85L in the middle of the street
Started Jul 12, 2007 | Discussions
Nilsa Regular Member • Posts: 183
Hi Canerino :-)
It is a very nice photo... and so are most (if not all) of the photos in your gallery. But this particular photo does look strange at the street. The feet are in focus but the street looks as there are blurry spots where it should be focus. If you compare with...
http://www.pbase.com/anerino/image/82095236
... where the street is in perfect focus. I do have the 85L and have not yet this blurry spot effect on any of my photos, but I have seen it somewhere else (dont remeber where).
Is this something you have seen before or have any explaination of?
Thanks for sharing!
Schwa Senior Member • Posts: 1,185
Re: Hi Canerino :-)
Very sweet shot. Was it originally shot in raw? What did you process the raw with?
My current camera:
http://www.amazon.com/exec/obidos/ASIN/B000V5P90K/02-4686-20
Some of my pix:
http://haroldandpod.com/p826419914/
canerino OP Contributing Member • Posts: 794
Re: Hi Canerino :-)
To clear up some confusion.
Thanks to some emails from friends on other forums, I went back to my original RAW image to see if I wasnt crazy (mind you this was 3 months ago). I had no idea this photo was causing so much controversy!
I did two versions of this photo (the one on the right in this composite).
AND
Here is the story. On the composite I posted here in this post, that is the original composition of the photo. I felt (and others) that I didnt leave him enough foot room and felt that the photo would benefit from more footroom. So I did some cloning of the asphalt to 'create' more room (the second photo I posted in this thread). That might explain some of the unnatural look around his feet.
I belong to several online photography communities and posted both versions in different forums. I forgot about the cloning on the ground for the inital version I posted here. I responded above before looking at the RAW. Clearly, I was wrong and mistaken about the version of the photo I initally posted here.
Once again, there is absolutely NO additional blurring on the background. I wouldnt even know how to go about doing that. Selecting the subject and glaussin blurring the background?
Anyway, sorry for any confusion I may have caused. I should have looked at the RAW before I posted. Hope this clears things up a bit.
Matthew Thomas Regular Member • Posts: 170
Thanks for clarifying this
It all makes sense now. The image is better compositedas you did. It was a good photographic decision in my opinion.
I agree the lense needs no additional blurring. That's the advantage of a FF camera. I don't shot FF (1.3x and 1.6) and don't quite get the degree of separation you can with the 5D. Very enticing for since the 5D price has just come down.
Matthew Thomas
Partner / Multimedia Director
ThomasArts, Inc.
chinch Senior Member • Posts: 1,731
Re: 85L in the middle of the street
can you post the unedited original?
that would make me reconsider the 85L vs 85/1.8 as a future purchase
 chinch's gear list:chinch's gear list
Canon EOS 5D Mark III Canon EF 24-105mm f/4L IS USM Canon EF 70-200mm f/4.0L USM Canon EF 85mm f/1.8 USM Canon EF 16-35mm f/4L IS USM +4 more
What more from the original do you expect to see? He posted the 2 images used to compositd the image, and none of the background blur is was part of the composite. The image you see is effectively unaltered besides the lower 5 percent.
Matthew Thomas
ThomasArts, Inc.
full resolution undoctored would help me decide to save almost $1300 MORE for the 85L over time.
"the image you see" is shrunk down JPG for the web
that is not exactly asking too much is it???
either way maybe you can let the OP answer for himself
Asking for RAW file is asking a lot
I mentioned earlier that the poster could post a RAW file to help clear up the issue of whether the pic was altered (and it was). It was suggested to help verify the OP's claim and that claim has since been clarified without the need to release the RAW file.
Asking for a RAW in order to help you decide whether you want to buy the lens is ask much more than this.
There are 1000's of images around the forum and elsewhere on this lens. There are many featuring smooth boken like this (although composed differently).
There are 100's of images featuring 100% crops of the lens wide open in more challenging techical situations. If you merely pickup a National Geographic, you'll see at least a few obvious samples using this lens in each issue. The quality is exceptional at wide apertures as long as the exposure isn't too over exposed in highlights.
I just don't understand how asking the OP to expose his unique RAW file to the general public (risking copyright violations) to help you make a decision that should be evident if you search is anything but invasive.
I would never hand off the RAW of a stock photograhy quality image (and this is that level of quality) to the general public. It is bad business practice. We should just be thankful that the OP was nice enough to share what he/she has and let it be.
Matthew Thomas
ThomasArts, Inc.
Re: Asking for RAW file is asking a lot
your interfering is invasive.
gimme a break. there aren't 1000s of similar images and small 100% crops are worthless when evaluating more often than not actual photos in their entirety.
bad business? this is a message board.
100% JPG is sufficient if RAW is such a deal-breaker.
but either way kindly stay out of it...if and when i request something from YOU then i'd welcome your input.
until then....
highlights.
invasive.
Matthew Thomas
ThomasArts, Inc.
My questioning your request for a RAW file is not invasive. I want the OP to know it is not necessary and will, yes, will hurt his/her ability to market the image at some point. The OP may decide this is a fair trade, in exchange for some kind of insight you can give with the RAW file in hand. However, if the main reason you request it is to help yourself decide on a purchase, I see this as unnecesary and invasive.
I've seen requests for RAW files and the expection of members to view them drive pros away from these boards, leaving the uninformed to do the informing. I don't know a serious pro that would share a RAW file online with anyone unless the image lacked any value. This image has value and I believe we should respect that.
This topic seemed a bit different than the usual 85mm variety so I decided to spend some valuable time contributing to it. Sure the OP can answer your question, but until then, this is my forum as much as yours.
You could just open another topic post called "85mm 1.2 samples needed" I've seen countless like it but at least it would be your topic and other people would be free to blast you for not searching.
And yes, there are 1000's of images and opinions of the lens here and most of them attest clearly to it's ability and weaknesses. Learn to search for them first, then you can call me the one that's invasive.
Matthew Thomas
ThomasArts, Inc.
Felipe Rodríguez
Felipe Rodríguez Veteran Member • Posts: 3,015
computer blurring
Hi!
As a owner of the 85L lens (and totally sucker of the bokeh it produces!), I would like to say that I doubt anyone is capable to recreate that wonderfully creamy, dreamy blur using a computer. Moreover, the guy eventually trying such task would
have a very hard time to avoid halos around the boy...
That small road cloning at the boy's feet doesn't detract an atom from the picture, which is captured and edited with great taste and skill.
Kudos once again!!!
http://www.beatusille.net
Bokeh
Dadme un mundo sin contornos,
Un espacio feliz que ignore los perfiles.
Concededme, sí, la dicha redonda
De flotar sin conciencia en el fondo
Desenfocado de mis fotografías.
Give me a world with no edges,
A happy space knowing nothing about outlines.
Grant me, please, the round joy
Of thoughtlessly floating on the blurred
Background of my photographs.
 Felipe Rodríguez's gear list:Felipe Rodríguez's gear list
Fujifilm FinePix X100 Nikon D810 Nikon D4 Canon EF 28mm f/2.8 Nikon AF-S Nikkor 50mm f/1.4G +13 more
enough.
please ZIP IT already.
if he says "i can't do that" that is sufficient.
NO ONE EXPECTS ANYTHING
(i don't even expect YOU to mind your business and stop being invasive)
what drives away people from boards is derailed threads such as what you are helping to do with this.
invasive.
yours.
Matthew Thomas
ThomasArts, Inc.
abnorm Contributing Member • Posts: 896
Was this shot with 85 mk I or mk II? (nt)
no text
michaelbs Senior Member • Posts: 2,663
I perfectly understand the request.
Quite honestly this resized web picture is oversharpened with jagged lines and halos.
If anyone should want to evaluate this picture in order to have a better basis for his own purchase a raw pic is required. OP can simply say no if it's too much to ask. But the request makes sense.
best regards
Michael
http://www.michaelbennati.dk
http://michaelbennati.dk/galleri/index.php?list=14
http://michaelbennati.dk/galleri/index.php?list=58
Eric Sorensen
Eric Sorensen Veteran Member • Posts: 4,638
And I thought this 85 f1.8 shot was good...
I can't imagine how much better it would have been at F1.2. I need to get me one of those balls of glass...
Canon EOS 5D ,Canon EF 85mm f/1.8 USM
1/500s f/2.0 at 85.0mm iso200
Bossier City, Louisiana
http://www.pbase.com/ericsorensen
 Eric Sorensen's gear list:Eric Sorensen's gear list
Canon EOS 5D Mark II Canon EOS 5D Canon EF 85mm f/1.2L II USM Tamron SP 24-70mm F2.8 Di VC USD Canon EF 70-200mm f/2.8L IS USM +4 more
Felipe Rodríguez
Another sample
Sorry! I couldn't resist to replicate your picture with my little darling. Your photo is better: light, mood, wet road, the model is more cooperative... Moreover, I am having a problem of backfocus and I'm going to send the lens and the 5D to get them calibrated together, so my sample is not as sharp as it should be.
But, anyway, this lens is quite impressive!
Regards!
Bokeh
Felipe Rodríguez
and even another one!
My nephew Pedro:
Bokeh
jccphoto Regular Member • Posts: 449
Re: Another sample
Looking at the ground, this photo does not look back-focused to me.
Regards!
Bokeh
Anand M Forum Member • Posts: 80
Re: And I thought this 85 f1.8 shot was good...
Would love an 85L myself. That's a great shot though Eric, and it shows off the 85/1.8 qualities well.
Re: Another sample
Regards!
Bokeh
background looks fake!!!!! you clearly cut and pasted your model!!! you added additional blur!!!
very nice shot my friend!
you have a darling model. its hard for me to see the backfocusing issues on this version, but i did have a mkII that was off. I had a mkI that was sharp, returned my first mkII, and now have the lens I currently have, which is good.
