Very interesting discovery about (D) and non (D) lenses
Started Apr 20, 2005 | Discussions
Dalibor J
Regular MemberPosts: 145
Apr 20, 2005
Hello,
I would like to share with you my latest discovery,
which I think is very interesting one.
As you probably know Dynax 7D does not store the
information about focus distance into EXIF (SubjectDistance)
which is strange as the older models 7i..A2 did it.
This information is neither stored in MakerNote Camera Settings tag.
I thought that Minolta engineers decided to keep
this information private for some reason and I did
really miss it. This information could be quite useful
for various purposes, for example DxO software needs it to correct
lens distortions, it could be used by panorama software
and it will be very good for back-focus-problem hunters.
I was pushed by Mladen (www.dyxum.com) to try to search
for this info once more and it seems that I have found it this time.
I will try to release a new version of Dalifer soon
so all of you will be able to get this information from
your JPEG or MRW files.
And now comes the funny part. Let me start with simple question.
Q: What is the difference between (D) and non-(D) lens?
A: That's easy. (D) lens does report the focus distance
back to camera so it can use it for ADI flash (and maybe AS as well).
The reason why I have failed to find the focus distance value
few weeks ago was that I was trying to compare the data from
the picture taken with (D) lens to the picture taken with non(D) lens.
I was looking for something which is present in the first one
but absent in the second one. But I have no additinal information.
I have taken a different approach this time and I have managed
to find the place where the distance information is stored.
So I have tried to take some test shots with my 50/1.4 nonD lens
and I have found the distance information there as well!
Very interesting and confusing at the same time.
So let me repeat my original question.
A: Ehmmm. I really don't know. Anyone else?
Dalibor
CAClark
Senior MemberPosts: 2,817
Re: Very interesting discovery about (D) and non (D) lenses
In reply to Dalibor J, Apr 20, 2005
Perhaps it's to do with specific and slightly differing distance data to be shared with the attached flashgun?
Cheers!
Craig A Clark
Lightwave 3D Modeller
Hard Surface
The Indestructible Production Company Ltd
Stanley Kubrick Building
Pinewood Studios
Iver Heath
Bucks , SL0 0NH
Mob: 0779 5595016
http://www.pbase.com/caclark
http://www.f-nine.co.uk/
ab012_KM7D
Senior MemberPosts: 2,644
Excellent Discovery!
Well done!
Bernard
KM7D - fantastic photography tool !!!
Lazar
Regular MemberPosts: 114
Re: Excellent Discovery!
In reply to ab012_KM7D, Apr 20, 2005
I don't think the answer is important. The data you want is there. Good done. Reverse engineering is beauty work. I think to be fair you could talk with KM to be sure about your discovery.
Dalibor J
Flash?
In reply to CAClark, Apr 20, 2005
I am sorry, but I do not understand your answer.
The focus data is known even for non (D) lens and
it does not matter if the flash is attached or not.
The communication with the flash is done by the camera
not directly lens-to-fash.
Dalibor
Dalibor J
In reply to Lazar, Apr 20, 2005
Maybe it is not that important. But still I would like to know
why Minolta tells us to buy (D) lens to use the benefits of ADI flash metering,
when the non-(D) lens provides the same data.
I really doubt that someone will reply anything meaningful.
I have tried to communicate with Minolta few times already
wit no success.
Dalibor
Lazar
Hi Dali,
Saying that you have the focal distance for non D lens, is not connected to the idea of using this data...
If KM says that D is used , so it is, even not available in the EXIF. EXIF is only for dumping out data for the user or some extraterestial software that can use it to change the parameters as much as possible for the shot.
Magnus W
Contributing MemberPosts: 854
flash metering,
It doesn't -- the built-in distance encoder in the body provides this information. This has been the case since the i series, and is the reason Minolta cameras "reset" their auto focus as often as they can (bootup, MF/AF switching, "sleep" mode -- it's worse with older cameras).
It's even mentioned in old Minolta sales brochures that AF information is used for determining exposure (but not flash exposure AFAIK). That's why the 14-zone algorithm doesn't work in manual focus! In my opinion, the distance info gathered by older generation bodies is quite crude, probably divided in "zones" only.
"D" info is more refined and not delivered by the encoder. When using the "smooth focus" mode of the regular 7 and 7D, the body internal encoder is disabled. You can probably verify this with EXIF info!
wit no success.
No surprise there
Magnus W
In reply to Magnus W, Apr 20, 2005
An additional note: if you examine the EXIF data from the 135/STF lens I sent you, I am pretty sure there won't be any distance information. That is because the lens is manual focus and there is no connection through a focusing shaft, meaning the internal encoder can't do its work...
Elgsdyr
Senior MemberPosts: 1,192Gear list
AFAIK, there's also some sort of distance information with non-(D) lenses but it's much more rough. Something like near/middle/far instead of a more precise distance.
Yours etc.
Torsten Balle Koefoed
 Elgsdyr's gear list:Elgsdyr's gear list
Sony a6000 Sony E 30mm F3.5 Macro Sony E 50mm F1.8 OSS Sony E 20mm F2.8 Samyang 12mm 1:2.0 NCS CS
Dalibor J
Lazar: Focus distance not Focal length
Lazar,
I am talking about focus distance not the focal length.
Please re-read my post again.
Dalibor
Dalibor J
I'll try to verify how fine it is
In reply to Elgsdyr, Apr 20, 2005
It is possible, but I did not have this feeling on the first sight.
I'll try to compare how fine it is this evening and I will report back.
It is definitelly more precise than this, I know this already.
Dalibor
Dalibor J
Good points, Magnus
Those are very good points Magnus, thank you.
Are you suggesting that:
  • with non-(D) lens the info is taken from the encoder in the body?
  • with (D) lens the info is taken from the encoder in the lens itself?
This sounds reasonable. But even if this is true there still remains
some questions to be answered.
For example:
  • does the camera use the distance info even from non-D lens?
  • why the (D) lens needs to be "reset" at start when the
internal encoder is not used and the information is taken from the lens?
Brilliant idea, I'll do it tonight.
There is "Infinity" in both files I have. So you are probably right.
Still there is a slight chance that it really was focused for infinity.
Dalibor
CAClark
Re: Flash?
Who knows, I was just guessing
Cheers!
Craig A Clark
Hard Surface
Pinewood Studios
Iver Heath
Bucks , SL0 0NH
Mob: 0779 5595016
kiklop_2
Senior MemberPosts: 2,590Gear list
Lazar wrote:
I think to be fair
The point is that KM should be grateful to Dalibor for all his work in helping KM costumers.
Not so long ago, MRWFormat was the only raw converter that has produced great results in converting MRW files. And IMHO Dalifer is a brilliant little utility that has many unique features.
At least KM should provide Dalibor with needed information to save him a lot of time. Currently I'm testing DxO with KM lens modules and subject distance is the most important value. If not for Dalibor, DxO (excellent but a bit expensive) software would be of very limited use for 7D owners.
7D dedicated website http://www.dyxum.com
 kiklop_2's gear list:kiklop_2's gear list
Konica Minolta Maxxum 7D Nikon D700 Sony Alpha DSLR-A900 Nikon D800 Nikon AF-S Nikkor 14-24mm f/2.8G ED +6 more
RichV
Veteran MemberPosts: 6,135Gear list
More on D vs. non-D
Here's a quote of something I received a while back - hope it clarifies things:
"Distance is pretty much an exact item with the D lenses as they have a distance encoder built right into the lens whose data is decoded by the camera body. Non-D lenses do this by knowing travel distace of the lens from infinity to close focus and using a photo interrupter in the body to get very good (but not exact) distance. This information is used to get magnification data which is use for lots of stuff."
Rich
 RichV's gear list:RichV's gear list
Sony RX100 Sony SLT-A77 Sony SLT-A99 Sony 70-200mm F2.8 G Sony 50mm F1.4 +6 more
Lazar
Re: Lazar: Focus distance not Focal length
Ok, but my answer is the same.
tom
tom
Senior MemberPosts: 2,721
Re: Good points, Magnus
With the earlier film cameras, such as the maxxum 7, there is a difference between how the distance info is obtained. With some of the newer cameras (5 and newer) it is different, and with the 7D I think it is a combination.
The film cameras definitely do this - see below
With the maxxum 7 it takes info from both the lens and camera body encoders. The 5 has the capability of doing this also, but has a different way of using it. The 7 D also seems to be able to take from both.
For example:
All the cameras that use 14-segment ambient metering (7xi and later) use the data from the in-body encoder as part of the scene recognition and metering algorithms - primarily they use magnification of the subject (a function of focal length and focusing distance) and the difference between the subject and background (I think something like 'almost the same', a bit farther, really different, and 'off-scale different'). The various camera brochures and a couple of the HOVE books (7xi and 700si) get into some of the details.
When these cameras are put into manual focus mode, the in-body encoder was disconnected and the cameras would switch to an approximation of centerweighted metering. I have run a number of tests and the difference in exposure just by switching to manual focus is notable.
The 7 film camera was the first to keep the mechanical encoder connected when the camera was switched to manual focus (either on the front dial or with the push button on back). The AF motor was disconnected by a clutch. That's why there is still more resistance when turning the manual focusing ring. The 7 was the only camera that didn't switch to CW metering in manual focus. When resistance was too great (because of the use of teleconverters for example), the camera could be switched to 'smooth manual focusing' which disconnected the AF drive and the encoder and reverted to the earlier type of behavior.
The 5 has an additional feature that allows it to use the distance info from a "D" lens in the 14-segment metering and only switches to CW metering when a non-D lens is used in manual focus mode (body encoder disconnected). I think that the 60/70 also does this since its DMF only works with a "D" lens.
I tried using a "D" lens on the 7 in smooth manual focus mode to see if the 14-seg meter could use the D info from the lens encoder. It does not. I don't know if the 7D can or not. Just put the 7D in 14-seg mode with a D lens. Check exposure in AF and then set smooth manual focus and check the exposure again. Try to use a back lit or side lit subject so that 14-seg would be different than CW.
I think that the 7D still uses the mechanical encoder. I don't know if it uses the D-lens encoder for 14-seg.
Dalibor
kiklop_2
veri useful post, thanks (nt)
In reply to tom, Apr 20, 2005
Magnus W
Dalibor J wrote:
You got all the questions answered already I think, just this one:
infinity.
If I remember correctly it was of a lamp in the ceiling, and actually focused on it. If it's "infinity" in the exif, that strengthens my point, as the camera resets focus to infinity and thus subtracts D info (coming from lens or built-in encoder). For a lens without D encoder it should be infinity -- by the way, why not examine a shot taken without any lens at all and see what the D info is set at?
