28mm dot on Sigma zooms
Started Jan 29, 2007 | Discussions
kirbysdl
Regular MemberPosts: 108Gear list
Jan 29, 2007
On my Sigma 17-70, there's a little dot on the barrel's focal length scale at 28mm. There's also one on the 18-200 lens, and other Sigma DC zooms print the actual numbers instead of using a dot. Why is 28mm so important? On a Canon 1.6x sensor, its 35mm film equivalent length is only 44mm, so it's not even an indicator of the "standard film" 50mm view.
 kirbysdl's gear list:kirbysdl's gear list
Canon EOS 70D Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-200mm f/4L IS USM Canon EF 35mm f/2 IS USM
SNGX1327
Veteran MemberPosts: 5,186
Re: 28mm dot on Sigma zooms
In reply to kirbysdl, Jan 30, 2007
not sure. on the canon kit lens, 28mm is marked as the focal length where the lens is the shortest physically. that particular lens extends when zoomed to any of the extreme focal lenghts
nickleback
Forum ProPosts: 11,111
28mm is the approximate diagonal of an APS-C sensor.
Standard view on a camera is where the diagonal measure of the capture medium equals the focal length. 35mm diagonal is 43.3mm, pretty darn close to 44mm. 50mm is used as the "standard" lens on most SLRs because that's about the shortest near-symmetrical design you can do on a 35mm SLR, which makes it inexpensive.
Seen in a fortune cookie:
Fear is the darkroom where negatives are developed
kirbysdl
In reply to nickleback, Jan 30, 2007
A-ha, very concise. So I guess the reason old 35mm film cameras came with 50mm kit lenses is because 35mm lenses were too expensive to make well.
Thanks!
nickleback
to make well.
The true normal for 35mm format is 43.3mm, so substitute "43 or 44mm lenses" for "35mm lenses" in your statement above and it is correct.
Thanks!
You're welcome!
strikeback03
Senior MemberPosts: 2,892
except...
lenses from long before digital also have the dot. Here is an EF 24-85 originally marketed in Sept 1996.
nickleback
Re: except...
In reply to strikeback03, Jan 30, 2007
Lack of space to write 28? Beats me. I was just commenting on 28 actually having a little bit of significance. Don't know if that's why it is a dot on the barrel.
strikeback03
Re: except...
I'd assume that for whatever reason it is just tradition to mark 28 - if the numbers don't fit then with a dot. Also I don't believe it is the point of minimum extension on the kit, IIRC mine was shortest at around 33mm.
http://www.linelight.org/
kirbysdl
Re: except...
Yeah, the 17-70 is shortest at 17mm grows continuously until 70. Thanks again for all the replies. I'm gonna shoot a bit at 28mm so I can grow accustomed to what a 28/30mm prime should look like.
