Samsung added two new lenses to its NX mirrorless camera line, one for pros, and another designed to serve as a smaller alternative to the kit lens. Both lenses range from 16-50mm, but the first is a premium design with the 'S' designation, whose bulkier design accommodates an F2.0-F2.8 aperture and optical image stabilization. The second lens is a retractable F3.5-5.6 power zoom with OIS, which the company says offers improved performance over the 18-55mm kit lens.
Samsung says the 16-50mm F2.0-2.8 S ED OIS lens offers greater 'precision, high quality materials and value control'. It has a metal body, includes weather and dust sealing, and uses what Samsung calls an 'ultra precise stepper motor'.
The 16-50mm F3.5-5.6 Power Zoom ED OIS lens, on the other hand, is designed as a portable option whose motorized zoom allows for smoother zooming while shooting video.
Samsung did not announce pricing and availability, only noting that the lenses will be on display at CES 2014.
Jump to:
Press Release:
Premium and Professional Quality in any Situation: 16-50mm F2-2.8 S ED OIS Lens
The new Samsung 16-50mm F2-2.8 S ED OIS lens allows photographers of all skill levels to achieve professional image quality through a myriad of new and advanced features. It is the first Premium “S” Series lens, which signifies end-users will be given superior optical-technology to meet their photography needs. Its versatile standard zoom angle of view allows for flexibility to take photos at frequently desired angles and vantage points, without limitations on what is captured. The 16-50mm has an extremely bright aperture (F2.0 at 16mm; F2.8 at 50mm) making it the brightest 3X zoom among equivalent class lenses, adding-value to the overall picture-taking experience and imaging results. Splash and dust proof, this lens is designed to deliver quality results even in extreme, harsh conditions.
This lens features an Ultra-Precise Stepping Motor (UPSM), improved from the conventional Stepping Motor (SM), that is 3X more precise in its ability to control and focus on subjects. Coupled with its optical image stabilizer and combination of three aspherical (ASP) lenses, two extra-low dispersion (ED) lenses, and two eXreme High Refractive (XHR) lenses, the 16-50mm F2-2.8 S ED OIS has the ability to take a steady shot and produce an exceptional photo with ultimate clarity and detail. The combination of these advanced elements work together to enhance the results from the lens. The ASP lenses reduce and nearly eliminate spherical aberration, whereas the ED elements reduce chromatic aberration and the XHR allows for a more compact and light lens.
Excellent Imagery Everyday: 16-50mm F3.5-5.6 Power Zoom ED OIS lens
The new 16-50mm F3.5-5.6 Power Zoom ED OIS lens was designed for everyday use as well as for photographers who often travel and desire quality and compactness. It is lightweight, weighing only 111g with a compact 31mm frame and a modern and simple design. It is available in two colors (Black and White). With an outstanding wide angle optical performance, the 16-50mm F3.5-5.6 Power Zoom ED OISlens includes Silent Auto Focusing and a low zooming noise, excellent for capturing video which is clear and undisturbed by the noise of the mechanism.
A vital feature of the new lens is its quick control made possible through an Electro zoom with a seesaw type button. This unique feature allows photographers to simply click to zoom and take a photo from any view or angle, similar to a compact camera experience. The smooth zooming operation, applied from the high-end camcorder not only creates superb pictures, but enables high-quality videos. The intuitive operating mechanism, i-Function and UPSM help to take more precise pictures, while the Optical Image Stabilization reduces the blur associated with camera movement adding to the appeal of this lens.
Specifications
 Samsung NX 16-50mm F2.0-2.8 S ED OISSamsung NX 16-50mm F3.5-5.6 Power Zoom ED OIS
Principal specifications
Lens typeZoom lens
Max Format sizeAPS-C / DX
Focal length16–50 mm
Image stabilisationYes
Lens mountSamsung NX
Aperture
Maximum apertureF2–2.8F3.5–5.6
Minimum apertureF22
Aperture ringNo
Number of diaphragm blades97
Aperture notesCircular Aperture Diaphragm
Optics
Elements189
Groups128
Special elements / coatings3 Aspherical lens, 2 Extra-low Dispersion lens, 2 Xtreme High Refractive Lens4 Aspherical lens, 1 Extra-low Dispersion lens
Focus
Minimum focus0.30 m (11.81)0.28 m (11.02)
Maximum magnification0.19×0.24×
AutofocusYes
Motor typeStepper motor
Full time manualUnknown
Focus methodExtending front
Distance scaleNo
DoF scaleNo
Physical
Weight622 g (1.37 lb)111 g (0.24 lb)
Diameter81 mm (3.19)65 mm (2.55)
Length97 mm (3.8)31 mm (1.22)
SealingYesNo
ColourBlackBlack, white
Zoom methodRotary (extending)
Power zoomNoYes
Zoom lockNo
Filter thread72.0 mm43.0 mm
Hood suppliedNo
