Minolta 28mm - - f2.0 or f2.8
Started Oct 21, 2005 | Discussions
kdp
kdp
Junior MemberPosts: 35
Oct 21, 2005
I would like to purchase a 28 prime.
Other than the obvious stop difference....
any pros or cons to either?
B&H has the 2.0 at $400... the 2.8 at $200.
have a good weekend.. see you monday
thank you
kent
andrewD2
Veteran MemberPosts: 8,467
Re: Minolta 28mm - - f2.0 or f2.8
In reply to kdp, Oct 21, 2005
The 2.8 is very cheap secondhand, its a good lens.
One nice thing about the old 28/2.8 is 49mm filters which makes a polarizer very affordable.
I'd love a 28/2 of course.
Andrew
theswede
Veteran MemberPosts: 3,936Gear list
I have the 28 F2.0, which I got on eBay for under $200 with one year warranty, factory refurbished. It's a very nice lense; on my 5D it will easily focus on static subjects in mood indoors lighting. I'm very happy with sharpness and clarity, and I routinely use it at F2.0 for low DOF and low light photography. AF is fast and accurate; not USM fast obviously, but for a normal "screw driven" lense it does an admirable job. If the focus change distance is short, it's just as snappy as a USM lense, but if it has to hunt, it takes a while.
I hope to be able to put together a more comprehensive subjective review with some photographs later. I haven't had the opportunity to compare it to the 28 F2.8, so can't say much in relative terms, but it's a very nice lense.
 theswede's gear list:theswede's gear list
Fujifilm FinePix X100 Konica Minolta Maxxum 5D Sony SLT-A37 Sony 50mm F1.4 +2 more
gnet158
Senior MemberPosts: 2,273
Second hand you should be able to pick up either for ½ of what you’re looking at. I have the f2.8 version of this lens and it’s sharp, provides great color, and focuses fast on my Maxxum 7. The f2.0 version is better (on paper), whether you’ll notice the difference is another story. It’s just like the Minolta 50mm, the f1.7 is sharp enough for me but I’ve never used the f1.4 either. Good luck!
ab012_KM7D
Senior MemberPosts: 2,644
In reply to kdp, Oct 22, 2005
filter size 55 vs 49 - pro/con depending on your other lenses. A fair number of Minolta lenses have 55mm eg (off the top of my head)
28/2
50 1.4 new
100 Macro
135 2.8
70-210/4
Bernard
AS rocks!
lens reviews and more on dyxum.com!
theswede
In reply to ab012_KM7D, Oct 22, 2005
Also the 18-70 kit lense for the 5D.
dcap
Contributing MemberPosts: 999
I have both, f2.8 for testing/review
The New/RS version of the 28/2 has a circular aperture blade, and this would ge my vote for the smoothest, nicest bokeh. I want one, I have the original which is very sharp. VERY.
f2 price looks LOW if its new??
(converts to GBP 226, new in the UK it is: GBP499, used UK is: GBP 200)
f2.8 price is far too high. Its a US$50 used lens and its the 2nd most common used prime on eBay after the 50/1.7
and you, happy shooting everyone
My money would be on the 28/2, its sharper than the 28/2.8, but quite a bit more expensive. A super narrow depth of field f2 lens is a bit silly as a wide angle, you don't really see its narrowest, not as much as you do with a 85/1.4 for example, or a 100/2.
Sample shots from both 28s - coming soon - on http://www.MaxxumEyes.com
kdp
kdp OP
In reply to kdp, Oct 24, 2005
Thank you gang... Appreciate you comments. I'm leaning strongly to the 2.0.
Thanks again
Kent
Monte920
Regular MemberPosts: 153
Have you noticed that the picture used by B&H for 28mm f2.0 is an old version? That is, metal lens body rather than rubber-polycarbonate body used in the new version. I wonder what version B&H is going to shiip to you if you buy it. I checked the KonicaMinolta official USA site and found both f2.0 & f2.8 28mm were not listed in their lens line up. Is there any possibility that Minolta has stopped producing these lenses?
monte
ab012_KM7D
In reply to Monte920, Oct 25, 2005
AFAIK they are both still in production according to the Japan site (which is actually much more up to date)
Bernard
AS rocks!
JL-photo
Regular MemberPosts: 477
Still in USA
