Tip: Zero Postprocessing for Christmas
Started Dec 24, 2004 | Discussions
David Chin
Forum ProPosts: 11,670
Dec 24, 2004
First off, Merry Christmas and Happy Holidays to everyone.
Fotogenetic's goodbye message ( http://forums.dpreview.com/forums/read.asp?forum=1034&message=11499905 ) made me look at his recent postings and I was surprised to find out about his new Point and Shoot v4.0 curve, and thought I'd give it a try. This curve is weird in the sense that it remaps the 255 point to 228, and in one his posts, he says that this was done to obtain 1/2 of a stop more Dynamic Range ( http://forums.dpreview.com/forums/read.asp?forum=1021&message=11239667 ). Posts by other happy users of this curve also motivated me to give it a try.
Well, I have to say that I personally find this curve to be the best for snapshots - my favourites in the past used to be the White Weddings and Komin curves, but this new one beats them all - again, I have to stress, for snapshot purposes, where people are the main subjects. Actually, I find that it also works pretty well for the majority of the type of shots I take, and it looks like this is the curve that will stay in my camera.
The 3 pictures below were taken during a just-concluded Christmas dinner at my parents' house with this curve and other settings noted in the EXIF info. An SB-800 flash mounted on the camera was used with the Diffusion Dome on and bounced off the white ceiling. I put the SB-800 in AA mode. Other light sources are the multiple cool-white fluorescent lamps which I would characterize as very bright. If the ambient light had been tungsten or some other warm whites, I would have used a different setting such as Auto +3. Images were reduced in size in Photoshop CS, USM 500, 0.2, 0 and faded to Luminosity. Saved at JPEG 9. Comments and questions are welcome.
Hope this helps.
Focal Length: 28mm
Optimize Image: Custom
Color Mode: Mode IIIa (sRGB)
Noise Reduction: OFF
2004/12/24 22:41:56
Exposure Mode: Manual
White Balance: Auto -1
Tone Comp: User-Defined Custom Curve
Bounce
JPEG (8-bit) Fine
Metering Mode: Multi-Pattern
AF Mode: AF-S
Hue Adjustment: 0°
Image Size: Large (3008 x 2000)
1/15 sec - F/5.6
Flash Sync Mode: Front Curtain
Saturation: Normal
Exposure Comp.: 0 EV
Auto Flash Mode: Auto Aperture
Sharpening: Normal
Lens: 28-200mm F/3.5-5.6 G
Sensitivity: ISO 400
Auto Flash Comp: 0 EV
Focal Length: 28mm
2004/12/24 23:32:44.8
Bounce
JPEG (8-bit) Fine
AF Mode: AF-S
Hue Adjustment: 0°
Image Size: Large (2000 x 3008)
1/13 sec - F/5.6
Saturation: Normal
Sharpening: Normal
Lens: Nikkor 28-200mm F/3.5-5.6 G IF-ED
Focal Length: 34mm
2004/12/24 23:02:58.7
JPEG (8-bit) Fine
AF Mode: AF-C
Hue Adjustment: 0°
1/15 sec - F/5.6
Flash Sync Mode: Not Attached
Saturation: Normal
Exposure Comp.: +0.3 EV
Sharpening: Normal
Sensitivity: ISO 800
beaucamera
Senior MemberPosts: 2,231
Merry Christmas to you too
In reply to David Chin, Dec 24, 2004
Hi, David!
Thanks for sharing your Christmas with us. It's fun to see you and your family together. That a really cute one of your and Kellie..under the tree!
P.S. Can one download this curve and use it in Curve Surgery or Raw Magice lite?
welcome.
Hope this helps.
Focal Length: 28mm
2004/12/24 22:41:56
Bounce
JPEG (8-bit) Fine
AF Mode: AF-S
Hue Adjustment: 0°
1/15 sec - F/5.6
Saturation: Normal
Sharpening: Normal
Focal Length: 28mm
Bounce
JPEG (8-bit) Fine
AF Mode: AF-S
Hue Adjustment: 0°
1/13 sec - F/5.6
Saturation: Normal
Sharpening: Normal
Focal Length: 34mm
JPEG (8-bit) Fine
AF Mode: AF-C
Hue Adjustment: 0°
1/15 sec - F/5.6
Saturation: Normal
Sharpening: Normal
Dennis_Josiah
Regular MemberPosts: 195
Re: Tip: Zero Postprocessing for Christmas
Awsome shots!
Love the clarity of the first two and the blur of the last --go figure
Merry Christmas,
Dennis
http://www.dchimages.com
"Seeing with the light of the world." Gen 1:4 - Matt 5:14
welcome.
Hope this helps.
Focal Length: 28mm
2004/12/24 22:41:56
Bounce
JPEG (8-bit) Fine
AF Mode: AF-S
Hue Adjustment: 0°
1/15 sec - F/5.6
Saturation: Normal
Sharpening: Normal
Focal Length: 28mm
Bounce
JPEG (8-bit) Fine
AF Mode: AF-S
Hue Adjustment: 0°
1/13 sec - F/5.6
Saturation: Normal
Sharpening: Normal
Focal Length: 34mm
JPEG (8-bit) Fine
AF Mode: AF-C
Hue Adjustment: 0°
1/15 sec - F/5.6
Saturation: Normal
Sharpening: Normal
David Chin
On Curve Surgery and Raw Magick ...
In reply to beaucamera, Dec 24, 2004
... yes, I would imagine those programs can handle this curve, no probs - just go to http://fotogenetic.dearingfilm.com/downloads.html and download the zip file containing the curves. It's just like any of the other curves we have come to know and love, examples include Oldskool's and Blake Haber's curves.
Thanks for the kind comments - I trust you're having a splendid Christmas too
beaucamera wrote:
Hi, David!
Raw Magice lite?
vrc
vrc
Regular MemberPosts: 283
thanks (nt) & Merry Christmas
welcome.
Hope this helps.
Focal Length: 28mm
2004/12/24 22:41:56
Bounce
JPEG (8-bit) Fine
AF Mode: AF-S
Hue Adjustment: 0°
1/15 sec - F/5.6
Saturation: Normal
Sharpening: Normal
Focal Length: 28mm
Bounce
JPEG (8-bit) Fine
AF Mode: AF-S
Hue Adjustment: 0°
1/13 sec - F/5.6
Saturation: Normal
Sharpening: Normal
Focal Length: 34mm
JPEG (8-bit) Fine
AF Mode: AF-C
Hue Adjustment: 0°
1/15 sec - F/5.6
Saturation: Normal
Sharpening: Normal
KeenAmatuer
Senior MemberPosts: 1,104
You have a lovely family David.......tho i wouldn't want to be the one doing the cooking as there are a lot of you there!
I've seen this curve used before and it does boost colours for people type shots. I think i may load it.
Happy Christmas
Phil
incoherent1
Regular MemberPosts: 129
Flash settings?
Thanks for continuing to share tip(s).
For my taste, I find the first to be a little flat, really like the second. Easily enough changed with post processing, tho', and largely a mater of personal taste.
My somewhat OT query is why you choose not to use the flash in TTL mode. Do you find that the flash meters better than the camera for some reason?
Thanks in advance for any reply provided.
R Laing
Veteran MemberPosts: 3,115
Got to post process no free lunch
Beautiful family David but digital = post
degsy_safc
Senior MemberPosts: 1,354
Hi David,
Very nice Christmas Photo's and a lovely way to spend the holidays with all your family around you.
Shot 1 made me really laugh, i had this strange picture conjured up in my mind of an 11 legged turkey at your dinner table - one for each adult
Personally i think shot 3 really captures the excitement of the event and that little girl is so cute.
Merry Christmas & Happy New Year to you and your family.....
regards ....
degsy
Runner 101
Contributing MemberPosts: 618
I am a newbee D70 coming from 35mmfilm Minolta family. I work for a company in Penang and have been there and to KL. One of the guys I have come across has the same name as you but my company is into chemicals via palm trees which there are plenty of by you. Merry Christmas, thanks for the posts, I am slowly learning from you and others. John
welcome.
Hope this helps.
Focal Length: 28mm
2004/12/24 22:41:56
Bounce
JPEG (8-bit) Fine
AF Mode: AF-S
Hue Adjustment: 0°
1/15 sec - F/5.6
Saturation: Normal
Sharpening: Normal
Focal Length: 28mm
Bounce
JPEG (8-bit) Fine
AF Mode: AF-S
Hue Adjustment: 0°
1/13 sec - F/5.6
Saturation: Normal
Sharpening: Normal
Focal Length: 34mm
JPEG (8-bit) Fine
AF Mode: AF-C
Hue Adjustment: 0°
1/15 sec - F/5.6
Saturation: Normal
Sharpening: Normal
HOOAH!
G K Lai
Regular MemberPosts: 304
This curve also in my camera, but...
... I discover something "unusual" with this latest curve by Fotogenetic.
When shoot in NEF with NORMAL curve and open the image in NC. Whenever I choose this curve in NC, the "Color Mode" and "Saturation" changes have no more effect. Just feel strange. This curve seems can overide these two settings and of course, I found no need to change Color Mode and Saturation once this curve is activated because it is a P&S curve.
Have a nice holiday!
-Lai
welcome.
Hope this helps.
Regards, David
(D.7.0. & C.P.4.5.0.0.)
http://www.pbase.com/dlcmh
http://www.pbase.com/dlcmh/dslr_links
nowhereatoll
Veteran MemberPosts: 8,285
beatiful family David
Happy Holly to you all!
probs - just go to
Christmas too
beaucamera wrote:
Hi, David!
Raw Magice lite?
accw
Contributing MemberPosts: 555
Re: This curve also in my camera, but...
In reply to G K Lai, Dec 24, 2004
I bought the cam yesterday and am shooting for the moment most in AUTO-mode (and now for testing etc in P-mode).
Because I didn't like the exposure in auto-mode, I downloaded the curve and installed it.
Now I'm wondering if this also works for the AUTO mode?
thanks.
grt,
Alex
Ca
Fotogenetic.
-Lai
welcome.
Hope this helps.
Regards, David
MGlennn
Senior MemberPosts: 1,578
Merrry.....
...Christmas to you as well David and THANKS for all your contributions to my photographic education............ :-)) M
Bill Hall
Contributing MemberPosts: 886
Nice pictures. Nice family. Thanks for sharing those pictures. Nicely done.
And thanks for sharing the tip. I missed it. I'm using one of his other curves - can't remember which one. I'll check it out.
Merry Christmas
welcome.
Hope this helps.
Focal Length: 28mm
2004/12/24 22:41:56
Bounce
JPEG (8-bit) Fine
AF Mode: AF-S
Hue Adjustment: 0°
1/15 sec - F/5.6
Saturation: Normal
Sharpening: Normal
Focal Length: 28mm
Bounce
JPEG (8-bit) Fine
AF Mode: AF-S
Hue Adjustment: 0°
1/13 sec - F/5.6
Saturation: Normal
Sharpening: Normal
Focal Length: 34mm
JPEG (8-bit) Fine
AF Mode: AF-C
Hue Adjustment: 0°
1/15 sec - F/5.6
Saturation: Normal
Sharpening: Normal
There are 10 kinds of people in this world, people who understand binary, and people who don't!
Cassandra
Veteran MemberPosts: 9,301
In reply to David Chin, Dec 25, 2004
Merry Christmas David! Very nice family pics -- thanks for sharing. I too have fotogenetic's new p&s curve loaded but not much opportunity to try it out yet.
Cassandra
http://www.pbase.com/cassandra/nikon_d70
AviBen
Senior MemberPosts: 1,016
In reply to accw, Dec 25, 2004
Custom curves do not work in Auto mode. Use P (or A or S) mode instead.
David Chin
TQ NWA! (nt)
In reply to nowhereatoll, Dec 25, 2004
http://www.pbase.com/nowhereatoll
http://www.nowhereatoll.com
David Chin
TQ Dennis! Blurring ...
In reply to Dennis_Josiah, Dec 25, 2004
... human subjects within interesting compositions is still something I'm trying to master.
Dennis_Josiah wrote:
Awsome shots!
figure
Merry Christmas,
Dennis
David Chin
U're welcome, VRC! (nt)
In reply to vrc, Dec 25, 2004
vrc wrote:
Regards, David
