self focus adjust
Started Feb 11, 2007 | Discussions
M.S. Shin
New MemberPosts: 4
self focus adjust
Feb 11, 2007
Hi,
I have big news!
If your K10D have problem with focus, you can adjust it yourself.
Someone in Korea figured it out himself.
He is not a employee of Pentax or related company.
He just found out by trial-and-error with key-set.
Of course, You yourself is responsible for doing something scribed below.
Here's How-to-adjust-focus.
1. Your K10D' firmware version must be 1.10.
2. Test shot for focus trouble.
3. Turn the camera OFF.
While pressing [PLAY]+[OK], Turn the camera ON.
You can see firmware version on LCD screen.
4. Firmware version is appeared,
then press [Fn]-> [Fn]-> [INFO]-> [MENU] within 5 seconds.
You get service menu!!!
5. by pressing [right key]
,Make DEBUG MODE to DEBUG MODE .
then press [OK].
(save and LCD will be black out)
6. Press [MENU] and go to SETUP tab.
then, Press [Up key], you can see TEST MODE.
7. Select AF TEST menu. now you have AF correction menu.
If you have Front-focusing, reduce the value.
If you have back-focusing, increase the value.
after adjust some value, press [OK] and quit out of setup menu.
8. TEST for focus, find out that focus is correct.
(repeat this from 6 for correct focus.)
9. Go to service menu(step 3,4).
then press [OK].(save and LCD black out)
10. Go out and enjoy nice photos!!!
AGAIN, You yourself is responsible for any damage or trouble by doing this process!!!!!!!!!!!!!
sir_bazz
sir_bazz MOD
Senior MemberPosts: 2,128Gear list
Wow
In reply to M.S. Shin, Feb 11, 2007
Thanks for posting that!
I'm sure there's a number K10D owners here who are likely to tinker with this. Most of them just out of curiosity
bazz.
 sir_bazz's gear list:sir_bazz's gear list
Pentax *ist DS Pentax K-5 Pentax smc FA 50mm F1.4 Pentax smc DA 40mm F2.8 Limited Pentax smc FA 31mm F1.8 AL Limited +2 more
RodConn
Contributing MemberPosts: 847
Absolutely WOW
Many thanks for passing this on.
I have to try this - with extreme care :))
Rod
roybin
Regular MemberPosts: 154
Re: self focus adjust
wow!!!
This is real. I just tried on my k10d. I did find the debug mode and that AF focus calibaration setting. I have not tried to ajust the value yet. I may do it after I carefully and completely confirm my frontfocus probelm.
This is amazing I have to say. Thans OP.
nevada5
Veteran MemberPosts: 7,548Gear list
In reply to roybin, Feb 11, 2007
Thanks for the info. Could be invaluable to many here.
Larry G.
http://www.gevertphotography.com/
Still trying to break into nude photography but every time I take my pants off some jerk calls the cops.
 nevada5's gear list:nevada5's gear list
Nikon Coolpix P330 Samsung NX500
Craig Jewell
Senior MemberPosts: 1,182Gear list
Mmmm..
There are a few interesting things on that menu, like being able to save the EEPROMS to your card. Potentially useful in the event of you wanting to roll back you bios (provided you backup before you update). Looks like you could also adjust the AF points if they are out.
 Craig Jewell's gear list:Craig Jewell's gear list
Panasonic Lumix DMC-TS3 Canon EOS 5D Mark II Pentax K10D Canon EOS-1D Mark IV Canon EOS M +24 more
Joseph Tainter
Veteran MemberPosts: 9,190
Hmmm. Where's the Easter Egg?
Joe
Perry Pellechia
Regular MemberPosts: 242
Hot stuck Pixel remapping?
Anyone find a submenu for hot/stuck pixel remapping? I would suspect that is is there somewhere but I could not find it.
attilladanko
Forum MemberPosts: 60
I just my fixed my slight backfocus. Kewl.
Ralph E Napier
Regular MemberPosts: 186
IST DL?
Any info on a debug mode for the ist DL?
Camera-carrying member of the Pentax Club, with *ist DL, 18-55 kit, smc A50 f/2, JCPenny 80-200 w/ vivitar 2X converter, Pheonix 100-300 KAF, AF280T flash, 16 AA's, Sandisk ultra 2 plus USB 1Gig card.
Yes, I carry all of that. Everywhere.
insulglass
Senior MemberPosts: 1,024Gear list
In reply to attilladanko, Feb 11, 2007
Well, I just confirmed that this particular sequence doesn't work on a DL.
Anyone have any suggestions? Just curious if anyone has gotten to a "debug" menu on a DL.
 insulglass's gear list:insulglass's gear list
Nikon AF-S Nikkor 24-70mm f/2.8G ED +1 more
jthommo
Veteran MemberPosts: 3,735
Thanks M S Shin
could come in useful
Thommo
http://www.flickr.com/photos/jthommo101/
peekapoo
New MemberPosts: 9
well..you might want to be careful posting this in public forum.
I heard that pentax and affilate company in korea may sue this guy
for revealing their 'secrest' in public.
The guy deleted original post in korean pentax forum after he got threatened by pentax and its affiiate company.
I don't know if they can sue this guy for that, but thats what they say
they would do.
I am sure pentax is monitering this forum too. So, be careful...
Ralph E Napier
In reply to insulglass, Feb 11, 2007
on a DL.
same here... i tried it on mine.
Anyone?
escobar
Veteran MemberPosts: 4,942
Wow! very useful.
I would suggest to anyone interested in this to save a copy of this info, not just a bookmark.
Kristian Farren
http://kf3.net
lak
lak
Contributing MemberPosts: 998
In reply to peekapoo, Feb 11, 2007
I can't believe that this is true. This is simply a service menu or a debug mode. How can they call it a secret if it can be activated by just a few keystroke?
The service menu of my Optio, my TV and my cable TV PVR are all revealed in various forums. And people access the TV's service menu to do fine calibration. So I just can't see Pentax can sue anyone for this at all.
Cideway
Veteran MemberPosts: 5,702Gear list
In reply to lak, Feb 11, 2007
Business secrets, and the fact that it also allows direct access to proprietry information, it allows you to down load the entire camera firmware to a SD card, very handy for anyone wanting to reverse engineer it.
Fanboy, and proud of it...
GMT +9.5
 Cideway's gear list:Cideway's gear list
Pentax K-5 II Pentax K-3 Pentax smc FA 50mm F1.4 Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA* 50-135mm F2.8 ED (IF) SDM +2 more
Voe
Voe
Contributing MemberPosts: 507Gear list
In reply to Cideway, Feb 11, 2007
Well, the latest firmware is publicly available for download anyway.
GMT +9.5
 Voe's gear list:Voe's gear list
Sony Alpha 7 II Sony FE 35mm F2.8 Sony FE 55mm F1.8 Zeiss Batis 25mm F2
lak
lak
Maybe secret to us consumers, but big players would be able to find out about this without any problems, or they could take apart the camera if there is anything they want to find out.
And the firmware is already downloadable from all the official Pentax web sites, you don't need to get it from the camera or with this service menu
escobar
did you read the steps required to get to the debug mode? There is no way that someone could get into it just by playing around. My guess is that somebody spilled some inside information.
Kristian Farren
http://kf3.net
