Vuescan vs. Silverfast ?
Started Nov 20, 2007 | Discussions
ken henke Contributing Member • Posts: 766
Just curious as to some users experience with Vuescan and Silverfast. I have a Plustek 7200i film scanner, so I am just learning to use Silverfast SE. I also upgraded to get the multi-exposure feature. Some questions I have:
1. How well does Vuescan dust and scratch function work? Any detail loss? Does it work on Kodachrome slides? If it is indeed an infrared function, it shouldn't be used on silver-based Kodachrome, from what I understand. On E-6 slides how does it compare to Silverfast's SRD function?
2. How well does Vuescan multi-scan function work? Worth the extra scanning time?
3. Overall comparison of the two programs from a quality of output standpoint. I realize this may not be a fair comparison given Silverfast has many features, but I would still welcome any comments. Obviously, the "real time" view of any manipulations in Silverfast may be a huge benefit. And, of course, the cost of Vuescan is certainly a no-brainer.
Barry Fitzgerald Forum Pro • Posts: 29,888
Re: Vuescan vs. Silverfast ?
I have exactly the same scanner.
You can try the demo. It works pretty well, though I stick to low to medium mostly. Tend to stay on low. I think its better than silverfast, in this dept. It replaces scratches with more skill, IMHO.
Slides, they dont work well with infared removal, or ICE on other scanners. What you need is this, its free.
http://www.polaroid.com/service/software/poladsr/poladsr.html
Works very well on slides, you can run it on its own, or in PS. I use it on its own. With a bit of tweaking, even my oldie slides are nice and mostly clean.
scanning time?
It works well enough. If you are scanning at 7200 dpi, 10 times plus multiscan, go make some lunch! lol
Serioulsy I use it for mainly 3/4 scans, to wipe out any chance of noise in the scan, it appears to work well enough.
I mostly get better results with Vuescan. I do have silverfast, and I do use it a bit, but I just feel I get better more accurate results from vuescan. I didnt upgrade to the multiscan, as I was a bit niffed at silverfast for not offering it for free, I spent extra on the scanner to get the AI version. I kinda wasted my time and money.
Silverfast is very comprehensive, but I just prefer vuescan. I see a place for both being honest, though if I had nothing..I would pick vuescan anyday over silverfast. Easier to use, nicer results, and it costs a whole lot less.
Clint is on holiday! Soon to return!
ken henke OP Contributing Member • Posts: 766
and mostly clean.
When you refer to slides, are you referring to both Kodachrome and E-6 slides?
scanning time?
Yea, the muti-exposure feature now in Silverfast really interested me if it could increase the dynamic range of my scanner. I haven't had the time to test this feature, but will soon. Very curious to see if I wasted $$ upgrading. I had used Vuescan in the past, but was quite pleased. Again, the real time view of changes in Silverfast is a very attractive feature, but it may be a mute point if Vuescan's ease of use and generation of quality scans surpasses Silverfast. Like you indicated, it is possible that some slides, particulary ones with more shadows, may benefit using Silverfast.
E-6 slides?
Yes scanning kodachrome slides. IR doesnt work so well, it does a bit, but this is true to all scanners. That software works nice on slides, not so well on negatives.
If you notice on silverfast, you have an "HDR" option in the main selection. It makes your scans dark. So you pp them afterwards, pull them up.
For non HDR on silverfast
Pay attention to the highlight areas mostly, tweak the settings to hold that area. You can lift up shadows a bit more later.
Same with Vuescan, most setting needs a tweak to get the best from them, silverfast is more geared to tweaking in that app, VS is more basic, but you can pp after the scan. VS also has a direct to RAW, aka RAW from the scanner CCD. Not tried it yet..so cannot comment.
Wouldnt worry about the DR too much, not had much problem on that front. Slide scanning takes a bit of skill and tweaking to get right. Only scanner I ever tied that didnt have a hard time with high contrast slides so much was Minolta's Eite II. Most do.
Used a fair few scanners, and the Dmax no. seems to mean not that big a difference in the real world.
E-6 slides?
Yea, that makes sense because of the silver in Kodachrome slides.
them up.
Thanks...the "real" world experience is more important to me than research papers. Indeed, the highlights are exacting what I am focusing on. In addition, the dust and scratches. Other than that, I will fulliy anticipate further editing in Lightzone, for me. Of course that brings up the classic question, is it better to conduct a majority of the editing in scanning software of editing software? Not sure yet. Any experience on that issue?
To be honest, for me..I find it a lot easier to do adjustments, contrast, colour, levels etc, in another application. You can do it, a fair bit in silverfast, but its just a bit awkward IMO. Vuescan is not really meant for major adjustments, its got the basic stuff covered.
If you are worried about pp on scans, you can save as TIFF, thus not do any long term damage to the files, aka compression etc. I dont often scan a 7200dpi, I think 3600 is fine for most stuff. Takes less time also.
As you already have silverfast, do what I do, keep it for some stuff. The odd time it might be better, but over 90% of my scans are done in vuescan, its working pretty well for me. Give it a trial spin, see what you think.
Paul Stricklin Contributing Member • Posts: 901
The nice thing about Vuescan is the ease of adjusting the averaging areas to match the quality of the images you have. The multiple scans do greatly reduce random noise. If you do an initial low res scan of a slide set, the images will help ID the special handling needs for individual slides in a given set. Unless you are one of the special ppls that have a very high keeper ratio, why spend lots of time on images that don't meet your standards.
The nicely researched set of film settings is worth far more than the registration fee of the programs.
Paul Stricklin
Club, Event Photographer to pay for the equipment
Nature, Landscape for the joy of life
LPS
Vuescan vs. Silverfast test
Although I don't have much experience with either program, some of my first tests indicate Silverfast is clearly better.
Silverfast scan
Vuescan
Probably more from a lack of experience, but I don't find setting white and black points very easy in Vuescan. Also, this was a very difficult slide as it was relatively dark.
Re: Vuescan vs. Silverfast test
Ken Henke wrote:
Ummm...for some reason I didn't get the photos embedded. Try the links
Silverfast
http://picasaweb.google.com/laramiecats/Maroon/photo#5135797071536304162
Vuescan
http://picasaweb.google.com/laramiecats/Maroon/photo#5135797097306107954
Hmmm
did you make the correct adjustments in VS? Looks pretty flat to me.
Silverfast
Vuescan
Hmmm
Apparently not. I tried the white and black point % slider, but it didn't seem to help enough. And, yes, the main issue is how flat the image is. Any thoughts of what I should have adjusted? Again, it may just be getting used to using Vuescan. The layout is strange.
Ok you want to look at curve low, and curve high, maybe brightness as well.
It is a bit different to SF, thats for sure. But you will get used to it.
Oh, and tick pixel colours, that way you can keep an eye on highlight and shadows. Be more concerned with highlight.
See how you get on with that..
well.
it.
Yea, I did try some of the functions. One of the most frustrating aspects of of this, is that the scan shown in Vuescan does not match the scan when I view it in another editing application. Pretty hard to adjust with that situation.
Check your colour management settings. That can throw it off big time.
If its a major problem, try setting it to either the monitor profile, or sRGB. I assume your monitor is fairly close to what it should be?
I do have it set to my monitor profile. Is there any other setting in Vuescan?
Henry Richardson Forum Pro • Posts: 15,347
Vuescan scan to RAW file
time also.
I used to do a lot of scanning and I have been a Vuescan user since it was beta 0.7 back in 1998. What I usually do is scan to RAW. That will create a RAW file that you can then go back to later with Vuescan and "re-scan" as many times as you want with different settings. In fact, I have a couple of hundred Vuescan RAW files that I did back in 2004 that I still haven't gotten around to processing. I should get on that. They were all done with something like 8 times multi-sampling on my Minolta Elite. By the way, if you do the scan to RAW file thing make sure you select 64 bit (which includes the infrared channel).
Henry Richardson
http://www.bakubo.com
Re: Vuescan scan to RAW file
time also.
That is a great thought, actually. Clearly, I want to scan in many of my past slides in, but if I focus too much on editing each photo, I may never get it done. Right now I am just focusing on some particulary good slides for enlargements. I still am not getting the scans I want out of Vuescan, so I guess I better question Ed. Scans out of Silverfast do look the same when opened in another editing program, yet, as stated, Vuescan scans look different. Other than some color management issues, the comparison between Silverfast and Vuescan is very very close.
Henry Richardson
If you scan to RAW it is really fast because you don't have to make any adjustments for each scan. Just do the scan and then move onto the next slide. Later when you have time you can one by one go back to the folder with all the RAW scans and process them.
The Vuescan interface is quite different than what you are generally used to, so it would be worthwhile for you to read the help file and user guide, if you haven't done that already. The early Vuescan was a Windows command line program -- sort of like dcraw. Of course, now it has a huge number of controls so that makes it appear complicated.
Henry Richardson
RAW scans
I have some 400 slides to work thought (tip for others..dont offer to scan old slides for family! lol)
Tried out the RAW, using DNG, and I have to say this looks like the best way to work through big jobs.
You can get stuck into it, without messing about tweaking etc, then come back once you have them all scanned, and tweak away (I use LR by the way)
Also ideal for archive reasons, ala you are not "stuck" with the adjustments you made (or any errors), and can re pp later on.
So with that in mind, I would say Vuescan is worth its asking price just for this feature alone.
StephaneB Contributing Member • Posts: 778
Hmmm, pardon me for saying so, but your conclusion is due to your lack of experience.
The VueScan one is actually the better scan , while what you got from SilverFast is a backed finished product.
Silverfast tries, and fails in my opinion, to be a complete thing while VueScan tries to get the most information from your film.
In your Silverfast sample, you have clipping both in the shasows and in the snow. These are lost forever. With VueScan you get a file that needs to be porcessed to do what you want with it. That can be automated in PhotoShop.
Stéphane
Sharpness is over rated.
http://lumieredargent.com
 StephaneB's gear list:StephaneB's gear list
Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R +10 more
