D200 underexpose in low light problem?
Started May 8, 2007 | Discussions
ddt332
Contributing MemberPosts: 742
May 8, 2007
I own a D200 and a D40. My D40 always over-expose, however when I set its exposure compensation to -0.7, it works just fine in most cases. On the other hands, my new D200 can normally give me near perfect exposure outdoor, but indoor at low light it is seriously under-exposed, normally I have to compensate +1.0 EV. It works the same with my SB400 TTL, still need +1.0 EV with SB400 flash.
I wonder is this normal or just me? Any comments here, please?
Randy Z
Senior MemberPosts: 2,551
Re: D200 underexpose in low light problem?
In reply to ddt332, May 8, 2007
Every photo you make is different. They have different values of light and dark, and different amounts. ANY meter, despite all the marketing hype, is just a suggestion. You learn that your camera meter on-average will behave in a certain way, and then you make adjustments. That's why you didn't buy a point and shoot.
Yes, the D200 meter is biased toward slight underexposure to save highlights. You can use your exposure comp (which for most is a constant fact of life in photography), or you can set the camera to invisibly always bump up a half stop or whatever you set it to (I can't remember what this is called in the manual) if you wish.
Z-Man
ddt332
ddt332 OP
Thanks for the comments!
In reply to Randy Z, May 8, 2007
Jeff Klofft
Veteran MemberPosts: 3,541
I have mine set to +1/6 all the time
Jeff
Check out my gallery at http://www.jkphotogallery.com
Keith Helms
Regular MemberPosts: 138Gear list
It depends on what effect you're after. I was in Carlsbad Caverns last week and I had to set exposure compensation to between -1 and -2 for a lot of the shots. If I didn't, the camera tried to increase the exposure to compensate for all the dark rock around the spotlighted areas. Then the spotlighted areas ended up getting blown out.
 Keith Helms's gear list:Keith Helms's gear list
Nikon D600 Nikon D7200 Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Nikkor 16-35mm F4G ED VR +6 more
Mario
Senior MemberPosts: 2,648
Learn how cameras meter a scene...
and you will understand why it happens and you'll be able to predict exactly when it will happen.
If you have very reflective surfaces in the scene, they might not look bright, but when you shine light on them with flash, they reflect a good potion of the light back. Camera actually fires pre-flashes to meter exposure and what it sees is a very bright area in the scene, and hence compensates exposure to avoid blowing it out. The bigger the area the bigger the "underexposure" of what you may think of as main subject.
So, learn to recognize luminance values of stuff in the scene and you will meter better than a camera.
Mario
eolian
Regular MemberPosts: 270
Re: I have mine set to +1/6 all the time
In reply to Jeff Klofft, May 8, 2007
Jeff Klofft wrote:
Jeff
How do I do this?
Clark Hampton
Senior MemberPosts: 2,856Gear list
mine is the same but...
in underexposes but I don't see it as a problem. I compensate for it. WIth flash however I get dead on exposures
 Clark Hampton's gear list:Clark Hampton's gear list
Nikon D100 Nikon D200 Nikon D800 Nikon AF Nikkor 85mm f/1.8D Nikon AF Nikkor 135mm f/2D DC +4 more
Koanut
Contributing MemberPosts: 708
Re: mine is the same but...
In reply to Clark Hampton, May 8, 2007
Also, learn to use your histogram in setting exsposure...
'Once in a while, you get shown the light
in the strangest of places if you look at it right...'
WSSA Member #80
ddt332
ddt332 OP
In reply to Koanut, May 9, 2007
Hi:
I check the histogram after every shot I took. However my point was IF this is a popular problem for D200, Nikon should easily adjust it, right? My D40, for example, does an amazing job as long as you set your EC to -0.7. It is very consistant in different situation.
WSSA Member #80
