Photoshop Gradient Tool: Blending Images
This image was created from two separate photos, using Photoshop’s Gradient tool.
Photoshop's Gradient tool may not be on most users' lists of go-to editing options. But it should be. In combination with layer masks, the Gradient tool lets you create natural-looking composite images. In this tutorial I'll show you how to combine a compelling foreground element with an interesting sky to create a seamless, believable landscape image.
In an upcoming article we'll explore how to use the Gradient tool to modify layer mask-enabled adjustments to brightness, contrast and toning. But first things first. Here, I'll show you how to make two separate images blend seamlessly into one.
When two is better than one
If your instinct is to resist the whole notion of composite imagery because it feels like 'cheating', you should know that the idea of combining pictures together has a long photographic tradition. Swedish photographer Oscar Gustave Rejlander pioneered the photomontage a.k.a. 'combination printing' in the 1850s! In addition to solving the problem of capturing both sky and foreground on the low-latitude, blue-insensitive emulsions of the day, many 19th century masters appreciated that combination printing is a wonderful way for photographic artists to realize their personal vision, just as painters do.
Here our goal is to seamlessly blend the two images below into a the single image shown at the start of the article. Since we're combining two images, you may be wondering why I don't just use the Quick Selection tool to cut the sky out of one image and paste it over the existing sky in the other image.
Here I have an interesting foreground: a weathered, abandoned and tiny 19th-century New Mexico homestead. The total living space couldn’t have been more than 100 sq. ft.! The problem here though is that the sky isn’t so exciting. This image has a luminous, dramatic sky, but no real focal point for the eye to rest on. Neither of these images really succeeds on its own – but combined together (as seen above) they’re lovely.
The problem is that masking or silhouetting the horizon line is much harder than you may think. The roofline won’t be a problem, and the soft edges of the mountains at the horizon are do-able, but those tree limbs and leaves will be a source of heartbreak! Chances are, even after hours of careful work using Channels, Image Calculations or the Pen tools, something will still look 'funny' around those trees.
So let’s just skip all that. Using the Gradient tool in a layer mask is fun, effective, and best of all, speedy. Of course, there are some projects that need a complex silhouette, but when you're blending things like sky and clouds, using a gradient is not only easier, but produces better results.
Layer masks and gradients explained
The concept of layer masks can be hard to grasp, even for experienced Photoshop users. So before we go any further, here’s a good, simple way to think about them. Masks have only one job: they hide stuff. A mask on a pixel layer makes it possible to hide parts of that layer without destroying any pixels. By using masks instead of the Eraser or History brushes, you can always change your mind about any edits because you're never deleting pixels, only changing their visibility. Better still, you can restore the visibility of any hidden items even after the image file has been saved, closed, and reopened.
When a layer mask is white, it reveals the layer to which it is attached. A black layer mask does just the opposite. It hides the layer to which it is attached. But of course, a mask does not have to be filled completely with black or white. And that's where gradients come in.
When making a gradient inside a layer mask, the thing to remember is that a black-to-white gradient means 'hidden-to-revealed' or 'invisible-to-visible'. A white-to-black gradient means exactly the opposite: 'revealed-to-hidden' or 'visible-to-invisible'.
Gradient tool options
When you select the Gradient tool there are two options you need to set: the gradient's colors and its shape.
You can set the Gradient options to display as thumbnails or in a list view, at a choice of sizes. You can even opt for a text-only view to save room if you're working on a small monitor.
In this tutorial we'll be using the Black, White option to fill in the layer mask. These are the colors we want to use to hide and reveal parts of the layer. The Black, White option is, by default the third item in the Gradient flyout menu shown above. Note that if you set Photoshop's foreground/background swatches to their defaults, (keyboard shortcut: D), then choosing the Foreground to Background option in the Gradient flyout menu will give the same effect.
You also want to make sure to select a Linear Gradient in the options bar. In a followup article on gradient masking, I’ll be using both the Radial and Reflected Gradients. (If anyone can tell me a practical use for the Angle or Diamond Gradients, I’d love to hear from you.)
Once the Gradient tool is selected you can decide the shape of your gradient. You can apply it as a straight-line (linear), radial or reflected blend (shown here). For this tutorial only the Linear Gradient will be employed.
I'll be honest, it takes a little practice to get the hang of using the Gradient tool and its options, but the idea is pretty straightforward. The Gradient tool (unlike a Gradient Fill or Gradient Map Adjustment Layer) is similar to the Brush tool. As with brushes, the color black in a mask hides stuff; white makes it visible. And as I'll demonstrate later, gray partially hides a layer.
Here's where gradients differ though. You create one by click-dragging. A longer click+drag results in a more gradual transition, a shorter click-drag creates a more abrupt transition. To experiment with the Gradient tool I suggest creating a new, blank canvas (File>New) and drawing different gradients on the white Background layer. It’s a great way to make sense of this very useful tool.
Continue to page 2 of our Photoshop Gradient article...
31
Flag as inappropriate
12
Share:
Print view
Comments
Total comments: 215
12
CJ Lan
By CJ Lan (1 week ago)
I still do not think combining two or more pictures into one is a good photography principle and practice to follow or encourage.
Why does the author involve blending two pictures into one with the gradient tool. The gradient tool can be used without. I just do not see the point.
1 upvote
AndreNL
By AndreNL (1 week ago)
Combining two pictures has nothing to do with photography. So it can't be a bad photographic principle. It is postproduction, faking, enhancing, shaping reality.
Image manipulation helps telling the story. It is creativity, NOT photography. A painter does't wait for the perfect sky to come by. He makes one up. He is an artist.
The sky-replacement has nothing to do with photography. Any use of gradients (using photoshop) hurts all photographic principles that you can make up. Photography ends as soon as the shutter closes. Everything after (and a LOT before) is pure manipulation.
In some situations postproduction should be avoided or used with care (news etc.). That is my PERSONAL principle and has nothing to do with photography.
I this article I fail to see any problem regarding image manipulation. The image greatly improved.
The article is well written and will help readers (artists) to further improve the story they want to share with the rest of the world.
That is the point.
1 upvote
Stefan Stuart Fletcher
By Stefan Stuart Fletcher (1 week ago)
Thank you for a very informative tutorial, clearly and simply explained.
0 upvotes
contadorfan
By contadorfan (1 week ago)
I got this to work in PaintshopPro x5 with a little help from this tutorial:
http://www.youtube.com/watch?v=QXCIiTavAS
Woo hoo! First time I've ever used a mask or a gradient!
0 upvotes
NZ Scott
By NZ Scott (2 weeks ago)
Fantastic tutorial, thank you. I've been meaning to train myself in the use of the gradient tool for some time now - and this is tremendously helpful.
0 upvotes
Peter B Schmidt
By Peter B Schmidt (2 weeks ago)
Thank you Jean Miele for this splendid article. You make me hungry for some more. When can we expect
"In an upcoming article we'll explore how to use the Gradient tool to modify layer mask-enabled adjustments to brightness, contrast and toning"
0 upvotes
AbrasiveReducer
By AbrasiveReducer (1 month ago)
Thank you so much for acknowledging that making a really convincing mask for sky replacement is not fast or easy. This is an excellent tutorial, made even better by your honesty about the tedious alternative.
0 upvotes
Zvonimir Tosic
By Zvonimir Tosic (2 months ago)
Light in two pictures above comes from a totally different angle.
But who really cares about that? :)
0 upvotes
letsgofishing
By letsgofishing (2 months ago)
Many thanks Jean - looking forward to part 2!
Comment edited 20 seconds after posting
0 upvotes
Serban Alexandru
By Serban Alexandru (2 months ago)
Really good, indeed. Thank you.
What do Diamond Gradients serve for? To draw diamonds, I suppose... :)
0 upvotes
zizzle
By zizzle (3 months ago)
Thanks! Great article - simple and short really good
1 upvote
JonathanFV
By JonathanFV (3 months ago)
Very nice tutorial, thanks a lot Jean! It worked great with Gimp as well, using the same technique. Also, I've noticed I had to horizontally flip the sky so the shadows of the beams of the house go the same way as the rays of the sun.
0 upvotes
rdc13
By rdc13 (3 months ago)
I'm guessing that people here who are saying 'this isn't photography' never spent hours and hours dodging and burning in a hot, stuffy darkroom.
Tools change. Art remains.
1 upvote
martin45
By martin45 (3 months ago)
Thank you Jean for your useful example of using gradients in a mask. This is an easy method to deal with a common problem.
I preferred the original sky though. What I did was to duplicate the original background layer and then use the Multiply blending mode. This was a little too much so I reduced the opacity to around 65%. Then I used your straightforward example to add a mask with a gradient. For the gradient I reduced the opacity to 30% and applied gradients several times to mask the grass and cabin as well as the clouds on the upper left partially. Then I added an adjustment layer to saturate the dry grass and cabin in the foreground. In the mask for this adjustment layer I used your method again to mask the sky from the top down to just allow the cabin to get saturated. This was way better than using selections or painting in a mask. Thanks again.
0 upvotes
jean miele
By jean miele (3 months ago)
You are very welcome, Martin45. Thank you. It's fantastic that you were able to integrate using a Gradient in a mask; that was my goal in creating the tutorial. And your "variation on a theme" sounds just great. Jazz improv, right? ; )
0 upvotes
Giuseppe Fallica
By Giuseppe Fallica (3 months ago)
Improving photographs working on levels, curves, contrast, saturation, filters, lights, shadows, gamma, as well as using HDR techniques, photo stacking, etc.., is deontologically appreciable, because the final result, however, isn't a fake: only a picture improved.
Techniques such as the one here illustrated, however, leave me puzzled because goes beyond the Photography and entering the creative montage. Which often has a great artistic value.
But that's not Photography.
4 upvotes
jamesfrmphilly
By jamesfrmphilly (3 months ago)
says who?
2 upvotes
jean miele
Ciao, Giuseppe. Thanks for commenting. You're not the first one in this thread to say "that's not photography" or some variation on that theme. Personally, I think “photography” is a BIG word. I doubt Sir John Herschel could have imagined that the term would grow to encompass such a vast range of uses, processes, media and intentions when he popularized it in 1839. From the beginning, our beloved "painting with light" was diverse and ever changing, and has grown into a spectrum that spans art, documentary, family snapshots, advertising, pornography, scientific research, and a thousand gradations and variations between. It includes nearly a hundred distinct photographic processes (so far!), ranging from daguerreotype to Hipstamatic, and is presented on an impossibly wide array of media and substrates, including glass, metal, paper, and LCD, to name just a few. *more below*
4 upvotes
jean miele
If photomontage isn't a part of photography, that's bad news for me, and a bunch of other people. Pretty sure Jerry N. Uelsmann (as Amadou mentioned earlier) is a photographer. Not to mention Carleton Watkins, Gustave LeGray, Henry Peach Robinson… and W. Eugene Smith. Smith, unarguably one of the icons of photojournalism, wasn't above creating the occasional photomontage, as evidenced in this recent NY Times Lens blog entry: http://lens.blogs.nytimes.com/2013/01/03/w-eugene-smith-i-didnt-write-the-rules-why-should-i-follow-them/
The way I see it, we all love photography, and there's room in that word for all of us, regardless of the kinds of pictures we like to make.
3 upvotes
lafab
By lafab (3 months ago)
Thank You so much Jean for the fantastic article .
And all you " anti-photoshop talibans",what about all great wildlife photographers,no fakes at all,or the great guys at Magnum for long,long time ago.like Robert Doisneau with his legendary "Kiss by the Hotel de Ville"; fake or not?
When humans or animals are directed and manipulated by the photographer,is the result then just a poor fake ?
0 upvotes
Giuseppe Fallica
Do not get me wrong.
I assumed that creative manipulation has a great artistic value, often even more than in documentary photography.
But it's another thing.
It's therefore necessary to understand what we are talking about: creativity or photojournalism?
In the first case it's ethically permissible to use any tool. No limit.
In the second case, It's ethically allowed the use of calibration tools, but not "manipulation".
It was discovered that some photographers, trying to emphasize the famous tsunami a few years ago, have created photomontages using pieces of Niagara Falls.
This is unethical.
The newspapers, now more than ever, in the digital age, they are very strict in this respect.
0 upvotes
Giuseppe Fallica
- continue from -
And I do not mean just photojournalism social or war reportages. Even the landscape photos are discarded without hesitation by newspapers such as National Geographic, if counterfeit beyond what is a simple calibration.
The case of the legendary Robert Doisneau photo "Kiss by the Hotel de Ville" is completely different. We discuss it if the kissing couple is casually on site, or it's a couple in a pose. But even in the latter case, technically, no question of a montage.
Infact, one thing is to create a scene or a situation. Another thing is to remove people with rubber ...
0 upvotes
Giuseppe Fallica
P.S.
Jean, It's obvious that my comments were related to the purposes of the technique, not to the the "technique itself". Your tutorial is a masterpiece and I will be the first to use it!
0 upvotes
Jack76
By Jack76 (3 months ago)
Heck, back in the fifties we took the two negatives and printed what we wanted out of the first negative, and then added the sky from the second negative. You probably had to make maybe a half a dozen prints before you got a good one. But that's the way we did it back then and no one griped.
Also way back beffore they had panchromatic film we used orthochromatic film that was color blind Practically insensitive to red - NOT BLUE.
0 upvotes
aja2
By aja2 (3 months ago)
Is there anyway to add this to my favorites or bookmark this article within DPR? I don't have time to read the whole thing but am very interested in the subject, since I needed to learn how to do this months ago!
0 upvotes
jean miele
Sure, aja2. There are a few possibilities. I use both Evernote and Instapaper to save things for later reading. (There are also many other services like these.) Another possibility is to simply "print" the browser page as a PDF, and save it to your hard drive. Whichever method you choose, you'll need to save page 1 and page 2 of the article individually. Glad you found it helpful enough to want to refer to it again : )
0 upvotes
GSpix60D
By GSpix60D (3 weeks ago)
You could save it for later using Evernote and its Chrome extension. I do this quite a lot, as I have memory problems.
0 upvotes
QSMcDraw
By QSMcDraw (3 months ago)
Just had to laugh at the many, many pompous comments about PS being a cheat, or about how many "better" ways this could be done. I remember when these same pompous jerks used to work at camera shops, making beginners walk out, enthusiasts feel stupid...Now most of those shops are out of business. Wonder why?
3 upvotes
AbrasiveReducer
The reason camera shops went out of business was that people had no reason to keep going to camera shops. When was the last time you needed a roll of film, spare (disposable) batteries, a photo album and to pick your prints? And don't forget the stop bath and a spare bulb for your slide projector.
0 upvotes
sm176811
By sm176811 (3 months ago)
Thanks! Great article - simple and short!
2 upvotes
peacefrog33756
By peacefrog33756 (3 months ago)
Many thanks for a very helpful and informative article.
2 upvotes
wildplaces
By wildplaces (3 months ago)
Thank you for explaining the basics of gradients used with masked layers...it is always helpful to see these techniques explained in simple terms using sample images this way.
2 upvotes
Steve Parkin
By Steve Parkin (3 months ago)
I know more than a few people who I see and hear complaining about Photoshop - who are folks who have not embraced it and therefore, cannot use it to its full advantage. Back in the times when Photoshop didn't really exist and everybody's photos were based on how well they came out of the camera, these guys were kings. Now with post processing and other tools, they have lost that status somewhat. 3 photos layered into 1 to produce a shot that looks better than the single frame. Lets compare.
The guy doing the layered piece of art is making something that looks better (perhaps?), and still requires a camera to create it. Making great images is a lot of fun. Not much complaining from this guy.
The guys doing the single frame shots that I'm referring to get to prattle on about how bad Photoshop is and how if there was a contest like the old days when you had to use a camera and not Photoshop, they'd still be the best.
Ego.
Comment edited 2 times, last edit 5 minutes after posting
5 upvotes
TLD
By TLD (3 months ago)
Steve, your comment puts me in mind of responses encountered in my camera club, and always from old school members with limited computer skills.
One factor has to be intended end use of 'created' images, and if for competition use, if the rules allow radical image manipulation, then a person disadvantages themselves if they refuse to encompass that option in their images.
The PSNZ (Photographic Society on New Zealand) uses this flickr stream to host winning exhibition and salon entries, and the images show a slight predominance of heavy Photoshop use, but there are still enough straight photographs to satisfy the conservative shooter.
http://www.flickr.com/photos/psnz/
Our professional body the NZIPP shows an even greater percentage of heavily manipulated images in its annual Iris Awards
http://www.nzipp.org.nz/nzippweb/Default.aspx?tabid=422
It seems to me that you ignore these image manipulation tools at your peril!
0 upvotes
Steve Parkin
Quite a bit of narrow minded thinking from people who feel that their way is the only way to be a photographer.
Really, I think the biggest issue at play is EGO. Thats a hard thing for people to admit to. The point of photography? I always thought it was to create images. A camera records reality the way a camera sees reality. Not the way it really is. We override the camera in such a way that the camera produces things closer to OUR vision. How is that different than Photoshop?
You can use white balance on board the camera to produce a total lie as easily as a layer mask can.
I do not condone dishonesty in image making; I do condone interpretation and artistic license. It seems that there are too many ego driven people stuck on the idea that the best image makers are the ones who can do the best using just a camera. The point of this game is to make great images, right?. Why limit yourself to just a camera in the art-making process? When so much more is out there to use?
3 upvotes
M DeNero
By M DeNero (3 months ago)
Jean Miele is a great photographer known for highly artistic images. So, I would know to look at this with some suspicion of license. Personally I draw the line on composites. Composites compromise the power of photography, shifting the emphasis from a photographer's reaction to the subject to mere artistry. As for the subject example? The final may be marginally better than the original graphically, but in terms of meaning it adds nothing. In fact, knowing it a composite of separate scenes diminishes the image.
2 upvotes
QSMcDraw
I agree that there is a certain purity of viewing experience when we know that a photographer caught a special confluence of elements and did not alter reality. If this is the type of photography you most admire, enjoy! However, to disparage other types of approaches, in this case composites, and sniff that such are, as you bizarrely state, "mere artistry," paints you as pompous, rather than embracing. Photography appeals to so many because it is offers so many ways of expressing oneself. Embracing some does not require us to belittle others!
Comment edited 2 times, last edit 15 minutes after posting
0 upvotes
M DeNero
Yes, I enjoy a "confluence of elements". I also enjoy abstract photography and accept some well done composites in that realm. I have no problem with composites for advertisements, illustrations, or art, but almost all have absolutely no place in photography that includes documentary intent. It is important that general perceptions are considered. Viewers in general are very receptive to photographic illusions, abstractions, exaggerations, etc created in an artful way. Viewers even tolerate outright manipulation when it makes a point, or when it is meaningless. But show somebody a photo of something they care about and you better watch out! You better be sensitive and not twist it to meet your ego. Or you won't be trusted.
0 upvotes
jeep
By jeep (3 months ago)
One of the best uses of layer masks is selectively combining different exposures of the same scene to achieve a natural looking HDR image, without the overblown look of HDR software and tone mapping.
1 upvote
Dvlee
By Dvlee (3 months ago)
If done proerly, HDR can yield pefectly natural results. And an image properly tonemapped for a natural look appear more natural than an image pieced together in layers.
It's a matter of skill, and a matter of intent. And very much a matter of opinion.
There are times to strive for a natural look and a time for a more surrealistic look. This has been true not only as long as photography has been around, but as long as art in any form has been around!
Unskilled artists tend to be a bit heavy handed when applying special effects. But in the right hands, heavily tone mapped images may bring a beauty and interest to a scene that would otherwise be dull and boring. It takes as much skill to apply a heavy special effect without over doing it as it does to apply the effect to make it appear natural.
I revisited some of the images I had pieced together from bracketed shots and layers, and tonemapped them in HDR. They look more natural via HDRI than through layers.
Comment edited 50 seconds after posting
0 upvotes
TheDman
By TheDman (3 months ago)
"an image properly tonemapped for a natural look appear more natural than an image pieced together in layers"
I couldn't disagree more with this.
0 upvotes
TLD
You can't possibly make that statement and maintain credibility. You might have admired any number of pictures without realising they were tone-mapped. One of the biggest problems with HDR is that the worst examples are the easiest to spot. Apps like Photomatix have advanced enormously over the years, and it is much easier to photorealistic HDR nowadays - even if you are not very good at it.
0 upvotes
TheDman
I certainly can. How can you get more photorealistic than an actual photo? The image in this example is just two photos pieced together in layers... are you saying it's LESS realistic than a tonemapped image of the two? That's ridiculous.
0 upvotes
madeinlisboa
By madeinlisboa (3 months ago)
The more Photoshop you use the less photographer you are... I use Photoshop only for creativity and extreme problems. I still use Capture NX for 99% of my photos.
It's sad to reach a point when you don't know if it is a photograph anymore...
3 upvotes
Dvlee
That sounds very much like what they were saying about Eduard Steichen 115 years ago!
The painters said it wasn't art and the photographers said it wasn't photography.
Your opinion on Photoshop simply defines how you prefer to approach photography and is not an accurate description of all photographers.
Long before digital photography existed, we used to say that clicking the shutter is only the start of the photographic process. There's alot that takes place after the exposure is made that must be done for the photographers vision to be realized.
I could argue that if all one is doing is making a few tweaks in tone and color, that it's really no different than a snapshooter who drops the film off at the minilab and lets someone else finish the process. That would be an inaccurate statement but no less accurate than saying that using more photoshop makes one less a photographer.
Photography is a two step process, one is what happens before you take the shot, and one after.
2 upvotes
TheDman
So you use Photoshop correctly, and everyone else uses it incorrectly. Got it.
0 upvotes
Michael Wilkinson
By Michael Wilkinson (3 months ago)
I started life as a photographer in 1965 and have been cheating ever since.hot water on part of a B+W print to bring up detail,a dab of fix to stop development in one spot,shading,printing from multiple negatives.
I love what Photoshop lets me achieve.I no longer worry about how to prop something up in the studio,blemishes on products can be removed etc.
Photoshop is the perfect tool to compliment digital images.
0 upvotes
Timmbits
By Timmbits (3 months ago)
Why not invert from left to right (mirror) the dark sky image, so that it works with the direction of the shadows on the structure? The main problem I see with this, is that to me, it is not a believable composite, because first, the building is so bright it looks like it's in broad daylight, but there's this dark sky over it, and second, the point where the skies may be lightening up is on the left, while the shadows imply a light source from the right.
I understand it's just an example and the point of the article is otherwise, but I feel that while we're on the topic of making "believable" composites, light source, light intensity and contrast, and direction of shadows still have to be all taken into account, to make it work. And this is part of the job with such an undertaking.
1 upvote
jean miele
Feel free to download the jpegs from page 2, and try it yourself. That's why we're providing the practice images :-)
2 upvotes
Da99ve
By Da99ve (3 months ago)
The original dramatic sky is great, too. Leave it alone, as well. ;) No big foreground focal point is required other than the gentle arid nodule already there.
If this was all just a hypothetical test, fine. But I hope people don't over-think their original visions/moments, which is the heart of photography.
0 upvotes
Dvlee
The brighteness on the right side of the sky makes the image seem less ominous. That might have been fixed with just a tonal adjustment, but since the point of the article is about blending images, that would have defeated the purpose of the article!
0 upvotes
Da99ve
I haven't scrolled through all the comments below, but the combined photo is a bit silly-looking, because the sun is now behind the dark clouds (as evidenced by the original foreground), yet we still have the strong-lined shadows on the building from the original sun high and to the right.
The homestead's original sky is great. Leave it alone.
Over-processing turns a photo into a painting or at least 'photo art'. Label it as such.
Comment edited 11 minutes after posting
0 upvotes
jeep
I've used layer masks for blending for some time now, but have always used feathered brushes set to 10% of black or gradients of black to transparent, so the introduction of white is new to me, will give it a go.
Thanks for an interesting article.
0 upvotes
Wildbegonia
By Wildbegonia (3 months ago)
Thank you so much for sharing, nicely explained. Hope you will be posting some more.
1 upvote
Neodp
By Neodp (3 months ago)
Gimp has an excellent youtube channel to help the Gimp user accomplish almost anything.
2 upvotes
sickdog1674
By sickdog1674 (3 months ago)
Photoshop Elements has an excellent youtube channel to help the elements user accomplish almost anything the program is capable of doing. Excellent article though helping me expand my knowledge of a seemingly endless learning process with Photoshop. I do what makes me and the customer happy and that is all that counts in my photography, everybody is an artist in their own way
2 upvotes
Alejandro del Pielago
By Alejandro del Pielago (3 months ago)
Who says "blending images is a sin"???
Light up the darkroom: since the first 'camera oscura' to paint with perspective, even before, painting the walls inside a cavern, man are "cheating" "the real world" again and again...
2 upvotes
Easycass
By Easycass (3 months ago)
A good article. There will always be various ways to achieve better results; explaining the technique was the point.
And ‘cheating’? Even purist photographers are never able to fully represent reality. Would that mean everyone ‘cheats’?
In camera we: crop, rotate, use focal length, DOF, compression, distortion, shutter speed, expression, props, shadows, viewpoint, film, exposure, blockers, lighting, reflectors, masks, filters, etc.
In the darkroom we: dodge, burn, mask, filter, diffuse, solarize, graduate, spot, colour balance, vignette, bleach, and even do composites (you know, a house and a different sky) by multiple exposures and sandwiching negatives.
In Photoshop we: do all of the above and more.
All the above distort what is reality. Am I to believe that those ‘photographers’ here who accuse people of ‘cheating’ do none of the above?
Photography - Painting with light - You do not have to like what is created, but love that we have the ability and freedom to create...
1 upvote
Wye Photography
By Wye Photography (3 months ago)
Have you actually ever tried doing composites in the darkroom?
I don't think you have. Because you'll know how bl00dy hard it is and how much skill it takes to do it successfully. And it's usually a one-off. You can't repeat exactly what you have done previously..
In Photoshop its click, click, click, drag, drop, click, click, click. Done. In minutes. In the darkroom you can work for MUCH longer than that.
You say in the camera we... In the darkroom we.. Yeah, sure, but those things actually exist. You are confined by physical and chemical realities. Not so in your fake photoshopped world.
Have you tried, say, removing that small annoying seagull that just happen you fly into your shot ruining your sky. On a colour RA4 print it's impossible (apart from actually 'airbrushing' over it). In a B&W silver gelatine print, well, give it a go! All you digital freaks get off your ar5e and give it a go with a real B&W print.
Photoshopography: Painting with pixels that don't exist!
2 upvotes
Easycass
Hi there Wye,
Your opinions are strong. It is good to find someone with such passion, and nothing wrong with it, especially if it really is what you believe. I looked at your website too, and I have to say you have some wonderful photos.
I especially noted your section that included, "Photos of Wales taken on the iPhone 4S and processed on the iPad2."...
I guess you don't mind heavily processed photos afterall, but maybe only if done on an iPhone...? But I must say, a bit of a disappointment after you showed such passion against such things...
1 upvote
AluKd
By AluKd (3 months ago)
"Have you tried, say, removing that small annoying seagull that just happen you fly into your shot ruining your sky. On a colour RA4 print it's impossible (apart from actually 'airbrushing' over it). In a B&W silver gelatine print, well, give it a go! All you digital freaks get off your ar5e and give it a go with a real B&W print. "
That's actually patently false, as part of my film photography classes was exactly replicating digital darkroom techniques in an actual darkroom - and yeah, we did actually remove stuff and composite photographs, both B&W and RA4 through frame splicing and clever use of masks. Is it easy? Nope. But it's doable - and, furthermore, people have been doing these very things since forever.
2 upvotes
Wye Photography
To Easycass
Thank you for your comments. My iPhone 'stuff' is peculiar and exclusive to the iPhone. I do enjoy working with the iPhone and iPad and do it in such a way as to make it obvious that the images have been modified. It's fun and a tonic for the jaded. It's blatant iPhoneography as they call it. I would NEVER pass it off as 'authentic', not that I possibly can. As the iphone 'work' is in its own pigeon hole, I may remove that gallery. Is it really 'photography'?
I don''t actually mind people modifying images, making panoramas, montages, blends, composites etc. IF they make it clear that this is the case. My whole point is passing such work off as an original one frame shot when in actuality it isn't.
That, my friend, is my whole issue.
I totally respect people who say things like "this image is a composite made from three frames" or "I removed...", "Changed..."
It is a question of honesty and integrity.
0 upvotes
Wye Photography
To AluKd
If I wasn't in such a hurry I would have chosen better words. I should have said "largely impossible", for some workers, it is because they can't achieve the level of skill required.
Tell me, removing said hypothetical seagull from an 10x8 inch RA4 print, how long? Chances of success on first go? How much space and equipment required? How much time would you have to put in to pull it off convincingly?
I can teach one of the office girls (most of whom do not like IT) where I work to remove said seagull from a .jpg in 15minutes maximum.
As you say, it's doable, but with what kind of skill and effort?
Before digital, Newspapers had teams of guys who whose sole job it was to touch-up photographs from film. Airbrushing was an art using real airbrushes not the photoshop tool. They were highly skilled people made redundant by a bit of software that anybody can use.
Photoshop can do much, much more, much quicker, with much less skill. You have never had it so good (or bad)!
0 upvotes
Irata
By Irata (3 months ago)
@Wye Photography:
Sounds to me like you're mixing two different things in your rather passionate posts, so:
What is your issue? "Authenticity" or "too easy in Photoshop these days"?
I don't care if the seagull's removed in Photoshop, or if it's removed on a "real" print. The later takes longer & more skill, but the result will be the same: seagull removed.
As for authenticity: there is no such thing. Take, for example, Robert Capa's "Death of a Loyalist Soldier". People still argue today whether the image was staged or not.
PS: Keep your iPhone pictures up. They're nice – and after, all iPhone photos ARE "photography", which is "painting with light" in a black light-tight box. Doesn't matter if it's film or a sensor involved ;)
0 upvotes
JakeB
By JakeB (3 months ago)
@Wye
You're whining because a faster, more accurate procedure has supplanted the darkroom where results were difficult to achieve and hit and miss?
You have no idea how to use Photoshop and like most of the old duffers on here are reacting out of fear of what you don't understand.
Click, click, click. indeed.
0 upvotes
Wye Photography
@JakeB
Sorry laddie, but I have been using photoshop PROFESSIONALLY as a Graphic Designer since version 2.5 Currently I run CS5.5
Old duffer eh! Well, this one being ex-Army is probably more fit than your are.
I think when this computer/gadget fetish runs it's course people will want to return to a simpler, unfiltered, humble way of making images.
You rely on a plethora of software engineers and programmers for your images. I don't. When I think about it, you don't actually make your images, Abobe's code-heads do.
0 upvotes
AluKd
"You rely on a plethora of software engineers and programmers for your images. I don't."
Unless you built your camera from the ground up, you do too.
0 upvotes
Wye Photography
@Irata
My issue is expressed in my comment above yours (I hope it was clear). The ease of it doesn't bother me per se, I was making the comparison that in the 'old days' faking, composites etc took really skill and a lot of hard work. Photoshop isn't hard work, it's easy.
Perhaps I have been using PS for too long. I went through all the stuff like I see and read here. There comes a point when you become sick of it all. Sick of all the computer generated un-reality. Perhaps you'll come to that point one day.
Like you, once I didn't care how the seagull was removed. Now I do. I suppose I've around digital media too long.
For me, authenticity is important, as is honesty, integrity and being genuine. Personally, I think Capa staged it, Alexander Rodchenko faked it a lot. That's not genuine. It's lying. Some people are like that. I am not.
Thanks for your comment about my iPhone pictures. I don't know where that sits with me yet. I'll take your comments aboard. Take care.
0 upvotes
Wye Photography
@Alukd
That's true. I could build my own camera though, it's not that hard. I have given it some thought actually. Building my own camera one day. I have already mixed my own developer, made Cyanotypes, that's a little start.
I like to see you write your own version of Photoshop! LOL.
0 upvotes
AluKd
Not that hard, actually. I mean, that's pretty much what Knoll did with PS 1.0. It's certainly doable.
Making your own digital camera from scratch, though, that's much harder ;)
On the other hand, I've built my own film camera, already. It's a cakewalk.
0 upvotes
Easycass
Hello again Wye,
I do understand your desire for a personal authenticity, but as you say, I think as long as people do not try to pass any modified image as something it is not, then we are happy.
Believe it or not, I am with you, and prefer unaltered images as much as possible. I used to think the only image that came close to be straight fromn the camera at least, was a positive slide, no printing, no cropping, only the film, ASA, aperture and shutter to get it right. I do allow myself a bit more latitude these days... Though sometimes I still can't bring myself to straighten a horizon in PS!
But I guess I have learned to appreciate there are many forms of photography these days, many ways to poduce 'the image', and so long as 'it works', I try not to judge 'how' they made it work...
Ps...
I too think you should keep the iPhone shots on your website. I really liked them. Whether they are photo-like or painterly, for me it only mattered that I enjoyed looking at them...
0 upvotes
Wye Photography
To Easycass and AluKd
Many thanks for your comments, I appreciate them.
It will be very interesting to see how the technology, software and the direction photography takes actually pans out in the next five or so years.
AluKd, when I said 'build my own camera', I did actually mean a film camera (I do shoot film, and more recently). If you feel so inclined, please send me details of your self-made-camera, I will be very interested in that.
May your Light always be wonderful!
0 upvotes
Irata
@Wye Photography,
I'm still a little confused... The first paragraph in your last reply to my post is contraticting in itself I think. ("The ease doesn't bother me..." <--> "Photoshop is easy").
Anyway... more importantly, about the seagull being removed: I hear what you're saying, but my point is: apart from your very own photographs you'll never know if there was a seagull in the first place – both with analogue or digital.
Personally, I keep retouching to a minimum: colours, contrast, maybe a little d&b. All those things could also be done in the analogue world (I used to work as a C-Type printer): different film stock (Kodak Portra vs Agfa Ultra for example), printing on different papers (Fuji negs on Kodak paper or vice versa),...
So, unless I took the image myself and/or porcessed it myself, I'll never be able to tell if it has been manipulated – and besides that: manipulation starts with focal length, camera position and angle, and the moment we press the shutter.
0 upvotes
Neodp
How to merge three images together; using Gimp
http://www.youtube.com/watch?v=LXVaEQbzKyc
1 upvote
Sunburned
By Sunburned (3 months ago)
I bought a fish yesterday. So i'm a fisherman, the expert one who can take any fish he wants!
I'm not a photographer and i don't say it's cheating. But i prefer to differentiate Editing and Designing from Photographing.
Thanks for useful article. It can help my terrible photos seem better.
0 upvotes
sanjja
By sanjja (3 months ago)
A well-written and helpful tutorial on how to use the gradient tool, but I agree with the comment that for the images used, that tool might not be the best choice. Here, it might be simpler to paint the mask with a 100%-opaque black brush in most of the area above the subject of photo 1. The only area requiring something less than 100% opacity is the area immediately above the subject. Because both photos have sky in this area, a seamless blending can be achieved in this area by feathering the brush and playing with its size and opacity. Once this is done, photo 1 can be moved around to achieve the most desired look. Still, the purpose of the tutorial was to illustrate how the gradient tool works, and in this regard, it well succeeds. Thanks.
0 upvotes
jean miele
Thanks for the kind words, and the feedback. A friend of mine, Brian Reed (from Hawaii and Sweden) is a great photographer and a musician. He once told me he thinks Photoshop is like Jazz Improv. Within the form there's room for a vast range of approaches, styles, and interpretation. And the analogy extends further: Photoshop is - literally - a keyboard ; ) instrument. It seems like there are almost always three ways to do the same thing in Photoshop, and this case is no different. Masking with brushes, feathered selections, Gradients - or a combination of all three… these are just variations on a theme.
9 upvotes
gsum
By gsum (3 months ago)
Well done for producing a good result and for sticking your head over the parapet.
I would liken Photo$hop to a jazz improvisation played by a pub jazz band on plastic instruments with half the keys missing. Capture NX and the Gimp are far more effective and lower priced tools (gimp is free) for the sort of manipulations that you're doing.
3 upvotes
showmeyourpics
By showmeyourpics (3 months ago)
Hi, I already commented on this technique but want to add my contribution to the issue of photographic realism. There is plenty of scientific evidence about the amazingly complicated way the eye-brain system "perceives" images, a personal mix of physiology, neurology and psychology influenced by the other senses, and how profoundly different it is from any technological means. It varies significantly from person to person or with the same person at different times. The conclusion is that there is no "realism" between the subject and the print no matter what we do. "Pure" b&w is even more abstract than color. From the camera side, we have the choice of letting the processing engine turn out an arbitrarily developed jpeg or processing the raw image ourselves. I am safe from this mess because (my) fine art photography, by definition, has no practical application but beauty and enjoyment. The only fundamental rule to follow is to be honest about what we are doing.
3 upvotes
QuarterToDoom
By QuarterToDoom (3 months ago)
Totally cheating as you're creating something new out of two separate images so its not photography and more in line with art/graphic design. Whats next on DPR, how to design sales flyers?
1 upvote
Dan Nikon
By Dan Nikon (3 months ago)
Actually, I am glad it is being done. More and more people who have the money to invest in art such as wealthy second home owners, luxury real estate developers and interior designers are coming to me for real hand made prints done in a real darkroom to meet these needs. Less and less people want photoshopped garbage because it is not hand made and is worthless from the outset.
0 upvotes
Steve and the dogs
By Steve and the dogs (3 months ago)
Except of course, this sort of stuff was done in the old darkroom days.
1 upvote
TheDman
Oh it's definitely handmade. And my sales of "Photoshopped garbage" aren't going down at all.
0 upvotes
pkincy
By pkincy (3 months ago)
I have owned Elements 9 for 3 years and don't use it at all because of the steep learning curve. And this seems to offer the same problems. I can follow every step of the tutorial, but again the author assumes that we know what we are doing and leaves us with 3 images; a Photo 1, a Photo 2 and a Gradiant mask. Then he quits! I suppose to many it is trivial how to then combine the 3 but to someone new to Photoshop it isn't.
So I have 3 images with no know way to combine them. Frustrating and precisely why I won't take the time to learn the software, it is completely counterintuitive. Likely a great tool but only for those that have the hundreds of hours needed to learn it properly.
2 upvotes
Thorbard
By Thorbard (3 months ago)
Following the instructions on page 2 of the article will give you the two images combined. If you can't do it because you've not followed the article correctly, not learning it is just laziness.
On the other hand, if you don't want to learn, no-one can blame you for that. But there are plenty of beginner level articles out there.
0 upvotes
Robert Eckerlin
By Robert Eckerlin (3 months ago)
Thorbard
I am not sure that you are right. I am myself also a PSE user (and not a Photoshop user), and for me too it is not evident how to do the job with PSE....But of course, this is not at all a critics towards the tutorial,....which never claimed to be an Elements tutorial.
Comment edited 24 seconds after posting
0 upvotes
Ken Croft
By Ken Croft (3 months ago)
I have owned and used CS3 for several years for basic operations and I thought I would like to know more about the clever stuff and that this piece would be useful. I worked through it concientiously but I did find it difficult to follow. My guess is that if you found it easy to follow, you didn't need the instruction in the first place because you already know your way around pretty well. In the end I too was left wondering how to end up with a combined image because what I did end up with was not very good to look at. I guess I will just stick to the relatively simple stuff that I know how to do, until intructions are produced for those of us who need guidance, not for those who already understand but are just looking for something to criticise, or to show that they know an even better way.
1 upvote
Dennis
By Dennis (3 months ago)
It's a great technique - I'm not hung up on issues of "cheating". But I also don't like techniques that result in images that look fake. When I look at the composite, I see strong shadows on the building from an overhead sun that obviously isn't there (yes it would be out of the frame, but couldn't be there with those clouds). Still a useful article, but it would be better with a photo that shows why you would want to do it, not just how you do it.
I think the author has some fascinating stuff on his own website, very different from anything I've done and very different from the landscape shot used in this article.
1 upvote
Da99ve
I fully agree - an <exercise only> is fine. (The original shots can stand on their own.)
0 upvotes
jpdenk
By jpdenk (3 months ago)
Thanks! I've been wanting to learn more about the gradient tool, and you've done a really nice job of explaining its potential and how to get using it for more stuff.
I just read some of the comments about this, and apparently there are a lot of people who don't realize that many people use Photoshop for stuff other than photo optimization. The technique in this article can come in very handy when one is making composite illustrations for publications and other creative endeavors. Nothing wrong with photo manipulation either, as long as it isn't presented as being out-of-camera results. The article is of potential use to many people, and I thank the author for it.
Comment edited 8 minutes after posting
3 upvotes
l_d_allan
By l_d_allan (3 months ago)
Very helpful article. Thanks!
I am not at all a "purist" as far as the "composites are not art mindset / camp". YMMV and my 2¢
I've been struggling with getting decent composites with winter trees in the foreground. As the author points out, that's a difficult compositing task. "Refine Edge" and "Color Range" haven't been coming out all that well. Neither has the Fluid Mask plug-in.
While this could be a case of "a poor craftsman blames his tools", I'm hoping that the Gradient mask approach you describe will not only be simpler, but work better.
4 upvotes
jean miele
It's not you. We've all been led to believe that silhouetting two pictures together in Photoshop is easy. In fact, it's one of the hardest things to do, especially when there's fine detail, like tree limbs. For some reason, maybe it's just human nature, I notice that even photographers with lots of darkroom experience reach for a selection tool first when they're in Photoshop - even though that's an approach that wasn't really available to most of us in a traditional wet-darkroom. (I actually tried using litho film and pin-registration a few times, but I think most people just stuck with the old fallback: cardboard.) Counter-intuitively, I think it's possible to get much better results by blending images together, rather than trying to cut them out. This approach emulates the way we used to approach burning & dodging in the darkroom: feathered and blended edges, created by moving the cardboard as we exposed the paper. The Gradient tool seems made for this.
1 upvote
AluKd
Complex composites are a matter of mixing techniques. Gradient masks are awesome as a rough starter - you can get most stuff out of the way with a few clicks, with very good results.
You can then focus on the foreground elements - I usually go about it by painting on the same mask with a digitizer, what gives you a lot of control and precision. You can reduce the Flow and achieve semi-transparency of borders, what helps mixing the layers. Takes time and a lot of effort, sure, but the results are top notch.
You can do something similar with Poly Lasso, painting with the mouse and a lot of elbow grease, as well.
One of the things most people tend to miss, though, is the value of applying global effects to all the layers. Whenever you apply the same effect to all the layers of a composite, you make them aesthetically closer. For instance, something I usually do is apply small hue shifts and grain.
Comment edited 4 minutes after posting
0 upvotes
Cane
By Cane (3 months ago)
This thread is full of miserable people.
12 upvotes
AlexBakerPhotoz
By AlexBakerPhotoz (3 months ago)
Thanks very much for this, I have done the same thing a variety of ways but this is nice and quick and smooth, much easier to do with the right image. As a landscape photographer I meet this challenge often. Here you are in this great place with a wonderful foreground and a drab, dreary sky, but today is the day you are here and tomorrow you have to move on. I keep a file I call "Big Sky" with just images of different types of skies that I use for just this occasion. Fake? Don't be silly, were Van Gogh's landscapes fake? Marshall McLuhan said: "Art is whatever you can get away with." I have lived by that maxim for a long time now. If I made it, it's my work, and stands on it's own.
Comment edited 1 minute after posting
8 upvotes
Robert Eckerlin
Alex, I love your "were Van Gogh's landscapes fake?".
I really believe that both sides have valid arguments....It really depends on what one is interested in when looking at photographies.
And I really believe that the Tutorial will be useful for a lot (of course: not all) dpreview Website users.
2 upvotes
Steve Balcombe
By Steve Balcombe (3 months ago)
Pity the comments section has been swamped by an irrelevant discussion.
But regarding the technique itself, I'm sorry but using the gradient tool is poor advice. You can just about get away with it in this particular case because there is a conveniently detail-free straight band just above roof height in both images, but in general you won't have this. The wiser and more versatile technique would be to marquee or lassoo the area to be revealed and refine the selection to create a soft edge before filling the selection with black/white as applicable. Or in many cases it's quick and convenient to select first then create the layer mask from the selection. You can then fine-tune by painting with a soft brush, or whatever suits, directly onto the layer mask.
There are applications for using gradients on layer masks, but this isn't one of them.
3 upvotes
showmeyourpics
Agreed, this technique has the limitations of a split neutral density filter and works best with straight, simple horizons. I most cases, landscapes are more complicated and require the techniques mentioned by Steve.
1 upvote
msamir
By msamir (3 months ago)
Well I just used this in a project I'm currently working on (I'm a 3D architectural visualization artist) and it works perfectly well, thank you very much for this tutorial.
3 upvotes
Bram de Mooij
By Bram de Mooij (3 months ago)
So some people call this cheating. And why should I care ?
Nice article.
6 upvotes
Robert Eckerlin
A general question about Photoshop and Photoshop Elements Tutorials on the dpreview Website.
I wonder whether for the dpreview Website, helping/educating via Tutorials Photoshop-Elements (PSE) users can (at least) make as much sense as helping Photoshop users.
On one side, I guess that the dpreview Website attracts more sophisticated semi-professional and professional Photoshop users than it attracts the less sophisticated PSE users.
But on the other side, less sophisticated PSE users could benefit more from tutorials like this one than the sophisticated Photoshop users (who are probably in their majority already well aware of techniques similar to the ones that are described in this Tutorial). Also, there are probably more PSE users than Photoshop users.
I am curious to learn, whether you too think that tutorials for PSE users could make sense on the dpreview Website...and curious to see if we will see in future such tutorials on the dpreview website.
Comment edited 3 minutes after posting
1 upvote
HubertChen
By HubertChen (3 months ago)
Dear Robert,
In short, you can use this Tutorial to do the same thing in Photoshop Elements.
In more detail:
I checked with Adobe Online support. ( Hey I could chat to a person and got a meaningful reply instantly, I am impressed! ) Photoshop Elements has Layers, Layer Masks, Gradient Tool and Blending of Layers. This means you can do the exact same thing shown in this Tutorial with your Photoshop Elements. The written documentation I found on PSE was sparse to say the least. Your best bet is to google on Youtube the following:
a) Layers
b) Masks
c) Gradient Tool
d) Blending
Combine these search words with Photoshop Elements and the version number you have. Pick a tutorial that works for you. Once you know how to do these 4 things in your PSE you can download the two images from this tutorial and retrace each step in your PSE copy. Good luck!
( to avoid any confusion, I am not associated with dpreview other than I like it very much. I hope you find my post useful though )
4 upvotes
Robert Eckerlin
Dear Hubert
Thank You very much. Yes, indeed your Post is helpful. I tried a Google Search with the keywords you had recommended and i got useful results (...but I have not yet tried to use the found descriptions - this will come).
I too love very much the dpreview Website. In fact, I bought my photo equpiment based on recommendations or reviews found on the dpreview Website: my beloved Nikon D5000 camera, my 18-200mm Nikkor DX lens, my Lumix LX 5 compact camera and probably soon my future Fujifilm X20 compact camera.
Its a pitty, that Switzerland and China are so far away...
Thanks again
0 upvotes
showmeyourpics
Hi Robert, you make a very good point. I am a part-time pro fine-art photographer, quite proficient in PS, and do some teaching. To make a long story short, I do recommend my students to begin with PSE. It has been stated by many experts that you can run many photo businesses with Lightroom (image management) and PSE (image processing) without getting into PS. I would add that, if you learn ACR well, even LR alone would often suffice.
1 upvote
ianp5a
By ianp5a (3 months ago)
Useful article for most people. But reading some peoples posts here is amusing and also a bit saddening that some people "don't get it"
As long as you are not claiming it is a documentary picture, there is nothing wrong with enjoying producing any picture that pleases you. Using paint or software.
Cheating would include asking someone to pose for a picture or changing the exposure value in the camera. It's all manipulation, and should be stopped!
I recently used the same technique with the Gimp application to move some clouds lower in the frame. As it was taken from the same picture do the "anti-manupilation Nazis" accept that or not?
4 upvotes
HubertChen
Dear Jean and dpreview,
Thanks so much for a well thought out and concisely explained Article. It promises to solve a problem nagging me since long. I am very much looking forward to part 2.
I live in Guangzhou, south of China. Lovely place except there is smog most of the time, which can render as bad as plain white (non) sky in a shot. Your technique -- if I can get it to work-- promises to be swift enough to make images work which otherwise I would not even try to shoot or trash later on anyways. I can't thank you enough for this inspiration!
Comment edited 6 minutes after posting
5 upvotes
jean miele
Thank you for your comments, Hubert. As a landscape photographer, I've always wanted to go shoot in China. In fact, I just saw a beautiful exhibition in New York this week by Chinese photographer Wang Wusheng. (His photographs were made far from where you live, in Northern China.) These are a wonderful example of "straight" photographs that are absolutely transcendent. For me, the question of what makes some photography exceptional is always interesting. Most other dichotomies seem kind of beside the point.
http://www.huffingtonpost.com/2013/01/27/photographer-wang-wusheng_n_2534810.html
I hope you'll find part 2 useful!
0 upvotes
Total comments: 215
12
