Nodal Point
Started Aug 5, 2007 | Discussions
Rudi2K5 Contributing Member • Posts: 714
Nodal Point
I have a question to those panorama freaks:
Is there any source in the web where they list lenses with information about the physical location of their nodal points?
http://www.pbase.com/rudiknust
John Kim Senior Member • Posts: 1,256
Doug Kerr wrote up how to find the pivot point
fredlord Senior Member • Posts: 2,630
Re: Nodal Point
Although we are not "those panorama freaks," a few photographers have listed them. It is so absurdly simple to find them that most have not bothered to make a list. Zoom lens nodal/pivot points vary with focal length anyway.
 fredlord's gear list:fredlord's gear list
Canon EOS 5D Mark III Canon EOS 7D Mark II Canon EOS 5DS R Canon TS-E 17mm f/4L Sigma 15mm F2.8 EX DG Diagonal Fisheye +6 more
Vernon D Rainwater Forum Pro • Posts: 13,160
Re: Nodal Point
length anyway.
I agree with your comment about NOT freaks. Also, I think it would be very helpful if there was a site where the "so called" Nodal Point information could be accessed. Yes, it may be east, however; it is somewhat like "re-inventing the wheel".
This would be good if included with lens specifications
Vernon...
GaborSch Veteran Member • Posts: 7,203
Entrance Pupil Database
(it is not the nodal point but the entrance pupil)
http://wiki.panotools.org/Entrance_Pupil_Database
There are only a few Canon lenses listed.
No, it is not true, that it is easy to find the exact location. It requires a series of shootings and comparison on computer.
The location varies not only with zooming, but in case of some (most) lenses, with focusing as well, although this becomes relevant only indoor.
There are three lenses we both have (four, but the Tamron 17-35mm is not good enough for panos). The distances in the following chart are measured from the mounting screw of the 20D. No idea, if and how much the 400D differs from that.
Canon 50mm f/1.4: 49mm @ infinity, 50mm @ 4m
Tamron 28-75mm: 102mm @ 28mm, 97mm @ 35mm, 92mm @ 50mm, 85mm @ 60mm, 79mm @ 75mm
Canon 85mm f/1.8: 73mm @ infinity
For the others: you can get a good approximation, if you stop down to f/10 or smaller, look into the lens from the front and actuate the aperture (on-off-on-off). The location you see the aperture is the entrance pupil. This is good enough in most cases, but not indoor.
rpcrowe Contributing Member • Posts: 859
Nodal Point - sites
I hope these help...
http://www.path.unimelb.edu.au/~bernardk/tutorials/360/index.html
http://www.zenadsl5251.zen.co.uk/photos/panos.html
see Tutorial 5 for above
http://forums.dpreview.com/forums/read.asp?forum=1029&message=16638706
http://gregwired.com/pano/Pano.htm
Relatively inexpensive pano mount the Panosaurus
http://www.vrphotography.com/data/pages/techtutorials/technotes/nodalptalign-tn.html
Retired Navy Master Chief Photographer's Mate. I was a Combat Cameraman, Motion Picture Director, and a Naval Aircrewman. I also had experience in reconnaissance and intelligence photography. I have had considerable commercial photo experience in weddings and advertising photography. I am fully retired now although I dabble occasionally in dog portraiture. I presently use Canon DSLR cameras.
peppino Regular Member • Posts: 445
Re: Doug Kerr wrote up how to find the pivot point
thanks a great article!
Rudi2K5 OP Contributing Member • Posts: 714
Thanks a lot,
Hi Gabor, thanks for your detailed information.
I am right now in the process of selling about 1/3 of my lenses to buy some better stuff. Among them are the Tamron 17-35 mm, Canon EF-S 10-22mm, Canon 24mm f/2.8 and the Sigma Fish-eye, too. I am going to Germany on Sept. 2, and I will sell them all through ebay. I am also selling my Manfrotto pano head 303, because it is way to heavy to carry around. I bought already a Nodal Ninja 3, which I will pick up in Berlin next month.
But I will have also some new purchases in September:
Canon 5D
EF f/2.8 16-35mm L II
EF f/4 70-200 L IS
Besides that in my sons house in Berlin are some manual zuiko lenses for me to be picked up and bring back to China (bought them all on ebay recently):
f/3.5 18mm
f/2 21mm , f3.5 21mm
f/2.8 24 mm
f/2 28mm
f/2 35mm
f/1.4 50mm , f/1.8 50mm
I will purchase adapters here in Guangzhou, China. I am also looking at those manual Zeiss ZF lenses, since they are much cheaper here.
So, when coming back to Guangzhou on October 5, I will have a lot of "lens testing" and "nodal point finding" work to do.
Thanks also for the critics on my panos. I am taking it with a positive attitude. I have taken a closer look and found some more issues. I am learning constantly.
Re: Nodal Point - sites
Thanks for the links.
Addendum
I forgot to mention: the conversion of the distances from the 20D to your camera should be easy. The Entrance Pupil Database contains the distances from the mounting screw to the lens base, in case of the 20D this is 36.5mm. The 400D is not listed there, so you have to measure that distance yourself and add/substract the difference to the distances I listed. The values measured from the lens base are the inherent characteristics of the lenses, but that is useless, as in the practice you need the distance from the mounting screw.
netmare New Member • Posts: 12
Re: Nodal Point
I'm wondering
Did you measure the distance from the mounting screw to the lens base?
Re: Addendum
If I understand Gabor correctly, that means
Canon 50mm f/1.4: mount-to-lens-base-distance + 12,5 @ infinity
Canon 50mm f/1.4: mount-to-lens-base-distance + 13,5 @ 4m
Is this correct?
Right (nt)
Re: Addendum
Is this correct?
Below is a copy of the explanation provided by the other poster:
The "so called" lens Nodal point should be DIRECTLY above and in line with the center of the tripod.
Before and alignment and with the camera mounted directly on the tripod; the "Nodal Point" will normally be in FRONT of the center of the tripod. Therefore, to align the Nodal point with the center of the tripod; it usually is necessary to have some type of a bracket to allow moving the Camera backward (the proper distance) to have the lens nodal point directly over the center of the tripod.
The measurements provided by the other poster evidently is the distance to move the camera and lens backward for the alignment.
The normal (and preferred) method is to use the tripod "connection hole) in the Camera to express how much to move to make the proper alignment.
Just think of when the camera is mounted directly on the tripod (before any adjusting for nodal point) that the distance from center of the tripod to the camera tripod mount "hole" is 0 (ZERO). Then, how far do we need to move the Camera+Lens to have the nodal point aligned properly. This distance is based on the lens setting for MM, etc....
The (copied from the other post) 49mm and the 50mm above are the distance to set the camera tripod mount hole on the camera backward from the center of the tripod in order to properly align the lens nodal point.
I have NOT used the 50mm f:1.4 lens to know the proper settings, however; the other poster obviously has.
The reason (of course) to have the nodal point "directly" over and aligned with the center of the tripod is so when the camera is rotated for the pano exposures, there will be NO change because the nodal point is centered directly in line with the tripod.
I hope this is at least as clear as "mud" [Grin]... I do hope this helpful for you.
Vernon...
Re: Addendum
I understand it. I think:-).
Gabor uses a different camera but does use the same lens (the 50mm 1.4).
I'm just trying to find out if I understand his hints of "translating" his measurements to my situation ...
