran MemberPosts: 3,183
In reply to WFulton, Mar 7, 2008
Great ideas listed above, but I will mention one that may get a few negative comments.
You may want to try some postprocessing of your images as well. Trying to go from a dark grey to black is easier than trying to go to a white background. I know... get it right in the camera!
John
Feel free to use any of these additional letters to correct the spelling of words found in the above post: a-e-t-n-d-i-o-s-m-l-u-y-h-c If you find any extra letters, please place them here for future use...
spiked3
Contributing MemberPosts: 519
In reply to phila_guy, Mar 7, 2008
Do what the parent said - moving away was the ticket for me.
Pick up a piece of black foam at staples/office depot for the table.
I learned it the hard way when I was using chroma green and getting all kinds of green tints on my models.
more at http://www.pbase.com/spiked3/black
Darrell Spreen
Forum ProPosts: 10,051
How about this?
This was done with a black velvet background and a black surface. With velvet you can be fairly careless in how the light spills onto the background.
But don't forget all white. I like it a little better when you want the car to appear grounded.
Darrell
brian schindler
Re: How about this?
In reply to Darrell Spreen, Mar 7, 2008
Nice...CMC models?
The top one was what I was looking for...perfect for what I have in mind. Was that one taken with a Flash as someone suggested?
The lower one is what I normally shoot but the models are 1/24th. I also agree to the "grounding" but this one is to be a bit different more like the one above it.
Off to the fabric store for me this weekend!
Thanks guys! I knew a newbie could get a straight shootin' answer here!
Barrie Davis
Forum ProPosts: 21,460
BLACK. Any ideas?
Yes...
Yes...
Yes...
Errr... No! Exposure duration wouldn't make any difference one way or the other.
Baz
brian schindler
In reply to balloonchasers, Mar 7, 2008
I try to do as little postprocessing as possible excpt to remove that errant speck of dust and maybe tweak the lighting just a tad.
phila_guy
In reply to Barrie Davis, Mar 7, 2008
the other.
you won't get 1/250s f/16 using continuous light. small aperture, high shutter speed will give you a black background even in daylight.
You can use f/16 with continuous light, you just have to keep the shutter open much longer getting more ambient light
Darrell Spreen
Re: How about this?
Nice...CMC models?
I believe they are both CMC models.
Yes, I use off-camera flash. I use one flash connected to the camera with a pc-sync cord and another flash optically slaved. Both are into or through umbrellas.
Good luck. Let us see your results.
Darrell
Jetjockgordo
Regular MemberPosts: 127
Re: How about this?
Don't forget to get a large lint roller! The best is the one that has peel off disposable layers instead of the gel type that can be washed.
Gordo
Nice...CMC models?
Barrie Davis
the other.
shutter open much longer getting more ambient light...
So, how is keeping the shutter open longer than the duration of a flash supposed to have a selective effect, lightening the background more than the subject?
For some reason you seem to think that it is does, but I cannot understand why you believe that. [?]
Please explain.
Baz
phila_guy
In reply to Barrie Davis, Mar 8, 2008
Barrie Davis wrote:
the other.
Please explain.
sure, these 2 concepts should explain that and should be easy enough to try out for yourself.
1. dragging the shutter
2. slow sync rear curtain flash
JimT49
Forum MemberPosts: 69
In reply to phila_guy, Mar 8, 2008
If you live in an area without a lot of light pollution, you can get a totally black backgrounds by shooting outside at night. Jim
Barrie Davis
Please explain.
Sorry... we are obviously flying on different beams, here.... (shrugs)
For some reason that I do not understand, you seem to be associating any AMBIENT light that might be around at shooting time....
(presumably, because somebody forgot to turn it off or pull the blinds)--
.... with an incredible ability in that light to illuminate the background more than the subject.
Just how this is supposed to happen I do not know. What's more, it has become increasingly clear that you don't have any more idea than I have !!
I think it is time to drop it, make my final point, and wish you farewell!!
Therefore, please note that.....
There is no particular difference in the visible effects of flash or continuous styles of lighting on still subjects. As always, it depends on how the lights are placed and their relative sizes and brightnesses etc....
However, they are rather different to shoot with. For small (stationary) objects needing finely controlled lighting (like samples seen in this thread), many people choose continuous for its more immediate visual feedback (WYSIWYG) especially since there is now increasing choice in fluorescent lightsources that combine cool working with top quality colour.
Baz
PlayPixel
Forum MemberPosts: 52
Re: How about this?
In reply to Darrell Spreen, Mar 8, 2008
Nice...CMC models?
It's look like real car to me (for the white car) look at the detail of the dash board. It's look real. Or maybe the premium car model.
Kpatel
Contributing MemberPosts: 937
In reply to brian schindler, Mar 9, 2008
Brian,
You need Digi tent like this
http://www.bhphotovideo.com/c/product/501358-REG/Westcott_305_DigiTent_20_.html
KP
virtuamike
Veteran MemberPosts: 3,569
Inverse square law
In reply to brian schindler, Mar 10, 2008
To darken background in relation to subject, either move your light closer to your subject or move your background farther from your light (or both).
Ramen is how I afford my glass
http://www.blindmike.com
Davidismyfriend
Regular MemberPosts: 274
In reply to Barrie Davis, Mar 10, 2008
Yes there is, sorry!!!!
the difference is that with flash the light on the model is provided by the flash and the background light by the ambiant light.
The explanation is that your flash will deliver a much stronger light on the first plan for a very short time that you'll be able to capture with a short exposure time, but this same flash wont reach the background therefore it will be black if you use black velour.
What happens is that with a flash you'll be able to control the light on the subject with the aperture and the light on the background with the time (the time is not affecting the flash unless your go past the maximum sinc speed of your camera).
With continuous light you dont have that separation capability.
