CHDK firmware hack discussion (15)
Started Sep 3, 2007 | Discussions
microfunguy Regular Member • Posts: 234
Re: Strange Compilation problem.
GrAnd wrote:
The compiler environment does not use cygwin
Then why does the error message refer to 'zsh' which is not part of the ready-made environment ?
It seems you have a conflict between various binaries.
Is there any way I can check this ?
If ANT and Perl variables are in the Path, can they cause a conflict ?
Or your environment is not set up properly.
Is 'Path' the only System environment variable that I have to set ?
This is very strange ..........
GrAnd Regular Member • Posts: 325
Digic III
Vit40 wrote:
GrAnd, are there any news about Digic III CHDK?
It's successfully ported to G7 1.00I (not in my branch yet).
Binaries: http://www.zshare.net/download/37426216a0c975/
Sources: http://www.zshare.net/download/3742688c747661/
zsh.exe = sh.exe
Because it was just renamed.
Try to clean your PATH variable (just keep an environment directory).
I have no idea here. But I can just say, that it could be.
I had have the problem with zsh - it crashed randomly in various places. The issue was ... (could you guess?) with web-camera server process. If I kill the web-camera related process the zsh does not crash anymore.
Yes. I did not set any other variables.
I agree. Because many people (include you in the past) use this environment.
OK, two 'actions' have recently taken place.
I have installed a Logitech webcam driver.
I do not know if this 'server' process runs if I am not running an application that uses the webcam.
I accidentally (a few days ago) ran a BAT file that deleted my system 'Path' variable and replaced it with a path variable with just the location of gmake.exe in.
On a USB drive, I do have a copy of the system as it was 12 months ago.
The 'Path' variable will not have been over-written.
I temporarily made that drive my main drive and added location of gmake.exe to 'Path'.
Same problem, but I had also installed the webcam driver a few minutes earlier.
When you say 'clean' the Path variable do you mean replace existing entry with just the location of gmake.exe ?
Does it matter if it is User or System environment variable ?
When I restarted my computer this morning there was a message about Administrator that was too fast to read, then Windows
checked the C: drive and finally reported that the system had recovered from
a serious error.
I do not know if that is because I had just installed Cygwin.
Anyway, I will remove Cygwin.
I have a Logitech web-camera too. The process name is one of: LVPrcSrv or LVComSX.
Yes. Just PATH to system dirs and gmake.exe.
User variable (if exists) overwrites the System one.
The path variable is probably causing the problem.
'David' user-variable is 'path' and only contains :-
k:\chdk\gcc\bin
System variable is 'Path' and contains :-
C:\WINDOWS\system32;C:\WINDOWS;k:\chdk\gcc\bin
So, I am not sure if they are the exact original names for PATH and if 'path' takes priority over 'Path'.
jose42 Junior Member • Posts: 32
Re: Digic III
Hello GRand.
I´ve tried the CHDK in the G7, it works.
So far the only function I understood is the battery voltmeter.
On the way to lern the use of the whole system.
When I removed the card with the files (PS and DISKBOOT) the G7 went back to original.
Thanks a lot. Jose
RembertRover New Member • Posts: 9
Re: Digic III
Hi GrAnd,
I just tried the Hack on my G7. Works perfectly. Thanks a lot!
The CRW files the cam writes cannot be read by any of my programs. (RAW-Shooter, Lightroom, MAXView).
Everything else I tried seems to work as intended.
Card is bootable also.
Thanks again.
Rembert
Vit40 Regular Member • Posts: 269
Re: Digic III
Did you try converting crw to dng with DNG4PS ? I think it should work, since sensor seems to be the same as in A640
I'll try to provide a color matrix if needed, if someone send some samples
My congratulations to GrAnd & Co for this
Vit
yournamehere Junior Member • Posts: 42
Re: Digic III
Hi GrAnd
First off, thanks a lot for your time.
I tried in my G7 and it just hangs brain dead with green power light on as soon as I confirm firmware upload and the only way to get it back into life is removing the battery.
Y copy both "PS.fir" and "Bootdisk.bin" in the root directoy of the card (I tried with two cards and downloaded three times just in case) and I get a UpgradeLog.txt back which isn't an understandable txt file, by the way.
Booted in "Play" mode, "Menu" key, scrolled down to "Firm Update" and got to the "Update firmware version? 1.0.0.0 -> 1.0.1.0" screen. Then it hangs as soon as I press the "OK" button
I have tried at different modes (auto, P, AV, M...), copying the files a few times, with both linux and windows boxes...
Any idea?
Regards
marirose3657
marirose3657 Senior Member • Posts: 1,343
Re: Digic III
Which camera's version are you using for the G7? I am interested in trying this but do not know which files to download (I use the hack on my S3 and works great)
Marirose
Keep Smiling... it can always be worse!!
Canon 20D, Canon S3, Canon SD900, Canon G7 Kodak Z712 and Fuji F30
 marirose3657's gear list:marirose3657's gear list
Canon PowerShot G9 Olympus Stylus 1 Panasonic Lumix DMC-FZ1000 Panasonic Lumix DMC-FZ300 Canon EOS 5D Mark II +7 more
Re: Digic III
this one, for sure!!!...
UNBELIEVABLE !!!
So, installing my Logitech webcam completely messed-up the compilation process ?
How on earth did you discover that ?
What does it do that causes the problem ?
Many thanks.
David
js2020 New Member • Posts: 2
Re: Digic III
i have an sd800is - will i be able to update my firmware using this fix? or must i wait until it's ported to an sd800is? thanks
Re: Digic III
yournamehere wrote:
Hi GrAnd
It seems that you have not the 1.00I version of original firmware. There is the another version known (1.00G), but we don't have a dump of it yet.
microfunguy wrote:
UNBELIEVABLE !!!
So, is the problem solved by killing one or both of these processes?
marirose3657
GrAnd
Hi and thanks for all you hard work. Is the hack available for the G7 and if so, where can I download it?
Thanks in advance.
Marirose
Re: Digic III
Thats right, its the aforementioned version.
Rembert
Yes .... LVPrcSrv.
A Google search for 'sh.exe logitech' shows this has caused problems for a lot of people.
I wonder what it does ?
David
Re: Digic III
Thank you for the advice! I got myself the DNG-Converter and it works.
What a great piece of software!
