Tiffen UV Filter Glass Rattle
Started Feb 2, 2008 | Discussions
Charlie Grosvenor Junior Member • Posts: 38
I have just purchased a tiffen UV filter, if you shake the glass rattles. Is this normal? I've never had another filter do this
like a user Contributing Member • Posts: 985
Re: Tiffen UV Filter Glass Rattle
I can t help much as I ve only just bought my first one and that was in ignorance, I ve only ever seen the name when used as big square filters in a matte box but it was what I was offered and as we don t have 'em in the UK and I assumed as the store was OK they wouldn t sell me
I was desperate to cover the front of my 24-70 .
Anyway mine doesn t rattle . Yours shouldn t either it, would drive me crazy....
 like a user's gear list:like a user's gear list
Sigma 35mm F1.4 DG HSM Art
Idomeneus Regular Member • Posts: 339
I've had that happen, and I am not aware of any problem related to it. However, if it bothers you, look at the front of your filter and notice a ring that screws into the threads in the front inside of the filter collar. These are the same threads you would use to stack another filter in front of the one you have. On my Tiffen filters there are two opposing notches on this ring which you can use to obtain purchase on the ring in order to tighten it down against the glass element. That should stop the rattling.
Combat By Design
Combat By Design Regular Member • Posts: 285
Glad I found this five year old thread... the same thing happened to my Bower filter today, and I wasn't happy haha. Now it's fixed.
Thanks!
-K
 Combat By Design's gear list:Combat By Design's gear list
Canon EOS Rebel T4i Canon EOS 7D Mark II Canon EF 50mm f/1.8 II Tamron SP AF 200-500mm F/5-6.3 Di LD (IF) Sigma 50mm F2.8 EX DG Macro +8 more
Ian Regular Member • Posts: 487
Have you tried tightening the ring holding the filter in..?
