Day to night - a mini tut for beginners on up
Started May 23, 2006 | Discussions
unknown member
(unknown member)
May 23, 2006
These are steps to turn day to night and put lights in windows. I’m using Steve's picture here:
http://forums.dpreview.com/forums/readflat.asp?forum=1006&thread=18520429&page=1
I will take very short steps so as not to lose people with relatively little experience in PS (this may be a bit tedious for more advanced users). Begin with this portion cropped out of Steve's pic.
Create a new layer (I'll name it "black night"), fill with solid black, leave blending mode as "normal," and reduce opacity to around 78%. Use your eye here. It should look pretty dark, about like this:
On top of that, create a new layer ("window 1") and change blend mode to hard light.
Here's what you should have in the layers palette:
Zoom in on the window to the right of the door. Using the polygonal lasso with no feathering, select the window.
Choose a round, soft brush (if you're not sure about the "soft" part, check your help files under Brushes). Note the settings underlined here. They're approximate but are a good place to start.
Choose a muted yellow color. Here's what I picked. Experiment with colors and don't use the same color for all windows.
Using horizontal strokes and working from the bottom, paint in the window so it is brighter at the bottom than at the top. Three to five strokes should do it. Here I let it fade out at the top so it would look like a lamp set low behind the window. You should get something like this. (Remember, I'm zoomed in close. That's why the image looks so choppy.)
While you're still on that hard light layer, one little refinement that is especially good for windows that show a lot of detail in an image. Use the eraser to knock out the muntins (the wooden sticks that separate the individual window panes). Set the eraser to 1 px, hard edge, 100% opacity. If you don't know this little trick with brushes, here's how to do it. Click at A and release. Move the eraser-brush to B, hold down SHIFT, and click again. This will erase along the dotted line from A to B. This works for all brushes -- painting, erasing, smudging, etc.
After you knock out all three muntins (two horizontal, one vertical), you should end up with something like this:
You can use this basic method to put lights in most windows. The settings I've used here are just approximations, what looked right to me on my monitor in my current mood. Experiment, experiment, experiment.
RayGuselli
Forum ProPosts: 14,192Gear list
May I be the first
In reply to Peano, May 23, 2006
to say many thanks Peano.
Just copied and pasted as a superb point of reference.
Great tutorial - very grateful.
Best wishes
Ray
 RayGuselli's gear list:RayGuselli's gear list
Nikon D700 Nikon D300 Nikon D750
cspringer
Forum ProPosts: 19,632
Great info...thanks!...nt
Steve's pic.
like this:
mode to hard light.
experiment.
GlobalTvlr
Senior MemberPosts: 2,061
Re: Day to night - a mini tut for beginners on up
Thanks, this is a keeper.
Best,
Chris
SBriggs
Contributing MemberPosts: 837
Thanks Peano.
I made a PDF of your tut and with your permission would like to make it available for download here.
Sam
Zorpie
Senior MemberPosts: 2,836
Thanks for sharing.
Hello Peano,
Great tutorial - and a great effect. Thanks for taking the time to sit down and prepare the 'how to' description - I'll look forward to Part 2 !!
Zorpie
pbase supporter
Shuk
Regular MemberPosts: 274
Peano,
THANK YOU so much for this tutorial, you have made my day a lot happier!
It is very kind of you to share your time, expertise and efforts.
I deeply appreciate this, and I'm sure many others will too !
I've said it before and I'll say it again without hesitation -
You are an extremely kind, talented and gifted person.
Thanks again, I'm in debt to you.
I'll get to work on this now I know the right way.
Best Regards
Steve H.
unknown member
(unknown member) OP
In reply to SBriggs, May 23, 2006
SBriggs wrote:
Thanks Peano.
Sam
Certainly. Help yourself.
Scott Deardorff
Senior MemberPosts: 1,100Gear list
Thanks, Peano. As you know, I enjoyed your Cambridge day/night conversion. Good job of explaining this.
Scott
cspringer
One suggestion
In reply to cspringer, May 23, 2006
instead of a black layer at 78% make a Hue/Saturation Adjustment layer. You can darken the Lightness slider which will give the same effect as a black layer or you can click Colorize, make a dark blue or whatever you like and desaturate, darken. You also have the mask to bring back the buildings.
Steve's pic.
like this:
mode to hard light.
experiment.
unknown member
(unknown member) OP
Re: One suggestion
Yep, that'll work. Good suggestion. The main thing is to have the "night" on its own layer so you can turn it off to search out details in the image, then turn it back on to see your lighting effects.
unknown member
(unknown member) OP
Re: One suggestion
effects.
Another point worth noting. Whether you use a solid black layer or a hue/sat adjustment layer, you might not want the darkness to be uniform over the whole image.
For instance, in Steve's pic, I wanted the moonlight to show on some of the walls while others stay in shadow. To get that effect, I erased the black layer at low opacity where I wanted to lighten a bit. You can do the same thing on a hue/sat layer by painting on the mask with white at low opacity.
SBriggs
Here's a link to the PDF file...
cspringer
Re: One suggestion
I thought you had added a mask to the black layer vs. the eraser tool.
They can be addicting!
effects.
unknown member
(unknown member) OP
Re: One suggestion
lol ... no, I just used the eraser, though I do have the layer mask addiction. I really like your idea of using a hue/sat adjustment layer instead of solid black. I filched this image from the Panasonic forum
( http://forums.dpreview.com/forums/read.asp?forum=1033&message=16350725 )
to see how a blue hue would work on a snow scene. This would be a great way to make a Christmas card of a house in winter.
Kent C
Forum ProPosts: 25,803
Thanks Peano, Sam....
To the archives with this one. Sam, I assume that the pdf will only be available for a certain time period, correct? Thanks.
Kent
http://www.pbase.com/kentc
For prior discussions on most questions:
http://porg.4t.com/KentC.html
or d/l 'archives' at:
http://www.atncentral.com
cspringer
Re: One suggestion
looks good. There's a Ulead Particle plugin that has a snow filter you might want to check out.
Panasonic forum
Wilkev
Veteran MemberPosts: 3,711
Yes, Thanks Peano and Sam (nt)
Bill
chas3000
Regular MemberPosts: 241
Excellent!!
thanks for posting Peano and thanks for the pdf Sam!
woofw
Contributing MemberPosts: 665
tnks guyz for all the imput you've given us
In reply to chas3000, May 23, 2006
woofw
