Contax/Yashica & K mounts
Started Jan 21, 2008 | Discussions
SBS
SBS Senior Member • Posts: 2,559
Does anyone know if the Contax/Yashica bayonet mount will fit Pentax K mount cameras? There is only a .04 difference in the registers (flanges) of these two mounts. Thanks in advance.
Michael
Anastigmat Forum Pro • Posts: 12,675
Re: Contax/Yashica & K mounts
Michael
No they won't fit. A Contax lens will not mount on a Pentax K camera and a K mount lens will not mount on a Contax/Yashica camera.
steephill Veteran Member • Posts: 9,861
sort of
Read the text that accompanies the photo in this link
http://www.pbase.com/steephill/image/44705399
I have also found a website which shows how to modify the K mount to fully accept a C/Y lens and still allow full use of K mount lenses. I'll post the link tonight when I get home.
Re: sort of
I tried a Yashica ML lens on a Pentax ZX-5 body. I could not get the lens to fit into the body. After seeing your photo, I tried again, and I discovered the reason I could not do it. The aperture coupling cam of the ZX-5 body prevents the Yashica lens from being inserted into the body. Since the Pentax DSLR cameras have the crippled K mount, the aperture coupling cam is absent, so the lens can indeed be inserted into the camera body.
Here is a web site that shows how to convert a Contax/Yashica lens so it will mount securely on a K mount body:
http://www5e.biglobe.ne.jp/~leicaman/Kmount_PLAN.htm
It is in Japanese but the illustrations are excellent.
Re: here's the link
That is an interesting link, but it can be somewhat destructive to the Pentax body, especially if part of the body material is removed so the C/Y lenses can focus to infinity. I do not have any Carl Zeiss lenses, so I will probably not be doing any modification to my Pentax body any time soon.
