D200 Batteries - 3rd Party or Nikon
Started Jan 10, 2007 | Discussions
MindInRewind
Contributing MemberPosts: 601
Jan 10, 2007
just wondering if people would recommend any 3rd party batteries for my D200 or should i go with nikon? right now i just see (on http://www.vistek.ca )
Lenmar NoMEM Li-Ion NIKON EN-EL3 7.4V 1400mAh
which is $30 cheaper than the nikon battery. anyone have any suggestions?
thanks
MIR
MTT
MTT
Veteran MemberPosts: 4,953
Just me,
In reply to MindInRewind, Jan 10, 2007
but I would try aftermarket. I have two for my D70 [not this brand] and they both out performs and out lasted my nikon battery. Was not happy with my Nikon.
But that just me,
Mark
suggestions?
thanks
MIR
Church Event Photographer
Full time auto tech, part time photographer. Just wished it were the other way around. Mark Thompson/MTT
Louisville, KY. USA
http://mtt.smugmug.com/
MTT
MTT
But,
In reply to MTT, Jan 10, 2007
The Nikon is 1500 mAh and the aftermarket 1400 mAh, you may get less shots. At least with my aftermarkets, I gainned 100 mAh.
Mark
But that just me,
Mark
suggestions?
thanks
MIR
Louisville, KY. USA
Louisville, KY. USA
Devendra
Veteran MemberPosts: 3,583Gear list
try this..
got 3 spares from them.
http://www.newworldvideodirect.com/productdetail.asp?productid=2138
rated at 1900mah, and have a 5yr warranty.
Works well with my mb-d200 grip. it is certainly not OEM, but definitely 40% cheaper. Occasional low battery indicator in my other D200 - havent diagnosed it fully.
suggestions?
thanks
MIR
use DXKA303DH for 70 off @ dreamhost
 Devendra's gear list:Devendra's gear list
Nikon D200 Nikon 1 J1 Nikon D800E Sony Alpha NEX-3N
aerosolcheese
Regular MemberPosts: 378
Re: D200 Batteries - 3rd Party or Nikon
I have 4 total genuine EN-EL3E batteries for my D200. Aftermarket batteries were not available at the time. If they were, I certainly would have purchased them because I had some inexpensive generic EN-EL3's for my D100 that totally outlasted my genuine Nikon battery.
MindInRewind
Re: But,
what brand are your aftermarket?
MIR
MTT
MTT
Not sure,
but will check tonight & let you know then. They both came from Best Buy's.
Mark
MIR
Louisville, KY. USA
MindInRewind
Re: Not sure,
thanks mate, ill check back later. i really appreciate it!
MIR
william cooper
Forum MemberPosts: 76
I prefer using the optional AA battery grip available for the D200. You can get alot of shots on a set of lithium batteries and don't have to worry about recharging in the field, particularly if you are in an area where no electrical power is available.
William Cooper
wildencountersphotography.com
smithrs
Regular MemberPosts: 151
In reply to william cooper, Jan 10, 2007
Can't see the point of spending thousands on a pro spec camera and top rate glass only to cut corners and risk invalidating warranties with generic brand batteries. I note that many batteries can be the subject of recalls. Who recalls a generic battery purchased from who knows were and made by who knows who.
By the nikon and at least have peace of mind.
Ed Kopicki
Regular MemberPosts: 223
In reply to smithrs, Jan 10, 2007
Very true.....Purchase the Nikon
a few years back I picked up three extra third party batteries for my CP5000(battery hog). In Disney I discovered two of them would only charge to half.
Sometimes you get what you pay for..........in my case two for one.....
Never again......
Kind Regards
Ed
Karl H. Timmerman M.A.J.D.
Veteran MemberPosts: 5,056
I bought an extra from http://www.batterybarn.com/enel3e.htm , $39.95. It lasts longer than the Nikon, (1700mAh) and uses the Nikon charger. I have been most happy with it.
Regards
Karl
http://www.karltimmerman.com/ramblings
'The best part of taking the moral highground ...... is the view'.
Brownie_Bear
Regular MemberPosts: 240
You can get the Nikon battery on Amazon for $40. Why risk your $1500+ camera to save $20-$30. I would buy the Nikon one.
Mike
I never have taken a picture I've intended. They're always better or worse. - Diane Arbus
MTT
MTT
Batterys,
In reply to MindInRewind, Jan 11, 2007
Here’s the two, one is made by Hi Capacity Power Products and is a 1400mAh. The second is made by Digipower and it is a 1300mAh. I didn't realize that the Nikon battery is also a 1400mAh, but did not out perform the 1300mAh. I bought the Digipower at the same time I bought my D70 almost three years ago. The Nikon battery doesn't do well any more, I'm lucky to get 100 shots from it. Compare to 400 from my aftermarket. When my Nikon was new, I was lucky to 300 shots from it.
I do want to add, my Hi Capacity Power Product battery did fall a part. They didn't do a very good job gluing the two halves together. A few drops of super glue took care of that.
Good Luck,
Mark
MIR
Louisville, KY. USA
MindInRewind
In reply to Brownie_Bear, Jan 11, 2007
thanks for the heads up, everyone. very appreciated. i know what you're saying. ill rethink my finances and see what i can do (im a gear head who only works twice a week - hrm... toys + little work = i window shop every day :P)
thanks again
MIR
MindInRewind
Re: Batterys,
In reply to MTT, Jan 11, 2007
thanks for double checking the names for me.. ill have a look around.
MIR
fraserj1
Senior MemberPosts: 2,565
suggestions?
So you spend between $1300 and $1700 on a camera and you're going to cheap out on the battery? Not a good idea.
I would opt for the Nikon just in case. If the battery blows up, you have more of a leg to stand on if it was a Nikon brand battery that did the damage.
MrPhotoBob
Senior MemberPosts: 2,887Gear list
In reply to smithrs, Jan 11, 2007
I am going to have to go along with that also. Why spend all of that money on your main equipment and then try and save $5 or $10 on a generic battery. I have 2 D200 cameras and both of them have Nikon batteries in them. I feel the very same about printers, people go out and spend all of that money on a nice printer and then complain because they can not afford the ink for it.
 MrPhotoBob's gear list:MrPhotoBob's gear list
Olympus E-M1 Olympus E-M5 II Olympus M.Zuiko Digital ED 60mm 1:2.8 Macro Olympus 12-40mm F2.8 Olympus 40-150mm F2.8 Pro +2 more
Greg Terzian
Senior MemberPosts: 2,382
Logic: Spend $1800 on a camera and who knows how much on lenses, only to cheap out on batteries.
I would play it safe and use Nikon.
suggestions?
thanks
MIR
Tom Moerel
Regular MemberPosts: 405
Does anyone here ever consider that there are people out there that do not make lots of money. People who want to have a good tool for their photography but have to severely stretch their budget to buy a D200. People who use cheap glass because those ridiculously priced pro lenses are way out of their reach......people who cannot afford overpriced Nikon batteries.....
Well, perhaps those people have no choice and they buy aftermarket. And please don't tell me they shoud have bought a cheaper camera......would you want to play with one of those plastic toys after holding a D200
