Do-It-Yourself lights for product photographers: step-by-step tutorial
Finished Image
 Sony X-Plod car speakers - finished image
Say what you want folks but I like watching shows like “American Test Kitchen”. First, I like good food. More important though, I like that those people always experiment and play with things that have been around forever and yet, they manage to come up with something new I have not heard before. In my studio photography, I try to experiment as much as I can and a big part of it has to do with lighting – using different lighting techniques, mixing different types of lights, using custom lights and so forth. In this installment of “behind the scenes” we will go over a shot of the car speakers (Sony X-Plode), which was done entirely with the help of the luminescent do-it-yourselt lights.
Building the lights
First, let’s begin with the lights. In my studio, I keep a set of four 18? under-cabinet lights from Home Depot, which could be very useful when you need a long and narrow light source with controlled fall-off. Those lights are great for dramatic low key shots where rim lighting (or sometimes “slash”, or criss-cross lighting from behind or from the sides) is desired. In a moment, I will show you how I built my lights but first let’s touch upon a few things that will help you get the most out of each shot:
  • First, when you work with any non-calibrated lights (such as these), you should never trust your in-camera white balance and always take a shot of a color chart or grey patch
  • The lights we are talking about are fairly low powered and your exposures most likely will be in seconds; a cable release is highly recommended. Also, if your camera has mirror lock-up function, you may want to use it
  • If you decide to go out and buy some lights to play with, make sure you buy all the lights at once and make sure you don’t mix and match models. The reason is very simple – even the lights of the same model but from different batches are almost guaranteed to have noticeably different color temperatures
All right, now we are ready to start building the lights. For this particular shot, I used two luminescent under-cabinet lights from Home Depot (approx. $12 each). Since I want to be able to control the light fall-off, I cut a few pieces of black-white foamcore, which will be used as improvised barn doors. Below are the lights, the foamcode cutouts and pieces of wood I will attach the lights to – these will help me mount the lights to the stands, grip etc.
Step 1 - building the lights
The next step is to “sandwich” each light in the cutouts (white side towards the light) and attach the whole thing to the piece of wood. After mounting, the “sandwich” looks like this:
Step 1a - this is what a "finished" light looks like
The first shot
For my shot, I only need two lights so I leave the other two for the next time. Now, let’s set up our object and the lights. In this particular shot, I am going for dramatic low-key lighting from the top and from the bottom. The goal is to achieve that “serpent eye” look with bright core and dimly lit space around it. To start, I mount the lights on both sides of the speaker and slightly tilt them down to control the light spill-off – we don’t want too much light on the middle part of the speaker. The camera is mounted right above the speaker looking straight down.
Lighting setup for the "main" speaker shot
The very first shot confirms that we are on the right path – we are not “on the money” yet, but we are close.
Resulting image (see the lighting setup above)
Improving the image
The light on the grill is nice, the edge is nicely separated but not over lit. The only problem is that the entire central part of the speaker fell into the darkness. To correct that, we add a couple of narrow foamcore strips that act as mini-reflectors and help to open up the shadows in the middle.
Adding foamcore "strip" reflectors to open up the shadows and reveal the logo marks
Much better now! We can see the label (Sony X-Plode) and even a glimpse of the blue core:
Resulting image (after the foamcore strips were added)
Now, the above shot is not bad at all. But… it is still an “OK” shot and we are going for the “WOW” one! If we could somehow make the blue core shine, that would bring the image to that next level. Unfortunately, it would be exceedingly difficult to achieve it in one shot without sacrificing the nice light on the grill so we will shoot the blue core separately and then combine the two shots in post production. In order to light for the blue core, we turn the lights about 90 degrees and point them sharply down leaving just enough space for the camera to see the speaker core:
Lighting setup - shooting for the speaker code
The resulting image of the speaker core:
Resulting shot - the speaker core
Putting it all together
All right, now that we have all the parts, all we have to do is to cut out the speaker, put it on a background of your choice (I happen to like plain black but it is my personal preference; you may want to experiment with different backgrounds to see which one works best for you), do some very light cleanup and paste the bright blue core into the final image. The finished image looks too good to believe it was done with two $12 lights from the home improvement store!
 And now everything comes together - the final image
Technical data
Camera: Canon 5D Mk II
Lens: Canon 50mm 1:2.5 Compact Macro
You can find my other articles and instruction materials here: http://www.photigy.com/author/astepanov256
1251
I own it
151
I want it
305
I had it
Discuss in the forums
101
I own it
11
I want it
20
I had it
Our favorite products. Free 2 day shipping.
Support this site, buy from dpreview GearShop.
Canon EF 50mm f/2.5 Macro
Comments
Total comments: 3
Funduro
By Funduro (Oct 9, 2012)
Informative article. Trail and error plus a side dose of imagination = nice image.
0 upvotes
Alex Stepanov
By Alex Stepanov (Jul 6, 2012)
Thanks Jay,
Surprisingly, I found this setup to be quite flexible - I shot some watches the other day with a slightly modified version of the same setup and it worked quite well, much to my surprise I must say :)
-Alex
0 upvotes
SonyAlphaLab - Jay
By SonyAlphaLab - Jay (Jul 4, 2012)
Really nice job Alex!! Very cool how you shaped the light into exactly what you wanted. The resulting image is excellent as well.
Jay
0 upvotes
Total comments: 3
