PMA 2005: Tamron's AF 18-200 mm F/3.5-6.3 XR Di-II LD Aspherical (IF) Macro lens, designed exclusively for digital cameras with small sensors, will ship in the spring. The wide to tele capabilities of this lens, which is equivalent to 28 - 300 mm in 35 mm terms, means that you should seldom need to change lenses. The lens, which is just 84mm long, features enhanced peripheral illumination, minimizes peripheral light fall-off and its internal surface coating reduces ghosting and flare. It is compatible with Canon AF, Konica Minolta AF-D, Nikon AF-D and Pentax AF mounts.
Press Release:
A New High Power Standard Zoom Lens Designed for Exclusive Use with Digital SLR Cameras
PMA, Orlando, Florida, February 20, 2005 - Mr. Morio Ono, President of Tamron Co., Ltd., announces the spring delivery of the AF18-200mm F/3.5-6.3 XR Di-II LD Aspherical (IF) Macro (Model A14), a new high power zoom lens designed exclusively for digital SLR cameras with smaller-size image sensors.
The new AF18-200mm F/3.5-6.3 XR Di-II LD Aspherical (IF) MACRO is a high power zoom lens designed for exclusive use with digital SLR cameras using smaller-size imagers and inherits the product concept of the existing AF28-300mm F/3.5-6.3 XR Di zoom lens. Even two years after its introduction, the AF28-300mm XR is still a favorite and highly evaluated by photographers around the world as a representative model of high power zoom lenses. With the recent market influx of digital SLR cameras, the use of high power zoom lenses has become increasingly popular since high power zooms provide the convenience of handling many photographic scenes and the capability of shooting ultra telephoto shots without changing lenses. The popularity of this focal length led Tamron to initiate the development of new zoom lenses to further meet the needs of digital SLR photographers. The result is the successful development of a new zoom lens made exclusively for use on digital SLR cameras. The wide to ultra tele focal range of this lens will allow digital SLR camera owners to enjoy digital photography with comfort and convenience.
• "Di (Digitally Integrated design)-II" lenses are designed for exclusive use on digital cameras with smaller-size imagers.
*This lens is not designed for use with 35mm film cameras and digital SLR cameras with image sensors larger than 24mm x 16mm.
Dedicated for Digital SLR Cameras
By incorporating an optical design for exclusive use with digital SLR cameras with smaller-size imagers, this high power zoom lens provides the same focal length, when converted to a 35mm format, equivalent to Tamron's 28-300mm. Therefore, you can meet virtually every photographic opportunity with this single zoom lens without changing lenses. When paired with the new ultra-wideangle SP AF11-18mm zoom lens, simultaneously introduced by Tamron at Photokina 2004 and expected to ship in late spring 2005, you can thoroughly enjoy digital SLR photography with the combined focal length coverage of 17-300mm.
Optical System Uses Special Glass and is Optimized for Digital SLR Characteristics in order to Enhance Optical Quality in a Compact Design
The new AF18-200mm high power zoom lens from Tamron features an entirely new optical design using XR (Extra Refractive Index) glass in an innovative way in order to optimize the overall distribution of optical power throughout the entire zoom range. This design reduces various aberrations to the absolute minimum and achieves remarkable downsizing at the same time. In addition, three hybrid aspherical lens elements and two LD (Low Dispersion) glass elements are used to accomplish effective compensation of on-axis and lateral chromatic aberrations, a critical factor to enhance the optical quality in digital photography. As a result, the lens provides outstanding optical quality in a multi-purpose zoom lens.
Optical Design Dedicated to Digital SLR Photography by Optimizing the Angles of Incidences of Light Rays Reaching the Image Sensor
The zoom lens uses a new optical system designed to confine the changing angles of incidences of light rays reaching the imager within a certain scope over the entire image field from the center to the periphery, by considering the effects of variances due to zooming.
Enhanced Peripheral Illumination
Peripheral light fall-off is minimized when compared with that of conventional lenses for film cameras so that images are uniformly bright from the center to the periphery.
Outstanding Resolution
Since the lens is designed exclusively for digital SLR photography, it provides high image quality in terms of resolution, contrast and flatness of image field.
Internal Surface Coating to Reduce Ghosting and Flare
Ghosting and flare caused by aberrations are annoying factors in digital SLR photography, so Tamron has adopted various countermeasures against the problem including the employment of “Internal Surface Coatings” (i.e., multiple-layer coatings on cemented surfaces of plural elements) and new multiple-layer coating technology on ordinary elements in order to minimize reflections that occur when light enters through the front element and to reduce image degrading effects caused by the imagers themselves.
Revolutionary Minimum Focus Distance - 0.45m (17.7") for 1:3.7* Macro Capability
It is an important condition for a multi-purpose zoom lens to provide the capability of getting close to the subject. The new 18-200mm zoom lens realizes an MFD (Minimum Focus Distance) of 0.45m (17.7") through the employment of a new optical/mechanical design configuration. Since the maximum magnification ratio at f=200mm is 1:3.7*, you can enjoy close-up photography easily and conveniently.
* The Maximum Magnification Ratio of 18-200m (Model A014) is 1:3.7 while the Maximum Magnification Ratio of the 28-300mm (Model A061) is 1:2.9. However, the A014 can fill the frame with almost the same scope as the A061 does when shooting with a 35mm SLR camera, since the new lens is exclusively designed for digital SLR cameras with smaller-size imagers. The Maximum Magnification Ratio of 1:3.7 is equivalent to 1:2.8 when converted to 35mm film format.
High Power, Yet Compact and Lightweight Thanks to New Mechanical Devices
Complicated mechanisms are built in the compact body thanks to new mechanical devices. The lens is a multi-purpose zoom lens, yet excellent portability and ease of use are assured. A number of invisible engineering innovations required to downsize the lens, produce high precision parts and increase durability are incorporated into the new AF18-200mm F/3.5-6.3 XR Di-II LD Aspherical (IF) MACRO since manufacturing this type of zoom lens with such complicated mechanisms inside was almost impossible with conventional manufacturing technology.
Zoom Lock Mechanism Incorporated
The Zoom Lock prevents unwanted barrel extension when carrying the lens/camera combination.
Flower-shaped Lens Hood
A glare-reducing flower-shaped lens hood is included as a standard accessory. The special hood provides optimum shading of superfluous light rays that enter from the rectangular frame outside the image field.
New External Design on the New Di-II Series Conveys “High Performance, High Precision Image”
Improvements have been made to the external design by adding a gold-colored band between the focus and zoom rings to enhance the appearance and make it stand out as a Di-II lens. The rubber patterns of the zoom and focus control rings have been improved at the same time to compliment the digital camera design style and to provide better handling.
Tamron AF 18 - 200 mm lens specifications
Model name
Focal length 18 - 200 mm
Maximum aperture F3.5 - 6.3
Angle of view 75° 33' - 7° 59'
Lens construction 15 elements in 13 groups
Minimum focus distance 0.45 m (17.7 in)
Maximum mag ratio 1:3.7 (at f=200mm MFD 0.45m)
Filter diameter φ62 mm
Overall length 84 mm (3.3 in) *
Maximum diameter φ73.8 mm (2.9 in)
Weight 398 g (14 oz) *
Diaphragm Blades 7 blades
Minimum aperture F22
Standard accessory Flower-shaped Lens Hood
Compatible mount Canon AF, Konica Minolta AF-D, Nikon AF-D and Pentax AF
*Values given are for Nikon AF cameras.
