Panasonic has formally unveiled the LUMIX DMC-G5, a mid-level mirrorless interchangable lens camera. The G5 is built around a 16MP LiveMOS sensor that the company implies hasn't been used in a G-series camera before. This, combined with the company's latest 'Venus Engine' allows the capture of 1080p video at 60 frames per second (50p in European examples). It also gains an additional control lever, higher-resolution 920,000 dot rear LCD and regains the eye-sensor to automatically switch between LCD and electronic viewfinder. In principle the G5 will sit above the existing G3 in the company's lineup. For more information, read our hands-on preview.
Jump to:
Press Release:
The New LUMIX G5 Offers High Image Quality with High Speed Response Time
July 18, 2012 (Secaucus, NJ) – Panasonic today announced a new addition to the popular line of LUMIX G series cameras, the LUMIX DMC-G5.  The newest Digital Single Lens Mirrorless camera offering from Panasonic, the LUMIX G5, features a newly integrated 16.05-megapixel Live MOS sensor and redesigned Venus Engine to render clear, crisp images in both photo and video recording. Featuring a compact, lightweight body with built-in flash, the LUMIX G5 boasts ultra-high mobility while offering users powerful camera performance which achieves spectacular image quality, realizing true-to-life photo details through excellent resolution, image rendering and color production.
The LUMIX G5’s high-grade lens and precision AF (Auto Focus) achieves high resolution, optimal balance of resolution and noise reduction to produce lifelike image rendering and high precision auto exposure and white balance for faithful color reproduction. A redesigned Venus Engine features exceptionally advanced signal processing capabilities, producing clear, crisp images in both photo and video recording. The 3DNR detects smooth areas or edges in photos and adjusts the strength of noise reduction (stronger for smooth portion, milder for edge portion) to maintain object descriptiveness. The Multi-process NR quickly detects brightness in each part of a picture and applies optimal noise reduction in multiple steps. The newly incorporated HDR (High Dynamic Range) allows for several pictures consecutively shot at different exposure levels to be overlaid, producing a single composite picture to eliminate over-exposure or under-exposure.
Like all cameras in the LUMIX G series, the LUMIX G5 adopts Contrast AF (Auto Focus), so focusing is controlled by the image sensor.  Compared with the Phase difference system AF, Contrast AF boasts higher accuracy, especially when shooting with a bright lens with small F values. To further advance the Contrast AF, the G5 incorporates full-area Touch AF, making it possible to set the focus on any point in the field of view. Additionally, ultra high-speed Light Speed AF, quickly locks onto a subject, making it possible to capture even fast moving subjects clearly.  Combined with Touch AF control and high-speed burst shooting at six frames per second in 16.05-megapixel full resolution, it has never been easier to capture fast-moving objects clearly.
The LUMIX G5 offers users simple operation controls with minimal stress, so users can concentrate on shooting.  A newly added function lever conveniently located near the shutter release allows for direct adjustment of zoom*1, exposure or aperture*2 control and can be used to magnify images in playback mode and page flip in menu mode.  Additionally, the combination use of the function lever and turn-and-push rear dial allows users to adjust major shooting settings, accelerating the camera’s simple, intuitive operation.
The LUMIX G5’s large, bright 1,440,000-dot equivalent LVF (Live View Finder) retains outstanding viewability and features approximately 100% field of view. Suppressing color breakup, the LVF assures stunning image view for any subject or scene. The LVF is newly designed to integrate an eye sensor for the LUMIX G5, which allows image output between the LVF and LCD screen to be switched automatically with the eye sensor on the LVF (which features optional sensitivity of high, low and off). Additionally Eye Sensor AF (Auto Focus) automatically starts focusing when the photographer looks into the EVF to capture spur-of-the-moment shooting opportunities.
A large, 920,000-dot high resolution LCD screen with wide-viewing angle rotates 180 degrees to the side, tilts 270 degrees up and down and offers approximately 100% field of view. Touch screen operation on the LCD screen allows for simple shooting or playback of images and the new Touch Pad function enables the use of both LVF and LCD simultaneously, which encourages more intuitive shooting. Lag time of image output has been minimized by approximately 18% compared to the LUMIX G5’s predecessor, the LUMIX G3, making it easier to monitor fast-moving subjects. The Level Gauge give the camera the ability to automatically detect the horizontal or vertical angle of view so that photos shot in a portrait aspect will automatically be displayed vertically, no matter which lens is used. The newly added Electronic Shutter mode allows silent operation which is helpful in areas where silence is needed.
Creative Control Mode has been upgraded in the LUMIX G5 with an increase of filter options from five options to 14, adding Soft Focus*3, Dynamic Monochrome, Impressive Art, One Point Color, Cross Process, Low Key, Toy Effect and Star Filter, in addition to the conventional Expressive, Retro, High Key, Sepia, Hi Dynamic, Miniature Effect*4 modes.  With the new GUI menu tab, switching filter effects is seamless. A preview of filter effects can be seen on the large LCD screen via Live View mode and the camera intuitively recommends filters depending on the scene that the camera detects in iA (Intelligent Auto) or iA Plus mode.  Furthermore, iA Plus mode allows users to adjust defocusing area in the background, exposure compensation and white balance for more flexible control while activating automatic shoot assist functions such as AF Tracking, Intelligent ISO Control, Intelligent D-range Control, Face Recognition and Intelligent Scene Selector.
For beginner users of interchangeable lens system cameras, the LUMIX G5 features the new Scene Guide which offers 23 sample pictures shot by professional photographers. Users can choose the photo closest to the situation that they are shooting and optimal parameters for shooting the scene will be set automatically*5.  Additionally, procedures, technical advice and recommended interchangeable lens options for the scene can be shown to allow users to better understand and learn photography.
Not only does the LUMIX G5 produce stunning still imagery, but it also records high quality video.  With the ability to record high-resolution full-HD 1,920x1,080 60p videos in AVCHD Progressive (MPEG-4) or MP4*6 format, subjects with fast motion and fine details are reproduced clearly. In addition to practical full-time AF, the Touch AF in video recording also lets the user enjoy professional-like selective focusing which allows the focus to be shifted while shooting video and AF Tracking easily locks onto a subject to focus, even when it moves. The Extra Tele Conversion function extends zoom range Max 4.8x without deterioration of image quality. The LUMIX G5 features a dedicated video record button on the top of the camera body so users can instantly start recording videos while shooting photographs without changing any settings. The camera can also take photos while recording video live just by hitting the shutter button. Along with full-HD video capabilities, the LUMIX G5 also features high-quality sound, recorded with Dolby® Digital Stereo Creator and noise from background wind is minimized with the Wind Cut function.
The LUMIX DMC-G5 will be available in black, white and silver in various kit options.  Pricing and availability will be announced approximately 30 days prior to shipping.  For more information about Panasonic LUMIX digital cameras, please visit
*35mm camera equivalent.
*1 When used with Power Zoom lenses H-PS14042 or H-PS45175.
*2 In M(Manual) mode
*3 For photo only
*4 Sound will not be recorded with [MINIATURE EFFECT] in Creative Control Mode and approximately 1/10 of the time period is recorded. (If you record for 10 minutes, the resulting motion picture recording will be approximately 1 minute long)
*5 Video recording using Scene Guide is not possible in some scenes.
*6 30p in MP4
• Leica is a registered trademark of Leica Microsystems IR GmbH.
• "AVCHD Progressive", "AVCHD", the "AVCHD Progressive" Logo and the "AVCHD" Logo are trademarks of Panasonic Corporation and Sony Corporation.
• Dolby and the double-D symbol are trademarks of Dolby Laboratories.
• HDMI, the HDMI logo and High-Definition Multimedia Interface are trademarks or registered trademarks of HDMI Licensing LLC.
• All other company and product names are trademarks of their respective corporations.
• This unit is compatible with both SD/SDHC/SDXC Memory Cards. You can only use SDHC Memory Cards on devices that are compatible with them. You cannot use SDHC Memory Cards on devices that are only compatible with SD Memory Cards. (When using an SDHC Memory Card on another device, be sure to read the operating instructions for that device.)
• Some accessories are not available in some countries.
• The use of recorded or printed materials that are protected by copyright for any purpose other than personal enjoyment is prohibited, as it would infringe upon the rights of the copyright holder.
• Design and specifications are subject to change without notice.
Panasonic Lumix DMC-G5 specifications
Body type
Body typeSLR-style mirrorless
Max resolution4608 x 3456
Other resolutions4608x3456, 3264x2448, 2336x1752, 4608x3072, 3264x2176, 2336x1560, 4608x2592, 3264x1840, 1920x1080, 3456x3456, 2448x2448, 1744x1744, 1712x1712
Image ratio w:h1:1, 4:3, 3:2, 16:9
Effective pixels16 megapixels
Sensor photo detectors18 megapixels
Sensor sizeFour Thirds (17.3 x 13 mm)
Sensor typeCMOS
ProcessorVenus Engine VII FHD
Color spacesRGB, Adobe RGB
Color filter arrayPrimary color filter
ISOAuto, 160, 200, 400, 800, 1600, 3200, 6400, 12800
White balance presets5
Custom white balanceYes (2)
Image stabilizationOptical
Uncompressed formatRAW
JPEG quality levelsFine, Standard
File format
  • RAW
  • RAW + Fine
  • RAW + Standard
  • Fine
  • Standard
  • MPO + Fine
  • MPO + Standard (with 3D lens in Micro Four Thirds System standard)
Optics & Focus
  • Contrast Detect (sensor)
  • Multi-area
  • Selective single-point
  • Tracking
  • Single
  • Continuous
  • Touch
  • Face Detection
  • Live View
Autofocus assist lampYes
Digital zoomYes (2x, 4x)
Manual focusYes
Number of focus points23
Lens mountMicro Four Thirds
Focal length multiplier2×
Screen / viewfinder
Articulated LCDFully articulated
Screen size3
Screen dots920,000
Touch screenYes
Screen typeTFT Color LCD with wide-viewing angle
Live viewYes
Viewfinder typeElectronic
Viewfinder coverage100%
Viewfinder magnification1.4×
Viewfinder resolution1,440,000
Photography features
Minimum shutter speed60 sec
Maximum shutter speed1/4000 sec
Exposure modes
  • Program
  • Aperture Priority
  • Shutter Priority
  • Manual
Scene modes
  • Clear Portrait
  • Silky Skin
  • Backlit Softness
  • Clear in Backlight
  • Relaxing Tone
  • Sweet Child's Face
  • Distinct Scenery
  • Bright Blue Sky
  • Romantic Sunset Glow
  • Vivid Sunset Glow
  • Glistening Water
  • Clear Nightscape
  • Cool Night Sky
  • Warm Glowing Nightscape
  • Artistic Nightscape
  • Glittering Illuminations
  • Clear Night Portrait
  • Soft Image of a Flower
  • Appetizing Food
  • Cute Dessert
  • Freeze Animal Motion
  • Clear Sports Shot
  • Monochrome
Built-in flashYes (Pop-up)
Flash range10.50 m
External flashYes (Hot-shoe)
Flash modesAuto, On, Off, Red-Eye, Slow Sync
Flash X sync speed1/160 sec
Drive modes
  • Single
  • Continuous
  • Self-timer
Continuous drive6.0 fps
Self-timerYes (2 or 10 sec, 10 sec (3 images))
Metering modes
  • Multi
  • Center-weighted
  • Spot
Exposure compensation±5 (at 1/3 EV steps)
AE Bracketing±3 (3, 5, 7 frames at 1/3 EV, 2/3 EV, 1 EV steps)
WB BracketingYes (3 frames in either blue/amber or magenta/green axis)
Videography features
Resolutions1920 x 1080 (60, 50, 30, 25fps) 1280 x 720 (60, 50, 30, 25fps), 640 x 480 (30, 25fps
Videography notes1920 x 1080, 60p, 50p (sensor output is 60p, 50p) (PSH: 28Mbps) ; 1920 × 1080, 60i,50i (sensor output is 60p, 50p) (FSH: 17Mbps) ; 1920 x 1080, 30p,25p (sensor output is 60p, 25p) (FPH: 17Mbps) ; 1280 x 720, 60p, 50p (sensor output is 60p, 25p) (SH: 17Mbps)
Storage typesSD/SDHC/SDXC
Storage includedNone
USB USB 2.0 (480 Mbit/sec)
HDMIYes (Mini HDMI Type C)
Remote controlYes (Optional DMW-RSL1)
Environmentally sealedNo
BatteryBattery Pack
Battery descriptionLithium-Ion rechargeable battery & charger
Battery Life (CIPA)320
Weight (inc. batteries)396 g (0.87 lb / 13.97 oz)
Dimensions120 x 83 x 71 mm (4.72 x 3.27 x 2.8)
Other features
Orientation sensorYes
Timelapse recordingNo
Additional images
