CHDK firmware hack discussion (8)
Started May 19, 2007 | Discussions
stebu
New MemberPosts: 12
An OOPS! function for Sokoban
In reply to Graystar, May 22, 2007
GrAnd (and anybody else interested)
I downloaded the src and gcc, works fine!
So as a first task I added an undo function to the Sokoban game. For me, it worked; it undoes the pushes, not the bare moves. The undo key is Display (on a710), which in some places has been used as the Back key.
Since this is my first go with the CHDK (and I haven't coded in C for 10 years) I ask GrAnd to include this change in a future release, thanx. The source code can be found at
(http: koti. welho.com/tstenbe3/gui_sokoban.c)(remove the spaces),
this was the only file I've touched.
Sorry to have removed your banner, GrAnd;-)
Stebu
Slarty42
Contributing MemberPosts: 527
Re: A700 support someday ????
In reply to GrAnd, May 22, 2007
Hi Guys
I came upon this thread just minutes ago(I don't visit here to often), and being of a curious nature, I had to "hear all about it".
I fully realize my little A700 (Jan 06 and 8300+ images so far), is NOT in the list,but I thought I'd try anyways to see what the results were, and perhaps some other A700 owners might be interested .....The devil made me do it !!!!
Firstly I went to the FAQ link and discovered how to utilize the "ver.req" file and that works (thank-you). I just hold down the SET button first, and THEN the DISP button (only combination that works), and then I see the version...GM1.00B
I then downloaded all the A610 - 710 zips and copied the 2 files in each zip to card (erasing both after seeing results), then trying next zip and so on
Results of all zips I tried: turn camera on,...select playback, and after hitting menu, I see a new menu item now "Firm Update...." at bottom (different font/colours also).
If I select "update" and hit SET ,I see .....File update Error !
,but all camera's functions work as before and never "hangs" or any other problem.(all is well !!). To get my original menu back, I just remove DISKBOOT and PS.fir from SD card.
So now I know I can experiment with my camera, and not damage anthing. So I did learn something today !!!
I'm really envious of all you people who have the Axxx models that can use all these wonderfull new features now that I know all the benifits I'm missing, I can only hope some day to see the A700 included in the list.
my best regards; Terry
szek
New MemberPosts: 21
Possibility of adding some manual settings to movie mode
In reply to GrAnd, May 23, 2007
Hi, would it be possible to override the video mode so that we could manually set shutter speed, aperture, iso, exposure compensation etc.
Any chances to unlock optical zoom and/or manual focus during movie shooting.
Any chances to get 640x480@60fps
Cheers and thanks for Your effort!
ursamajorRO
Regular MemberPosts: 251
videoclip
In reply to szek, May 23, 2007
Maybe when will be available the support for a Hard Disk (instead the memory card) for our cameras :))
Do you realise how much space should take a videoclip at 640x480@60fps?
Vit40
Regular MemberPosts: 269
Re: videoclip
In reply to ursamajorRO, May 23, 2007
VGA at 60 fps is not possible - sensor can return only 30 fps at this resolution
harvester
Contributing MemberPosts: 693
Re: An OOPS! function for Sokoban
In reply to stebu, May 23, 2007
as the Back key.
Cool, that's the right feature for me... I suck so much at Sokoban
How many moves can you undo? The last one, or more?
stebu
New MemberPosts: 12
In reply to harvester, May 23, 2007
Because I haven't found out the memory restrictions, I'm not sure what GrAnd will accept. I used 100 pushes, each push is stored as 5 integers.
Those 5 integers (160 bits) could easily be packed into one int (or less) if memory is tight.
Stebu
microfunguy
Regular MemberPosts: 234
Re: videoclip
In reply to Vit40, May 23, 2007
Does anyone know the sensors used by all the supported cameras and if PDF data sheets are available ?
I also want to check if all the supported cameras have orientation sensors as my calculations depend on whether the camera is held horizontally or vertically.
David
harvester
Re: videoclip
In reply to microfunguy, May 23, 2007
I found this quite some time ago in this forum. Don't know if this is reliable info or not:
A610
sensor ICX455 1/1.8"
sensitivity 250 mV
saturation signal: 500 mV
A620
sensor ICX489 1/1.8"
sensitivity 168 mV
saturation signal: 385 mV
S2
sensor ICX495 1/2.5"
sensitivity 150 mV
saturation signal: 420 mV
S3IS perhaps ICX624 ?
Vit40
Re: videoclip
some info can be found here --> http://www.riddle.ru/?page=articles/ccd
No info about 10 Mpix sensor from Sony though (A640). It may be sensor produced by Sharp, but in manufacturer's data it's said to produce VGA with 25 fps, while in A640 and G7 it seems to be true 30fps (unlike in some other digicams pruduced by other manufacturers, where every 5th frame is simply repeated, so video is choppy), so I don't know
Frank43
Senior MemberPosts: 1,912
Re: Possibility of adding some manual settings to movie mode
compensation etc.
shooting.
Which camera are you refering to?
The S3/S2 has exposure compensation, optical zoom and manual focus in movie mode.
Frank
Frank43
Yes I would love to have an undo.
However if you undo the pushes but not the moves, could'nt the user cheat?
Frank
szek
New MemberPosts: 21
In reply to Frank43, May 23, 2007
in movie mode.
Frank
Upss, sorry I forgot... Of course I was referring to those models that don't have these features (A6xx etc.). I believe that you can't change iso, shutter speed, aperture on S2/S3 too?
szek
New MemberPosts: 21
Re: videoclip @60fps (not that crazy)
640x480@60fps?
That would be 2x bigger than 640x480@30 = 3960KB/sec. which means 8 min. on 2GB card - pretty reasonable IMO.
GrAnd
Regular MemberPosts: 325
I'm not sure regarding the ISO, but the Av is dynamically adjusted during video shooting. And the shutter speed is constant which depends on video mode.
szek
New MemberPosts: 21
Re: videoclip
Probably that is the reason I find 30fps choppy on my A610 - that would make sense! So if 60fps is not possible then maybe reduction to 25fps would be reasonable then (paradoxically).
harvester
Re: videoclip
I don't think the videos of my A610 are choppy. Maybe you need a faster SD card?
szek
New MemberPosts: 21
But my initial point was about possibility of hacking that...
But my initial point was about possibility of hacking that (so we could manually set them).
Vit40
Re: But my initial point was about possibility of hacking that...
Nope. Shutter speed isn't constant, it can be 1/30 or shorter, depending on available light (evident if you examine .thm file, which is just a small jpg with full exif data)
szek
New MemberPosts: 21
Re: videoclip
faster SD card?
No, my card is OK (Kingston HS) but compering those allegedly fake 30fps to 60 (@320x240) I see the difference in smoothness. I always had this thought and now it just started to make sense. That description 'every 5th frame is simply repeated' looks like it.
