Canon has introduced the EF 200-400mm f/4L IS USM Extender 1.4x - a top-end telephoto zoom with a built-in switchable teleconverter, whose development was first announced back in February 2011. Simply flicking a lever at the rear of the barrel converts it to a 280-560mm f/5.6 lens. Designed for professional sports and wildlife photographers, it includes an array of top-end features such as Power Focus for movie shooting, and IS 'mode 3' that only applies stabilisation at the point of exposure, aiding panning. It also offers weathersealed construction, 4-stop image stabilisation, and a minimum focus distance of 2m. It will go on sale on 29th May, at an RRP of £11999.99 / €11800.
Jump to:
Press Release:
Introducing the EF 200-400mm f/4L IS USM Extender 1.4x – improved performance and versatility for professional sports and wildlife photographers
London, UK, 14 May 2013 – Canon today adds a new category to its range of high-performance super-telephoto lenses, with the introduction of the EF 200-400mm f/4L IS USM Extender 1.4x to Canon’s acclaimed L-series. The EF 200-400mm f/4L IS USM Extender 1.4x features a flexible 200-400mm focal range with a fixed f/4 aperture, 4-stop optical Image Stabilizer and for the first time in a commercially available lens, a built-in 1.4x extender. These features combine to provide an outstandingly versatile lens for professional sports or wildlife photographers. A robust magnesium alloy design, environmental protection and specialised lens coatings also make it ideal for mobile use, combining with the finest quality optics to deliver exceptional results, even in the harshest conditions.
Get closer to the action with superior image quality
The reach of the EF 200-400mm f/4L IS USM Extender 1.4x is boosted by its internal 1.4x extender, which is engaged or disengaged at the flick of a lever to provide an extended focal length of 280mm to 560mm – allowing photographers to get even closer to distant action. Ensuring the highest image performance, the optical design includes both fluorite and Ultra-low Dispersion (UD) lens elements, which help minimise chromatic aberration and eliminate colour blurring. Advanced anti-reflection SubWavelength Structure Coating (SWC) and Super Spectra Coating also reduce ghosting and flare. Thanks to the use of the latest optical technologies, image performance is unaffected when the integrated extender is used.
With a constant f/4 aperture the use of high shutter speeds to capture fast-paced action or a low-light scene is possible. A newly designed optical Image Stabilizer, which provides users with a four stop advantage, while IS ‘Mode 3’ applies image stabilisation only at the time of exposure – ensuring that photographers can pan with fast-paced action without IS overcompensating for movement. This feature is ideal for sports photographers, who typically have only a split-second to capture a subject in front of them.
Powerful, flexible focusing
The EF 200-400mm f/4L IS USM Extender 1.4x features Canon’s pioneering ring-type Ultrasonic Motor providing fast, silent autofocusing. For those who prefer to fine-tune focus themselves, full-time manual override allows photographers to manually focus at any moment when using AF. The Power Focus (PF) mode also increases versatility during movie shooting with the EOS-1D C or EOS-1D X, enabling photographers to achieve an accurate pull-focus effect at one of two speeds, simply by twisting the focus recall ring and stopping at a pre-set distance.
High-performance design for professional demands
Designed to answer professional demands for superior image quality and versatile zoom range, the EF 200-400mm f/4L IS USM Extender 1.4x a boasts a premium-quality design befitting Canon’s industry-renowned L-series lenses.
The tough magnesium alloy chassis ensures that, despite the inclusion of the 1.4x extender, the lens is a similar weight to lenses of comparable focal length. Fluorine coatings on the front and rear lens elements also reduce the ability of dirt to cling to the lens surface, while a dust and water-resistant construction allows photographers to shoot in challenging weather conditions. The combination of outstanding optical performance, versatility, weight and tough construction will make it an essential part of any professional sports or wildlife photographer’s kitbag.
EF 200-400mm f/4L IS USM Extender 1.4x key features
  • Built-in 1.4x extender, for extra magnification when you need it
  • Shoot in low light with four-stop Image Stabilizer
  • High image quality using Fluorite lens elements
  • Fast AF with USM technology
  • Robust design for use in the toughest environments
Canon EF 200-400mm f/4L IS USM Extender 1.4x specifications
Principal specifications
Lens typeZoom lens
Max Format size35mm FF
Focal length200–400 mm
Image stabilisationYes (4 stops claimed)
Lens mountCanon EF
Aperture
Maximum apertureF4
Minimum apertureF32
Number of diaphragm blades9
Optics
Elements25
Groups20
Special elements / coatingsFluorite and Ultra-Low dispersion glass elements, Sub-Wavelength Structure Coating and Super Spectra Coating
Focus
Minimum focus2.00 m (78.74)
Maximum magnification0.15×
AutofocusYes
Motor typeRing-type ultrasonic
Full time manualYes
Focus methodInternal
Distance scaleYes
DoF scaleNo
Focus distance limiter3 positions: Full, 2m-6m, 6m-infinity
Physical
Weight3620 g (7.98 lb)
Diameter128 mm (5.04)
Length366 mm (14.41)
MaterialsMagnesium alloy barrel
SealingYes
ColourWhite
Zoom methodRotary (internal)
Power zoomNo
Zoom lockNo
Filter thread52.0 mm
Filter notesRear drop-in filter holder
Hood suppliedYes
Hood product codeET-120 (WII)
Tripod collarYes
Other
NotesSwitchable built-in 1.4x extender (8 elements / 4 groups) converts lens to 280-560mm f/5.6 lens with 0.21x max magnification
Additional images
