RAW + Basic - writing 2 JPGs
Started Feb 4, 2007 | Discussions
Dave H
Dave H New Member • Posts: 21
I've just starting looking at RAW, and have the following problem. If I choose RAW (only), the camera (D50) writes a "NEF" file, around 5 Mb. If, however, I choose "RAW + BASIC", it writes 2 small JPGs (about 650 Kb), and no "NEF" file. What am I doing wrong? Or is it a fairly serious problem with the camera?
Thanks for any suggestions,
Dave.
ToeKnee44
ToeKnee44 Contributing Member • Posts: 821
Re: RAW + Basic - writing 2 JPGs
I am assuming that after you download pictures to your computer, you
are finding the two JPGs and no NEF. Is that correct?
Are you using a program to transfer the picts to your computer?
If so, what program?
I am suspicious that the problem may be caused by software, not by
the camera itself.
ToeKnee44 (aka Tony)
'If we cannot end now our differences, at least we can help make the world
safe for diversity.' John F. Kennedy
sillyconguru
sillyconguru Veteran Member • Posts: 3,057
Change the camera's transfer mode to from "PTP" to "Mass storage" (or is it the other way around? ;)). Better still, get a card reader.
 sillyconguru's gear list:sillyconguru's gear list
Casio QV-5500SX Pentax Optio I-10 Fujifilm FinePix X100 Canon ELPH 100 HS Fujifilm X20 +54 more
Dave H
Dave H OP New Member • Posts: 21
Thanks for this suggestion, which I'll try, and report back. It's when I look at the camera in "My Computer" that I'm seeing the 2 small JPGs on the camera (i.e. before downloading them). But, when I look at the file information on the camera's screen, it says that the pics are "RAW + Basic".
REBlue
REBlue Senior Member • Posts: 2,002
Well, what do you get when you actually download the files?
 REBlue's gear list:REBlue's gear list
Nikon D50 Nikon D200 Nikon D300 Nikon AF-S DX Nikkor 35mm f/1.8G Nikon AF-S DX Nikkor 17-55mm f/2.8G ED-IF +5 more
Thomas Comerford
Thomas Comerford Veteran Member • Posts: 9,745
No, you're just seeing what Windows is telling you. Windows doesn't understand what a NEF file is but it can see the JPEG that is embedded in it (even if you just shoot raw, a full-size JPEG will be embedded in the file), and it is showing you that instead.
Change the camera's USB mode to "mass storage".
bedde
bedde Contributing Member • Posts: 699
I think you should download the latest version of the software or try Capture NX.
I once had a problem opening NEF files. Got some error message saying the file format was not compatible with the supplied software.
I posted a thread, and one use suggested upgrading the software to the latest version or try using the latest version of Capture NX.
And it worked!
Hope this helps.
Thanks in advance for your replies.
Bedde
DX6490
Sunpak 383
winnie
winnie Veteran Member • Posts: 4,219
Definately to do with the Mass Storage setting
This has been mentioned before on here but for a D200.
As mentioned by a couple of other people on this thread, change the mode to Mass Storage and you will see the correct NEF + JPG.
Alex
http://www.alexwinserphotography.co.uk
Dave H
Re: Definately to do with the Mass Storage setting
Perfect! Thanks to everyone who responded.
Relieved,
Dave.
