Fujifilm has announced the WCL-X100 wide-angle adapter lens for its X100 large sensor, fixed-lens compact. The 0.8x adapter extends the camera's 35mm equivalent field of view out to 28mm equivalent. It is designed to match the X100 in terms of both appearance and quality, sharing the camera's Fujifilm's Super EBC coating and made-in-Japan construction. The WCl-X100 will be available from June at a price of around $350. To enable use of the converter, the company has also issued firmware v1.30 which adds a function for its use as well as fixing two minor operational bugs.
Press Release:
Valhalla, N.Y., May 15, 2012 – FUJIFILM North America Corporation today announced an exciting new premium accessory for the award winning FUJIFILM X100 – a Wide Conversion Lens (WCL-X100) that will further enhance the exceptional photographic experience of using the FUJIFILM X100 digital camera. The new Wide Conversion Lens will not only maximize the FUJIFILM X100’s shooting versatility and performance, but it will also add to the stunning look and feel of the camera with its exacting design similarities.
“We are extremely pleased to offer this new Wide Conversion Lens for the FUJIFILM X100, which has been enthusiastically received from the professional and advanced amateur photographic communities for its beautiful design and outstanding image quality,” said Go Miyazaki, division president, Imaging and Electronic Imaging Divisions, FUJIFILM North America Corporation. “Fujifilm is committed to giving photographers the premium tools that they need to achieve the best imaging results imaginable, and this new lens will allow the FUJIFILM X100 to exceed users’ expectations by opening up countless new shooting opportunities.”
FUJIFILM Wide Conversion lens (WCL-X100)
The FUJIFILM WCL-X100, a wide conversion lens made in Japan and designed specifically for the award winning FUJIFILM X100, attaches directly onto the camera and increases picture taking versatility by multiplying the fixed focal length by 0.8x, converting it from 23mm (35mm equivalent) fixed focal length to a 19mm wide angle (28mm equivalent). The WCL-X100 delivers superb optical quality and maximizes versatility of the FUJIFILM X100 by ensuring comparable image quality even at the f/2 wide aperture setting, all while retaining all the original optical characteristics, including the attractive bokeh effect.
The FUJIFILM WCL-X100’s optical construction uses four premium glass elements in three groups to keep aberrations minimal, and also employs the unique FUJINON Super EBC (Electron Beam Coating) for outstanding results.
Using the WCL-X100
Achieving the very best results from the WCL-X100 is simple: select the ‘Wide Conversion Lens’ option in the FUJIFILM X100’s menu system (camera must be updated to firmware version 1.30 or later) or select the function via the Function (Fn) or RAW buttons.
After selecting the ‘Wide Conversion Lens’ option, the FUJIFILM X100 automatically applies image processing to shots taken using the WCL-X100 to reduce image distortion, ensuring balanced illumination across the frame and reduced chromatic aberration which can be commonly found in wide conversion lenses.
The WCL-X100 maintains the full functionality of the FUJIFILM X100, including auto focusing speeds, the 10cm macro capability and of course, the extraordinary hybrid viewfinder. With the optical viewfinder (OVF) selected, icons showing the edge of the frame are displayed instead of the frame rim (equivalent to 80% of the frame field of view), while selecting the electronic viewfinder (EVF) gives users a 100% field of view.
The perfect match for the FUJIFILM X100
The design of the WCL-X100 has been carefully considered to ensure a seamless blend with the FUJIFILM X100. It uses the same materials, textures and colors as the existing X100, plus the optional LH-X100 lens hood and PRF-49S protective filter can be used on the conversion lens. Furthermore, the clip-on lens cap for the WCL-X100 can be attached with both the lens hood and filter in place.
FUJIFILM WCL-X100 key features
  • 0.8x magnification factor to convert X100 lens to 28mm wide angle (35mm equivalent)
  • All glass optical construction using four elements in three groups
  • FUJINON Super EBC coating
  • “Made in Japan” for optimum quality
  • Available in silver and black
The FUJIFILM Wide Conversion lens (WCL-X100) will be available in silver and black in June 2012 for $349.99.
