Fujifilm has announced the XF 56mm F1.2 R, a fast short telephoto 'portrait' lens for its X system mirrorless cameras. With an angle of view equivalent to an 85mm lens on full frame, it uses an internal focus design for fast, silent autofocus.
The lens has an aperture ring which Fujifilm says has been engineered to give positive click stops, something that hasn't really been the case with previous XF lenses. Like the older XF primes (but unlike the more recent wide angle primes), the focus ring is of the continuously-rotating type with no distance or depth of field scales - although Fujifilm claims it should have improved 'feel'.
The XF 56mm F1.2 R will be available in February, with a suggested retail price of $999.99 / £999.99.
Jump to:
Press Release:
Fujifilm announces fast portrait lens for X-series cameras that surpasses picture quality of full-frame equivalents
Fujifilm Corporation (President: Shigehiro Nakajima) has announced the release of the FUJINON XF56mm F1.2 R lens. Available from February 2014, this latest addition to the company’s line up of professional-grade lenses for X-series interchangeable-lens cameras features a fast maximum aperture of f/1.2, a focal length of 85mm*1 and delivers beautiful bokeh, making it particularly suitable for high quality portraits.
The XF56mm F1.2 R is less than half the size of an equivalent lens on a full-frame camera*2 and offers fast, quiet autofocusing that ensures stress-free shooting for both the photographer and the model. It also delivers incredible resolving power for high quality results that are enhanced by the unique skin tone reproduction technology found in Fujifilm’s X-mount cameras. Using the XF56mm and selecting one of two PRO Negative modes from the Film Simulation menu on the camera body will ensure users can capture beautiful portraits with rich tonal gradations reminiscent of images from film cameras.
Like all other lenses in the XF line up, the XF56mm F1.2 R is designed with an impressive attention to detail. It has a design that sits comfortably in the hand and exterior features including a metal aperture ring for a premium quality feel.
Advanced optical design for professional portraits
The lens’ new optical design featuring 11 elements in 8 groups delivers impressive results. The design includes two ED (extra low-dispersion) elements and one double-sided aspherical element, plus four elements with a convex surface facing the subject, which combine to reduce spherical and chromatic aberrations. They also ensure the best possible image resolution, even when the lens is at its widest aperture of f/1.2.
Image quality is further enhanced by Fujifilm’s proprietary HT-EBC coating that’s used on all lens surfaces to reduce ghosting and flare, while the seven-blade rounded diaphragm produces the creamy smooth bokeh effect that’s become synonymous with XF series lenses.
Attach the XF56mm F1.2 lens to a body that supports the Lens Modulation Optimiser*3 and picture quality leaps even higher thanks to the automatic correction of diffraction when shooting at smaller apertures.
Fast autofocus, silent operation
The XF56mm F1.2 R combines an inner focus mechanism*4 and a DC coreless motor for rapid autofocusing speeds, which are boosted further when used with a X-series camera body that supports phase detection AF. The structure and positioning of the focusing unit reduces sound and vibration for silent operation and with no lens barrel movement during focusing, the structure effectively prevents dust particles from getting into the lens and degrading picture quality.
Premium build quality
In keeping with the XF lens legacy, the 56mm F1.2 R features a durable, metal construction - including the aperture and focusing rings - to ensure a high quality feel. The aperture ring is designed to ensure it’s easy to detect ‘clicks’ between f-stops, while the focusing ring is both comfortable in use and has the perfect amount of torque so it’s simple to focus precisely.
*1  35mm format equivalent
*2  According  to Fujifilm data
*3  Fujifilm X-E2 as of January 2014
*4 A mechanism that moves small elements in the middle or at the rear of the lens, while keeping the large, front elements stationary
Fujifilm XF 56mm F1.2 R specifications
Principal specifications
Lens typePrime lens
Max Format sizeAPS-C / DX
Focal length56 mm
Image stabilisationNo
Lens mountFujifilm X
Aperture
Maximum apertureF1.2
Minimum apertureF16
Aperture ringYes
Number of diaphragm blades7
Aperture notesRounded diaphragm
Optics
Elements11
Groups8
Special elements / coatings2 ED glass elements, 1 double-sided aspheric element
Focus
Minimum focus0.70 m (27.56)
Maximum magnification0.09×
AutofocusYes
Motor typeMicromotor
Full time manualUnknown
Focus methodInternal
Distance scaleNo
DoF scaleNo
Physical
Weight405 g (0.89 lb)
Diameter73 mm (2.88)
Length70 mm (2.74)
MaterialsMetal barrel, metal mount
Filter thread62.0 mm
