Tokina has announced a US price of $599 for its AT-X 12-28mm F4 Pro DX lens. Soon to be available in both Canon and Nikon mounts for APS-C bodies, this lens was announced at the CP+ tradeshow back in January and will replace the company's existing 12-24mm F4 wideangle zoom for APS-C cameras.
Jump to:
Press Release:
Kenko Tokina USA, Inc. is pleased to announce the new Tokina AT-X 12-28 mm F/4 lens.
Tokina AT-X 12-28mm F4 PRO DX
Wide Zoom Range
The new Tokina AT-X 12-28 mm F/4 lens has a super-wide to standard zoom range while maintaining a constant fast f/4.0 aperture. This makes it a very versatile lens for different photo applications such as scenery, street scenes photography and event coverage. The lens is designed for DSLR cameras with APS-C (DX) sized sensors.
New Optical Design
A new optical design using aspherical elements and super-low dispersion glass matches even the highest mega-pixel DX sensors cameras available today.
One aspherical lens element is positioned in the front group. This together with another precision molded glass aspherical lens element placed in the rear group ideally focuses marginal light rays and maintains sharpness at the edges while also correcting distortion. The use of two different SD (Super-low Dispersion) glass elements, type FK01 and FK03, corrects chromatic aberration. The combination of all these specialized elements in the optical design yield excellent sharpness and color.
New auto focus mechanism
The new AF "GMR magnetic precision" control sensor is capable of fast auto-focus. Tokina placed the new sensor closer to the drive unit in the lens for faster communication between the controller and AF motor. This combined with the motor's high-precision focus control yields faster, more accurate auto-focus.
Additionally, a brand new "SD-M" (Silent Drive-Module) has greatly lowered the sounds emitted by the auto focus drive system allowing for much quieter AF. Both Canon and Nikon mounts have a built-in AF motor to make them auto-focus compatible with all current camera bodies.
Compact body design
The Tokina AT-X 12-28 mm F/4 compact design makes the lens easy to carry and handle. Manual focus is achieved through Tokina's one-touch focus clutch AF/MF mechanism. Simply slide the manual focus ring forward for auto-focus or back for manual focus operation. The lens focus ring is damped in the manual mode for smooth and precise focusing.
In addition the lens has a 77mm filter size allowing filters such as the Hoya HD2 low-profile circular polarizer or UV to be used.
Tokina AT-X 12-28mm F/4 Pro DX specifications
Principal specifications
Lens typeZoom lens
Max Format sizeAPS-C / DX
Focal length12–28 mm
Image stabilisationNo
Lens mountCanon EF-S, Nikon F (DX)
Aperture
Maximum apertureF4
Minimum apertureF22
Number of diaphragm blades9
Optics
Elements14
Groups12
Special elements / coatings1 Aspherical P-MO element, 1 glass-moulded aspherical element, SD glass (ultra-low dispersion glass) FK01 and FK03 elements
Focus
Minimum focus0.25 m (9.84)
Maximum magnification0.2×
AutofocusYes
Motor typeMicro-type ultrasonic
Full time manualNo
Focus methodInternal
Focus notesOne-touch focus clutch mechanism
Distance scaleYes
DoF scaleNo
Physical
Weight530 g (1.17 lb)
Diameter84 mm (3.31)
Length90 mm (3.54)
Zoom methodRotary (internal)
Filter thread77.0 mm
Hood suppliedYes
Hood product codeBH-77B
