Nikon US has announced a radio-frequency camera triggering system compatible with all its current DSLRs. The WR-10 system works over a 60m range and, unlike the current infrared system, does not require a line-of-sight between the trigger and the camera. Users of mass-market Nikons (D600 and below) can use the WR-T10 transmitter to focus or fire cameras with WR-R10 receivers attached to them. Owners of pro-grade DSLRs with 10-pin connectors can use the WR-A10 adapter to connect the R10 to their camera. This combination allows the camera to act as a host that can remotely trigger up to 64 other cameras.
The system was released in Europe in November, alongside the D5200.
From D5200 press release:
New optional WR-R10 and WR-T10 Wireless Remote Controllers
WR-T10 Transmitter WR-R10 Transceiver
The D5200 is also compatible with a new wireless radio frequency remote accessory, the WR-R10 and WR-T10 Wireless Remote Controllers. When using these devices, the camera can be triggered remotely, making it ideal for group shots, remote applications, or to reduce shake when the camera is mounted on a tripod. This new wireless remote system operates from a radio signal rather than infrared light, dramatically increasing functionality and range. Now the camera can be triggered from up to 20 meters (66 feet) away, and a direct line of sight is not necessary.
The WR-T10 Transmitter and WR-R10 Transceiver, pictured here with the WR-A10 Adapter (on the left).
The remotes also enable the bulb function for long shutter applications, as well as functions of the camera that are affected by a half-press of the shutter, including the engagement of the AF system or starting and stopping video capture. The WR-R10 transceiver can be connected to the accessory terminal of many Nikon D-SLR cameras including the new D5200, D3200 and D600. For those cameras that feature a 10-pin terminal, the optional WR-A10 adapter can be fastened to allow use of the wireless remote controllers.
WR-A10 Adapter (Allows use of WR-R10 with high-end DSLRs with 10-pin connectors)
Pricing and Availability
The WR-T10 Wireless Remote Controller will be available at the end of January for a SRP of $94.96*, WR-R10 Wireless Remote Transceiver for an SRP of $126.96*, the WR-A10 Wireless Remote Adapter for a SRP of $74.96* and the WR-10 Wireless Remote Controller Set will be available for a SRP of $277.96*.
*Suggested retail price listed only as a suggestion. Actual prices are set by dealers and are subject to change at any time.
