After sticking with ~20MP for more than seven years, Canon has unveiled the EOS 5DS and EOS 5DS R, both of which offer 50.6MP full-frame sensors inside virtually the same body as the EOS 5D Mark III. The effect of the EOS 5DS R's low pass filter has been cancelled out for greater detail resolution, but aside from that difference the two cameras are identical. Like the EOS 5D III the new cameras offer 1080/30p video but do not feature headphone jacks or clean HDMI out.
Each uses dual DIGIC 6 processors, a 61-point AF system with 41 cross-type points and a 150,000-pixel RGB+IR metering sensor with 252 zones. The EOS 5DS and 5DS R are capable of 1080/30p HD video recording and offer dual SD/CF card slots. The cameras will be available in June 2015. The Canon EOS 5DS will sell for $3699 body-only; the EOS 5DS R will sell for $3899 body-only.
Press release:
CANON U.S.A. INTRODUCES THE WORLD’S HIGHEST RESOLUTION* FULL-FRAME DSLR CAMERAS: EOS 5DS AND EOS 5DS R
Featuring Canon’s Newly Designed 50.6 Megapixel Full-frame CMOS Sensor and Dual DIGIC 6 Image Processors, New DSLRs Deliver Ultra-high Resolution Images and Enhanced Features
MELVILLE, N.Y., February 5, 2015 – Canon U.S.A., Inc., a leader in digital imaging solutions, is proud to introduce the Canon EOS 5DSi and Canon EOS 5DS Ri Digital SLR cameras featuring the world’s highest resolution* among 35mm format DSLRs. Providing photographers with uncompromising image quality, these new EOS models incorporate a newly designed Canon 50.6 megapixel full-frame CMOS image sensor and Dual DIGIC 6 Image Processors for superb image quality and processing speed. Perfect for commercial, studio, portrait, landscape and architectural photography, or anyone looking for an affordable alternative to medium format, the ultra-high resolution of these new models allow for large-format printing and extensive cropping capability while maintaining fantastic image quality.
Maximizing the potential of the new 50.6 megapixel sensor – for the first time in an EOS camera the low-pass filter effect in the EOS 5DS R model is cancelled. The cancellation of the low-pass filter helps deliver sharp images, squeezing the most out of every pixel. Both models provide attractive options for medium format shooters especially when coupled with a wide array of over 70 creative Canon EF lenses to choose from.
“Canon is always looking to deliver the absolute best in image quality and push our technology to the limits. These cameras deliver on that pledge, providing photographers with two new incredible tools that will enable them to make the most out of every shoot,” said Yuichi Ishizuka, president and COO, Canon U.S.A., Inc. “As photography becomes more specialized and more images are captured than ever before, the burden is on the photography equipment to keep up with the demands of today’s artistic talents. These new camera models will provide many photographers with new options to deliver their vision to clients, fans, and the world.”
Built to Maximize Sharpness
In addition to the 50.6 megapixel full-frame image sensor and Dual DIGIC 6 Image Processors, both cameras include a 61-Point High Density Reticular AF array including up to 41 cross-type AF points and EOS iTR AF for high precision autofocus. They also include the EOS Scene Detection system featuring a 150,000-pixel RGB+IR 252-zone metering sensor that provides enhanced precision and performance.
In support of such a high-resolution imaging sensor, the EOS 5DS and EOS 5DS R cameras were designed to minimize camera shake and significantly improve stability via a reinforced chassis, baseplate and tripod lug to improve rigidity. Canon also re-designed the mirror vibration control system to help reduce mirror bounce and camera shake. To help maximize stability and minimize vibrations, Canon added a new Arbitrary Release Time Lag Setting in Mirror Lock mode in both models. In addition to the standard setting (press the shutter button once to lock the mirror, then again to release the shutter), the EOS 5DS and EOS 5DS R cameras offer new setting intervals of 1/8, 1/4, 1/2, one and two seconds, releasing the shutter after the selected preset delay, allowing potential camera vibration to dissipate before shutter release.
A new Picture Style called “Fine Detail” has been added to enhance the sharpness of JPEGs and EOS Movies with three new settings: Strength, Fineness and Threshold. With such abundant resolution on each sensor, both models also provide two cropped shooting modes, while still delivering high-resolution images 30.5 megapixels for the 1.3x mode and 19.6 megapixels for the 1.6x mode. The available crop options are visible as a mask or an outline in the viewfinder; so shooters can know exactly where to frame their subject.
Capturing the Action
Like the EOS 7D Mark II, the EOS 5DS and EOS 5DS R cameras feature an advanced AE system that can detect and compensate for flickering light sources such as sodium vapor lamps that are often used in gymnasiums and natatoriums. When enabled, this anti-flicker system automatically adjusts shutter release timing to help reduce disparities in exposure and color especially during continuous shooting. And new Auto White Balance settings include Ambience Priority and White Priority (for use when shooting under tungsten lighting).
Photographers and cinematographers will appreciate improved custom controls including a built-in intervalometer and bulb timer to enable the capture of time-lapse images and long-exposure images. These features are ideal for recording fireworks, star trails, sunrises and more.
Both models feature Intelligent Viewfinder II providing approximately 100 percent field of view, while adding the ability to display cropped shooting frames and superimpose a customizable selection of camera settings and data such as dual-mode electronic level display and grid, as well as exposure, white balance, metering, drive, image quality and AF modes. A new Customizable Quick Control Screen, another first for EOS cameras, allows photographers to quickly change frequently used camera settings and functions.
The EOS 5DS and EOS 5DS R cameras continue the EOS Movie tradition with the ability to shoot in 1080p Full HD up to 30p or 720p HD video up to 60p. A creative Time Lapse Movie function, a first for EOS cameras, takes a continuous series of still photographs and automatically combines them in camera into a Full HD movie file. Interval adjustments can be set from one second to 99 hours, 59 minutes and 59 seconds. The number of shots possible range from 2 to 3,600 with a maximum of two minutes and 30 seconds of playback time. In addition, high-speed continuous shooting up to five-frames-per-second (fps) at full 50 megapixel resolution allows users to capture fast action.
The EOS 5DS and EOS 5DS R cameras feature dual card slots for CF and SD memory cards, including Ultra High Speed (UHS-1) SD cards. Built to last, the cameras also feature a shutter durability rating up to 150,000 cycles, the same as the EOS 5D Mark III.
Availability
The EOS 5DS and EOS 5DS R Digital SLR cameras are scheduled to be available through authorized Canon dealers in June 2015 for estimated retail prices of $3,699.00 and $3,899.00 for the body only, respectively.
* Among 35mm‐format Digital SLR cameras as of February 5, 2015 according to published competitive information.
Canon EOS 5DS/5DS R specifications
 Canon EOS 5DSCanon EOS 5DS R
Price
MSRP$3699/£2999/€3999 (body only)$3899/£3199/€4249 (body only)
Body type
Body typeMid-size SLR
Body materialMagnesium alloy
Sensor
Max resolution8688 x 5792
Image ratio w:h3:2, 16:9
Effective pixels51 megapixels
Sensor photo detectors53 megapixels
Sensor sizeFull frame (36 x 24 mm)
Sensor size notesOffers 1.6x and 1.3x crop modes, as well as medium and small Raw sizes.
Sensor typeCMOS
ProcessorDual DIGIC 6
Color spacesRGB, Adobe RGB
Color filter arrayPrimary color filter
ISOAuto, 100-6400 (expandable to 50-12800)
Boosted ISO (minimum)50
Boosted ISO (maximum)12800
White balance presets8
Custom white balanceYes
Image stabilizationNo
Uncompressed formatRAW
JPEG quality levelsFine, normal
File format
  • JPEG (Exif v2.3, DPOF v2.0)
  • Raw (Canon CR2, 14-bit)
Optics & Focus
Autofocus
  • Contrast Detect (sensor)
  • Phase Detect
  • Multi-area
  • Center
  • Selective single-point
  • Tracking
  • Single
  • Continuous
  • Face Detection
  • Live View
Autofocus assist lampNo
Manual focusYes
Number of focus points61
Lens mountCanon EF
Focal length multiplier1×
Screen / viewfinder
Articulated LCDFixed
Screen size3.2
Screen dots1,040,000
Touch screenNo
Screen typeClearView II TFT-LCD
Live viewYes
Viewfinder typeOptical (pentaprism)
Viewfinder coverage100%
Viewfinder magnification0.71×
Photography features
Minimum shutter speed30 sec
Maximum shutter speed1/8000 sec
Exposure modes
  • Scene Intelligent Auto
  • Program AE
  • Shutter Priority AE
  • Aperture Priority AE
  • Manual
  • Bulb
  • Custom
Built-in flashNo
External flashYes (via hot shoe and PC sync port)
Flash X sync speed1/200 sec
Drive modes
  • Single
  • High-speed continuous
  • Low-speed continuous
  • Silent single shooting
  • Silent continuous shooting
  • Self-timer
Continuous drive5.0 fps
Self-timerYes (2 or 10 secs)
Metering modes
  • Multi
  • Center-weighted
  • Spot
  • Partial
Exposure compensation±5 (at 1/3 EV, 1/2 EV steps)
AE Bracketing±3 (3 frames at 1/3 EV, 1/2 EV steps)
WB BracketingYes
Videography features
Resolutions1920 x 1080 (30p, 25p, 24p), 1280 x 720 (60p, 50p), 640 x 480 (30p, 25p)
FormatH.264
Videography notesSupports ALL-I and IPB compression
MicrophoneMono
SpeakerMono
Storage
Storage typesSD/SDHC/SDXC (UHS-I compatible), CompactFlash
Connectivity
USB USB 3.0 (5 GBit/sec)
HDMIYes (mini-HDMI)
Microphone portYes
Headphone portNo
Remote controlYes (Wired and wireless)
Physical
Environmentally sealedYes (dust and water-resistent)
BatteryBattery Pack
Battery descriptionLP-E6 lithium-ion battery & charger
Battery Life (CIPA)700
Weight (inc. batteries)930 g (2.05 lb / 32.80 oz)
Dimensions152 x 116 x 76 mm (5.98 x 4.57 x 2.99)
Other features
Orientation sensorYes
Timelapse recordingYes
GPSNone
