CHDK firmware hack discussion (8)
Started May 19, 2007 | Discussions
GrAnd
Regular MemberPosts: 325
Re: Some very basic questions
In reply to lowflyerguy, May 22, 2007
lowflyerguy wrote:
First, what exactly does "CHDK" stand for, or where did this
4-letter name come from? How does one pronounce it? (these may
sound like silly questions, but it seems easier to refer to it
metally as "check-disk" or whatever it stands for, rather than
"C-H-D-K").
Canon Hack Development Kit
HDK is pronounced like SDK or DDK.
The first letter 'C' was added recently to specify that this HDK is for Canon camera.
I pronounce it just in 'letter-by-letter' way: [siː]-[eɪtʃ]-[diː]-[keɪ]
I've got an A620. I've checked my firmware, and it shows up as
GM1.00F E18. I assume that it's the "F" part that matters, so I
figure I should be good to go. So I look on the download link,
and....I see this:
[snip]
Hmmm....what exactly do I download? These look like some sort of
test files, old files and fonts. It's not obvious which of these
(if any) are the goods I'm looking for. I'm guessing that I don't
need everything here....right? Can anyone direct me to what I need?
You have to download the file which contain your camera model and firmware version. In your case the file is:
test1-pre12-a620-100f-68.zip
The 'old' directory contain some previous build of CHDK;
'for_test' - is for highly experimental versions;
'fonts' - contain fonts which you can use for menu drawing and CHDK TextReader.
harvester
Contributing MemberPosts: 693
Re: suggestion - keyboard shortcuts
In reply to harvester, May 22, 2007
harvester wrote:
May I also suggest two other [half shutter press] keyboard shortcuts?
Another idea: let the user choose the shortcuts he likes, just like the "visual settings"> "colors" menu.
Maybe one could make a list of possible actions
-toggle histo
-toggle OSD
-toggle zebra
-toogle RAW
-start/end script
and after each list entry, there could be a drop down menu with available shortcuts (none, [half shutter]+[up], [half shutter]+[left], and so on).
harvester
Re: suggestion - menu sequence
And another idea (sorry... don't want to annoy you, I swear...
Maybe one could change the order in the CHDK main menu so that "scripting parameters" is the first menu entry, so that less clicks are required to get there.
Right now "RAW parameters" is the first menu entry and "scripting parameters" is the 5th entry. But "scripting parameters" (and "miscellaneous stuff") is the only entry I visit very regularly.
microfunguy
Regular MemberPosts: 234
Re: focus bracketing with CombineZM
harvester wrote:
CombineZ. I've tried it, and I have to say that I'm impressed.
Focus bracketing with the CHDK is a snap
Now do it in stereo
One way, for studio shots, is to move the camera sideways on a stepper-motor driven linear stage ... not difficult if you are 'into' that sort of thing.
For macro, you can place the subject on a turntable and rotate a few degrees.
You could control the stepper from CHDK by turning the LED on/off and taping an opto-receiver on top of it
That provides a pulse to the rest of the electronics.
GrAnd, does CHDK turn the LED on/off by directly accessing a particular memory location IN THE CAMERA and then performing lots of NOP's to create a delay ?
That is what the code suggests.
David
Mato34
Contributing MemberPosts: 882
Thanks to all!!
In reply to Mato34, May 22, 2007
In fact I haven't an S2, but a friend of mine.
I'm waiting for an A640, which has shipped today
Thanks again.
Un saludo!
Please, excuse my poor english...
microfunguy
Getting Camera Sensor size
In reply to GrAnd, May 22, 2007
microfunguy wrote:
On all the cameras CHDK works with, do they all have 1/1.8" sensors ?
harvester replied:
No, A710 and S3 have smaller 1/2.5" sensors.
Having now read all the source-code (apart from 'core'), the image width can easily be calculated with a simple function (such as 'get_sensor_width()' ) because the crop-factors are defined in CHDK for the various platforms:-
For A610 to A640, CF = 4.7946
For A710, CF = 6.0345
For s3is, CF = 6.000
Now I just need to read all of the 'core' code
David
lowflyerguy
Regular MemberPosts: 123
OK, got it. Installed and working.
Hallelujah, a battery indicator!!!
Thanks for the help.
bfollett
Regular MemberPosts: 472
GrAnd site down?
I was trying to get to http://grandag.nm.ru/hdk/ to get the S2 hack and got an error page that the requested url could not be found.
harvester
Re: GrAnd site down?
In reply to bfollett, May 22, 2007
Yes, it is down ATM.
Graystar
Veteran MemberPosts: 8,373
Re: CHDK firmware hack discussion (8)
I really like using the zoom control for manual focus on my A710. I noticed that when using manual focus all of the controls that used to be on the rocker are now on the zoom control. So the shutter, aperture, EV, even menu are also on the zoom control.
Since you can't keep the shutter, aperture, and EV on the zoom control all the time, I would suggest that, if possible, leave the shutter, aperture, and EV on the rocker control and only allow the manual focus to be controlled by the zoom lever, for nothing more than consistency in the interface.
Also, there is no way to zoom when manual focus is engaged. I would suggest that when the + - button is pressed to move away from the Manual Focus to another control, that you enable the Zoom on the zoom lever. I would imagine that such a change would fit in nicely with my first request.
Great work!
OptoZ
New MemberPosts: 4
Hi!
Thanks for the great features available by now.
So..for suggested features:
Would it be possible to get a full-display sized 100%-crop for preview in the manual-focus-mode via CHDK? (and setting the position it's taken from the
full-sized image)
OptoZ
harvester
In reply to OptoZ, May 22, 2007
full-sized image)
Oh yes, I've wondered about this, too. The normal function "MF-Point Zoom" is not that great for setting the focus manually... it would be cool to have a 100% magnification like in playback mode.
But I think it is not possible. I guess the CHDK can only work with the picture that the original firmware puts on the screen, and that is a very low-resolution one. It would certainly be possible for the CHDK to magnify the whole screen like the "MF-Point Zoom" function... but that would not increase the resolution and so it would look as ugly as the "MF-Point Zoom" function.
Graystar
In reply to Graystar, May 22, 2007
Hey, did the RAW indicator change? I used to see "RAW" on the screen in raw mode but with the latest build I don't see it anymore even though RAW is working. Was it changed to something else?
A710
test1-pre12, #68
manpower
New MemberPosts: 14
For FW GM 1.00F ??
In reply to solitare, May 22, 2007
Hi, where I can download the 1.00F DHDK version??
patochon
New MemberPosts: 15
Hi everybody
Just a little sugestion about this very good work you made, do you think it is possible to add a spot feature to the autofocus ? Cause it's a pity Canon don't made that and a very big problem when you really want to have a good focus on small objects with a big background.
GrAnd
Re: For FW GM 1.00F ??
In reply to manpower, May 22, 2007
manpower
New MemberPosts: 14
Thanks, sorry by my question, but I donĀ“t understand english well. Thanks.
OptoZ
New MemberPosts: 4
Do you think the magnified image in the ""MF-Point Zoom"-window
is nothing but a resized crop of the one on the display ? I am not sure.
When you focus via "MF-Point-Zoom" to a well defined edge and align
and compare it to the background, it does not seem to be just a 2 x magnification,since the aliasing that is visible in the background-image would come out more precisely than it does.Same about the noise.Maybe both
images - the permanent full-size image and the "MF-Point-Zoom"-crop are
from a third, common source...yeah, I know, sounds too nice to be true.
solitare
New MemberPosts: 5
Re: About S2
In reply to teeb, May 22, 2007
I just tried CHDK S2IS build 69 on my S@IS with firmware "GM1.00g" and it appears to be operational so I've installed the CHDK software on a dedicated corsair 133x 2GB SD card along with the Auto bootup and it works fine , at least with the features I tried. It does however force a relearning curve in manipulating the new menu system to work in conjunction with the standard firmware features though, but it souldn't take too long to get used to it.
All I can say is nice work, and keep the updates coming.
On another topic (not related to CHDK) however, I'm haveing ONE "H" OF ATIME POSTING / replying to this forum, when I try to reply I keep runing into the LOGON REGISTERED USER PROMPT OVER AND OVER AND OVER again, I CAN'T REPLY MOST OF THE TIME and I'm wondering WHAT THE "H" IS GOING ON. I have dpreview.com in my allowed list in IE 7.0 but it doesn't seem to matter. I've had to use an alternate ID and most of the time I get the LOGIN prompt , this time I un-expectedly make it through, and yes I have sent a feed back message to the powers that be , but never get a response !!!
Sooo until the next time I luck out and manage to get through, I'll be reading the threads and info here, I just won't have to ability to respond for whatever reason. YES IT PISSES ME OFF, because it's an ongoing problem.
Graystar
A710
test1-pre12, #68
Strange...on my 4GB SDHC card I get the "RAW" under the mode but on my new 2GB SD card I don't...I'll have to figure that one out.
